Ir para o conteúdo principal
Model number DSC-2100. Sony 12.1 mega-pixel point-and-shoot camera
8 Perguntas Visualizar todos
Why is camera not turn ON
Camera not turning on
Esta é uma boa pergunta?
Pontuação 1
4 comentários
Hi @priyeshcamera,
Have you tried using new fresh batteries in the camera to see if it turned on, you didn't say?
por
Yes, I already checked it
por
Start problem not running
por
Camera is 1year old please recover
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@priyeshcamera if you are sure you have a good battery and if your battery case door functions properly, time to take it apart. Use this guide Sony Cyber-shot DSC-S2100 LCD Replacement to get into your camera. Once there, you need to check the motherboard. Make sure that the battery cables are properly attached and then check the fuse for continuity. One is the power fuse.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Priyeshcamera será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 13
Últimos 30 dias: 45
Ao todo: 566
