Ir para o conteúdo principal
iPhone XS Lightning Connector Assembly Replacement
Robert K
Robert K e 5 outros colaboradores
Última atualização em 17 de mai de 2025
40 minutos - 6 horas
Difícil
Guia colaborativo
Introdução
Ir para o passo 1
MUST READ
Use this guide to replace the Lightning connector assembly in your iPhone XS. If you've tried cleaning the lightning port to no avail, replacing the Lightning connector can solve charging and connectivity issues.
The internal speaker connector is also part of this cable, so you will also need to replace this (or your speaker) to resolve sound issues.
Additionally, the guide steps below lead you up to the part where you remove the Taptic Engine, so please refer to the video after those steps. Please also look over the video before opening your phone just to get two perspectives of the disassembly process.
O que você precisa
Peças
Ferramentas
Exibir mais…
Vídeo de Apresentação
  1. iPhone XS Lightning Connector Assembly Replacement, Pentalobe Screws: passo 1, imagem 1 %32
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Der Original Akku ist codiert. Egal, ob man einen zweiten Apple Original Akku oder einen neuen Fremdakku einbaut erscheint bereits in den Einstellungen eine "Wichtige Batterienachricht" mit einem roten Punkt. "Unbekanntes Bauteil" und die "Informationen zum Batteriezustand" sind nicht verfügbar. Diese Nachricht verbleibt immer und nervt auf Dauer immens.
    Der Akku muss angelernt werden und dieses können von jetzt an nur authorisierte Apple Servicebetriebe und diesen ist es durch Apple verboten die notwendige Info weiterzugeben.
    Dies ist nicht zu verwechseln mit der bereits bekannten Rekalibrierung seit iOS 14.5.
    Seit dieser neuen Codierung kostet der Akkutausch bei Apple auch nicht mehr 75 € sondern aktuell 99 € (Stand Novmber 2023 in Deutschland).
    Damit sind künftig alle nicht authorisierten Servicebetriebe raus - denn wer will schon dauernd diese Mitteilung auf dem Bildschirm haben?
    Überlegt vorher, ob unter diesen Bedingungen ein eigener Akkutausch noch sinnvoll ist .....
    Manfred Wachtel - Responder
    Lieben Dank @manfredwachtel ! Mehr Infos dazu haben wir auch in unserem Blog zusammengefasst: https://de.ifixit.com/News/78890/teileko...
    Sandra Hiller -
  2. iPhone XS Lightning Connector Assembly Replacement, Tape over any cracks: passo 2, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement, Tape over any cracks: passo 2, imagem 2 %32 iPhone XS Lightning Connector Assembly Replacement, Tape over any cracks: passo 2, imagem 3 %32
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  3. iPhone XS Lightning Connector Assembly Replacement, Anti-Clamp instructions: passo 3, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement, Anti-Clamp instructions: passo 3, imagem 2 %32 iPhone XS Lightning Connector Assembly Replacement, Anti-Clamp instructions: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    The anti clamp is a much needed tool
    It makes opening the phone a breeze.
    Lon
    [deleted] - Responder
  4. iPhone XS Lightning Connector Assembly Replacement: passo 4, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 4, imagem 2 %32 iPhone XS Lightning Connector Assembly Replacement: passo 4, imagem 3 %32
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPhone XS Lightning Connector Assembly Replacement: passo 5, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 5, imagem 2 %32 iPhone XS Lightning Connector Assembly Replacement: passo 5, imagem 3 %32
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone XS Lightning Connector Assembly Replacement: passo 6, imagem 1 %32
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  7. iPhone XS Lightning Connector Assembly Replacement: passo 7, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 7, imagem 2 %32
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  8. iPhone XS Lightning Connector Assembly Replacement: passo 8, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 8, imagem 2 %32 iPhone XS Lightning Connector Assembly Replacement: passo 8, imagem 3 %32
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap under the screen and the plastic bezelnot the screen itself.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    It seems like I need a third hand to do this. To hold the phone; hold the suction cup; and push the pick in the space.
    haroldappel - Responder
  9. iPhone XS Lightning Connector Assembly Replacement: passo 9, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 9, imagem 2 %32 iPhone XS Lightning Connector Assembly Replacement: passo 9, imagem 3 %32
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  10. iPhone XS Lightning Connector Assembly Replacement, Screen information: passo 10, imagem 1 %32
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  11. iPhone XS Lightning Connector Assembly Replacement: passo 11, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 11, imagem 2 %32 iPhone XS Lightning Connector Assembly Replacement: passo 11, imagem 3 %32
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  12. iPhone XS Lightning Connector Assembly Replacement: passo 12, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 12, imagem 2 %32 iPhone XS Lightning Connector Assembly Replacement: passo 12, imagem 3 %32
    • The top edge of the display is secured with both glue and clips.
    • Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
    • The clips will break if you use too much force. Work carefully and be patient.
    • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
    • Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
  13. iPhone XS Lightning Connector Assembly Replacement: passo 13, imagem 1 %32
    • Pull on the small nub on the suction cup to remove it from the front panel.
  14. iPhone XS Lightning Connector Assembly Replacement: passo 14, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 14, imagem 2 %32 iPhone XS Lightning Connector Assembly Replacement: passo 14, imagem 3 %32
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    Open from the LEFT. Photo confused me and I came very close to damaging my phone by opening from the wrong side.
    charlotte - Responder
  15. iPhone XS Lightning Connector Assembly Replacement, Display Assembly: passo 15, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement, Display Assembly: passo 15, imagem 2 %32
    Magnetic Project Mat
    $19.95
    • Remove five screws securing the logic board connector bracket, of the following lengths:
    • Three 1.0 mm Y000 screws
    • One 1.3 mm Y000 screw
    • One 3.7 mm Phillips screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    The ribbon makes the 1.3 mm screw a little tricky. Use one hand to hold the display at a 90 degree or smaller angle to create the slack necessary to get the screw driver in place.
    I tracked my screws by using my kids fridge magnets to hold each screw size and placing a piece of masking tape below with the screw size.
    I stripped a screw ugh
    Tresia - Responder
    Where can i buy a One 1.3 mm Y000 screw
    Ismail - Responder
    FYI: I used a tiny piece of scotch tape to hold those 1mm screws in place while aligning the magnetic screwdriver. Otherwise they are so tiny the magnetic bit pulls them right out the hole.
    Jeff Miller - Responder
  16. iPhone XS Lightning Connector Assembly Replacement: passo 16, imagem 1 %32
    • Remove the bracket.
    • The bracket may be lightly adhered in place. Lift gently but firmly to separate it.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    During reassembly, pause here to check function. Gently reattach the top of the display to the base to test face ID.
  17. iPhone XS Lightning Connector Assembly Replacement: passo 17, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 17, imagem 2 %32
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  18. iPhone XS Lightning Connector Assembly Replacement: passo 18, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 18, imagem 2 %32
    • Use a spudger or a fingernail to pry up and disconnect the front panel sensor assembly connector.
    In my phone the connector made poor contact with the socket resulting in no sound audible through the phone receiver/headset. There was an overhang of insulation close to the socket which I believe may have prevented a good connection. So if you have these kinds of audio problems you might see if this is the problem.
    goblazers - Responder
  19. iPhone XS Lightning Connector Assembly Replacement: passo 19, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 19, imagem 2 %32
    • Use a spudger or a fingernail to disconnect the OLED panel cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Shine a bright light here to help you align the connector. Eventually, the right side snapped in first.
    On reassembly, use the pad of your fingertip to reconnect.
  20. iPhone XS Lightning Connector Assembly Replacement: passo 20, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 20, imagem 2 %32
    • Use a spudger or fingernail to pry the digitizer cable connector up from its socket.
    • This connector's recessed location makes it tricky to reconnect. Take your time and align it carefully, then gently press it into place with your fingertip—first one side, then the other. You should feel it click into place.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
    Reassembly: reconnecting the press connectors upon reassembly was so hard, even for the ones not seated in a recessed location !! It took me two days to get them reconnected. What helped me was to shine bright lights on all sides of the iPhone and then hold the iPhone vertically like a book and press it in that way. They are now all in, but the touchscreen functionality has disappeared :( so I will need to reconnect that one.
    natialollie - Responder
  21. iPhone XS Lightning Connector Assembly Replacement: passo 21, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 21, imagem 2 %32 iPhone XS Lightning Connector Assembly Replacement: passo 21, imagem 3 %32
    • The front panel sensor assembly flex cable is lightly adhered in place.
    • Carefully lift the cable until the adhesive separates.
    Will replacing camera and sensors fix damaged face I'd
    Siddhartha Chowdhury - Responder
    No, FaceID will be disabled because the original sensors are paired with the logic board.
