Ir para o conteúdo principal
How to Use a Heat Gun to Soften Adhesive
O que você precisa
  1. How to Use a Heat Gun to Soften Adhesive, Safety precautions: passo 1, imagem 1 %32
    • Before you begin, make sure you have a plan in the event of a fire.
    • Keep the heat gun unplugged when not in use.
    • Avoid using extension cords to power your heat gun. Since heat guns require a high current draw, cheaper extension cords may pose an additional fire risk.
    • If you're heating adhesive near or underneath a battery, make sure you've completely discharged the battery before proceeding.
  2. How to Use a Heat Gun to Soften Adhesive, Set down the device: passo 2, imagem 1 %32
    • Place the device on a clean, heat resistant surface or mat.
    • Keep flammable materials away from the work area.
  3. How to Use a Heat Gun to Soften Adhesive, Turn on the heat gun: passo 3, imagem 1 %32 How to Use a Heat Gun to Soften Adhesive, Turn on the heat gun: passo 3, imagem 2 %32 How to Use a Heat Gun to Soften Adhesive, Turn on the heat gun: passo 3, imagem 3 %32
    • Turn on the heat gun.
    • While heat guns can reach temperatures up to 1000 °F and higher, softening adhesives for electronics only requires a maximum of 200 °F. This can easily be achieved with the heat gun's low to medium-low setting.
    • Always start with the heat gun's lowest flow speed and temperature settings to avoid overheating the device you're working on.
    • If your heat gun has fine control over the temperature, keep it in the mid-to-low range. Anything higher could deform plastic or damage internal components.
    • When not in use, set the heat gun on a stable surface. The nozzle will remain hot after use.
  4. How to Use a Heat Gun to Soften Adhesive, Soften the adhesive: passo 4, imagem 1 %32 How to Use a Heat Gun to Soften Adhesive, Soften the adhesive: passo 4, imagem 2 %32 How to Use a Heat Gun to Soften Adhesive, Soften the adhesive: passo 4, imagem 3 %32
    • Position the tip of the heat gun 2–3 inches above the device.
    • The exposure time may change depending on the adhesive, temperature, and the distance between the heat gun and the device.
    • Move the heat gun along the area where the adhesive is located.
    • Always keep the heat gun in motion, and never leave it over one spot for too long—doing so could damage the device.
    • If the adhesive that needs softening is small, still keep the heat gun in motion, moving it around in little circles.
    • Some adhesives require multiple heating and prying cycles in order to loosen. Be patient to get the job done correctly and not quickly.
Conclusão
Allow the heat gun to cool down before you store it.
For other general electronics skills guides, click here.
20 outras pessoas executaram este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
214.551 Reputação
Autoria de 1.044 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.765 guias
5Comentários do guia
Thanks. You answer the question of temperature quite well, but leave open the question of duration. How long does it take to soften the glue sufficiently to remove the screen?
Chris Miller - Responder
That will depend on things like how big the screen is and how strong the adhesive is.
Chris -
Compré uno nuevo y cuando lo encendí en calor, se fundió a los 5 segundos, y seguí las instrucciones de mantenerlo lejos
Chartd - Responder
Hi Alex what is the procedure for using a hairdryer instead of a heat gun?
Julian Webster
Julian Webster - Responder
similar idea, just will take longer, start low temperatures, turn it up as needed, dont stop moving the hair dryer
Alasdair Elles -
Comentar
Visualizações:
Últimas 24 horas: 47
Últimos 7 dias: 270
Últimos 30 dias: 1,095
Ao todo: 40,599
