Why is camera not turn ON
Camera not turning on
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
@priyeshcamera if you are sure you have a good battery and if your battery case door functions properly, time to take it apart. Use this guide Sony Cyber-shot DSC-S2100 LCD Replacement to get into your camera. Once there, you need to check the motherboard. Make sure that the battery cables are properly attached and then check the fuse for continuity. One is the power fuse.
Esta resposta foi útil?
Últimas 24 horas: 9
Últimos 7 dias: 15
Últimos 30 dias: 47
Ao todo: 568
4 comentários
Hi @priyeshcamera,
Have you tried using new fresh batteries in the camera to see if it turned on, you didn't say?
por jayeff
Yes, I already checked it
por Priyeshcamera
Start problem not running
por Binod Saw
Camera is 1year old please recover
por Display is on but don't work