    Arthur Shi -
  22. iPhone XS Lightning Connector Assembly Replacement: passo 22, imagem 1 %32
    I wish the reassembly directions were separate. I forgot to pause here to do the waterproof seal.
    Geez, I blazed right past that small line to replace the waterproof seal. Needs to be called out much larger.
  23. iPhone XS Lightning Connector Assembly Replacement, Lower Speaker: passo 23, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement, Lower Speaker: passo 23, imagem 2 %32
    • Remove the five screws securing the two brackets below the Taptic Engine and main speaker:
    • One 1.0 mm tri-point Y000 screw
    • Two 1.3 mm Phillips screws
    • One 1.7 mm Phillips screw
    • One 1.8 mm Phillips screw
    Bonjour,
    Plus pratique avec une Y000. Dans mon cas c’était impossible en Y00.
    Bonne journée. :)
    Pascal Prugna - Responder
    got stuck on the 1.8 mm screw and had to abort. The Phillips head provided “PH000” didn’t quite fit and stripped the screw.
    Jimmy Zhang - Responder
    kit doesn’t come with the right screwdrivers for this step!! :(
    R.J. - Responder
    I ended up skipping this step through 32. It’s not necessary to take the speaker and taptic thing off. I just used the thin black spudger flat edge and pried under the battery on the L-shaped edge and dislodged the adhesive and then did the same on the top edge. You will end up bending the old battery but that’s ok—just don’t poke it. keep poking the flat edge of the spudger in there kind of like a knife to break the adhesive. once you get at least two spots of the adhesive pulled, the rest comes up quite easily when you lift the whole battery.
    R.J. - Responder
    I agree with R.J. The bracket screws are minute. They are much easier to remove than to put back. Avoid taking them out if you can.
    Kevin Bennett - Responder
  24. iPhone XS Lightning Connector Assembly Replacement: passo 24, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 24, imagem 2 %32 iPhone XS Lightning Connector Assembly Replacement: passo 24, imagem 3 %32
    • The brackets are lightly adhered in place.
    • Gently lift to unstick and remove each bracket, being careful not to bend it.
    • If necessary, apply a little heat with a hair dryer or heat gun to soften the adhesive. (Putting an iOpener on the brackets is not recommended, as this may bend the spring contacts along the top.)
  25. iPhone XS Lightning Connector Assembly Replacement: passo 25, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 25, imagem 2 %32
    • Remove the 1.9 mm Phillips screw securing the speaker connector cover.
    screew is 1,81mm
    Boni Zei - Responder
    The tools that you provided is not able to move the screw
    Gary P - Responder
  26. iPhone XS Lightning Connector Assembly Replacement: passo 26, imagem 1 %32
    • Remove the speaker connector cover.
  27. iPhone XS Lightning Connector Assembly Replacement: passo 27, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 27, imagem 2 %32
    • Use the tip of a spudger to pry up and disconnect the speaker connector.
  28. iPhone XS Lightning Connector Assembly Replacement: passo 28, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 28, imagem 2 %32
    • When prying up the speaker, take care not to damage the speaker flex cable you just disconnected. If necessary, bend the cable toward the battery so the speaker has room to come out.
    • Insert a spudger under the top edge of the speaker, near the edge of the iPhone's case.
    • Gently pry up and lift the top edge of the speaker slightly.
    • When reinstalling the speaker, check the position of the flex cable and make sure it doesn't get trapped underneath the speaker.
  29. iPhone XS Lightning Connector Assembly Replacement: passo 29, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 29, imagem 2 %32
    • While prying up the speaker, use tweezers to peel away the plastic bumper strip from the top edge of the speaker.
    • If necessary, apply a little heat to soften the adhesive and make the bumper strip easier to separate.
  30. iPhone XS Lightning Connector Assembly Replacement: passo 30, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 30, imagem 2 %32 iPhone XS Lightning Connector Assembly Replacement: passo 30, imagem 3 %32
    • Hold the speaker by its side edges and rock it side-to-side, separating the adhesive securing it to the bottom edge of the iPhone.
    • Pull the speaker away from the bottom edge of the iPhone until the adhesive gasket separates.
  31. iPhone XS Lightning Connector Assembly Replacement: passo 31, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 31, imagem 2 %32
    • Remove the speaker.
    • The speaker's adhesive gasket is not reusable. Peel away any remaining adhesive residue with tweezers.
