Ir para o conteúdo principal
Sony Cyber-shot DSC-S2100 LCD Replacement
O que você precisa
  1. Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: passo 1, imagem 1 %32 Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: passo 1, imagem 2 %32 Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: passo 1, imagem 3 %32
    • The broken LCD is immediately visible when the camera is turned on.
    • Remove the batteries and, if so equipped, the memory card.
    • Remove the three Philips screws from the bottom of the camera with a Phillips #00 Screwdriver.
  2. Sony Cyber-shot DSC-S2100 LCD Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-S2100 LCD Replacement: passo 2, imagem 2 %32 Sony Cyber-shot DSC-S2100 LCD Replacement: passo 2, imagem 3 %32
    • Remove the two Philips screws from the right side of the camera.
    • Remove the two Philips screws from the left side of the camera.
    • Split the housing by either using a plastic opening tool, or your finger nails. No excessive force is necessary. For ease of accomplishment, start at the battery compartment.
  3. Sony Cyber-shot DSC-S2100 LCD Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-S2100 LCD Replacement: passo 3, imagem 2 %32 Sony Cyber-shot DSC-S2100 LCD Replacement: passo 3, imagem 3 %32
    • Once the rear case has been removed, the LCD and frame are easily identified.
    • Fold the LCD to the right, away from the frame.
    • Do not try to remove the LCD yet since the ribbon cable is still connected.
    • Remove the three Philips screws from the LCD frame.
  4. Sony Cyber-shot DSC-S2100 LCD Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-S2100 LCD Replacement: passo 4, imagem 2 %32 Sony Cyber-shot DSC-S2100 LCD Replacement: passo 4, imagem 3 %32
    • When the LCD frame is removed, the ribbon cable becomes clearly visible.
    • Flip the LCD to its left side. Open the clip of the connector by moving the black lock to the right.
    • Remove the LCD
  5. Sony Cyber-shot DSC-S2100 LCD Replacement: passo 5, imagem 1 %32
    • Ensure the screen displayed greets you, once you reassembled your camera
Conclusão
4 outras pessoas executaram este guia.
oldturkey03
Membro desde: 09/29/10
837.140 Reputação
Autoria de 123 guias
2Comentários do guia
你在哪里?把相机给你帮我挨可以吗
Jeanne - Responder
请问你是在多伦多附近吗?
Jeanne - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 37
Ao todo: 3,489