    • To help protect against water and dust intrusion, replace the adhesive gasket during reassembly. Prep the area by cleaning it with a bit of isopropyl alcohol and a lint-free cloth or coffee filter so that the gasket adheres properly. Install a new gasket onto the speaker, and then install the speaker.
    Why is the speaker gasket not included or offered as required parts when you sell a battery?
    Daryl - Responder
    I thought my speaker gasket was also missing, however looking back into the part box I found it tucked under the flap at the other (unopened) side of the box. Glad I took a second (and closer) look. IFIXIT needs to do a better job securing very small parts as it is very easy for these types of parts to get jostled during shipping and then could fall out or stuck in the box unnoticed. I've purchased iFixit products for more than 10 years and am super satisfied their quality in parts and provided instructions. Hopefully they'll make some adjustments to their shipping containers as I'd love to continue using them.
    gelatofanatic - Responder
    My speaker gasket was stuck to the inside of the box also. Unfortunately it has the back peal removed and has stuck itself to the cardboard box. I tried to remove it but it was firmly attached. Bummer. This is my first iFixIt. Please package it more carefully as the other person said.
    Austin Abercrombie - Responder
    I can't find mine in the part box. Is it possible it was excluded?
    Jeff Feazell - Responder
    It might have fallen out. Search in the crevasses of the box. If you still cannot find it contact iFixit.
    Dane Elliott-Dyson -
    Update to last comment, I looked again at the listing for the battery with and without the "fix it kit". I ordered without, and apparently, the speaker gasket is part of the kit. Will need to order separately and take the phone apart again and replace the seal and battery adhesive again to install the gasket.
    It's kind of ridiculous that the gasket is ONLY included with the kit, that includes a bunch of tools that I already have too many of (yes, I've bought several screen kits...). The fact is, to properly do the repair, you require the gasket. As such, it really should be included with the battery part and not only sold with the entire kit. Most of us do not need yet a nother suction cup, more screwdrivers (ok, maybe the bits), etc. My first few orders, I bought the kit because the extra cost gave me more bits, handle, spudgers (always need more), etc. However, I didn't need any of those for this repair so I opted for only the part - the battery.
    I am so irked that I have to redo this again just because ifixit put the gasket with the kit and not the part that requires it. It's not even highlighted AT ALL that the gasket is required and not included. I'll have to find a way to bring this up to ifixit.
    Jim Shaw - Responder
  32. iPhone XS Lightning Connector Assembly Replacement, Taptic Engine Assembly: passo 32, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement, Taptic Engine Assembly: passo 32, imagem 2 %32
    • Use a spudger to disconnect the Taptic Engine flex cable by prying it straight up from its socket.
  33. iPhone XS Lightning Connector Assembly Replacement: passo 33, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 33, imagem 2 %32
    • Remove the two 1.9 mm Phillips screws securing the Taptic Engine.
  34. iPhone XS Lightning Connector Assembly Replacement: passo 34, imagem 1 %32 iPhone XS Lightning Connector Assembly Replacement: passo 34, imagem 2 %32
    • Grasp the plastic bumper strip and carefully lift it over the speaker connector.
  35. iPhone XS Lightning Connector Assembly Replacement: passo 35, imagem 1 %32
    • Remove the Taptic Engine assembly.
    Where's the rest??? Help!
    DycinLou26 - Responder
    This guide is used as a prerequisite before moving on to other components, you'll find the full list of guides here: iPhone XS
    Sandra Hiller -
Conclusão
12 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Robert K
Membro desde: 12/31/21
691 Reputação
Autoria de 2 guias
Equipe
Kid fixers Membro de Kid fixers
Community
195 Membros
Autoria de 287 guias
4Comentários do guia
Is this guide still planned? Are there any other guides which get close to the lighting connector? I have done one lighting connector before. It is the last part, which makes it a very difficult repair. I have an iPhone Xs A1920 which needs this repair. I would be interested in a collaboration.
Jayme Johnston - Responder
Where is the guide?
Bot Pro - Responder
This guide probably is still planned, however I don't currently have the time to work on it. If anyone wants to contribute to this guide, feel free to do so. If you need any resources that I have already made (eg. pictures) I would be happy to provide them.
Robert K - Responder
I just added a video from youtube to this guide, hopefully that helps till we finish the full written guide
tayola - Responder
Comentar
Visualizações:
Últimas 24 horas: 28
Últimos 7 dias: 168
Últimos 30 dias: 578
Ao todo: 11,191
