iPad 9 LCD Replacement
Introdução
Ir para o passo 1Use this guide to replace the liquid crystal display (LCD) in your iPad 9. Unlike newer iPads and most phones, the glass digitizer and LCD on the iPad 9 are not fused together.
Note: this guide is for the Wi-Fi version only. For the LTE version, click here.
For your safety, discharge the battery below 25% before disassembling your iPad. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage. If you choose to complete the guide without isolating the battery, avoid using metal tools except when completely necessary (like when removing screws) to prevent shorting the battery and damaging sensitive circuit components.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
O que você precisa
Peças
Ferramentas
Exibir mais…
Heat an iOpener and apply it to the left edge of the iPad for two minutes.
While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
Front camera
Antennas
Display cables
Ambient light sensors
Ferramenta utilizada neste passo:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Place an object under your iPad so it rests level between the suction cups.
Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
Wait one minute to give the adhesive a chance to release and present an opening gap.
If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
Skip the next step.
Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
Insert an opening pick into the gap between the digitizer and the frame.
Insert a second opening pick into the gap you just created.
Slide the pick towards the bottom-left corner of the iPad to separate the adhesive.
Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
Heat an iOpener and apply it to the top edge of the iPad for two minutes.
Rotate the pick around the top-left corner of the iPad to separate the adhesive.
Slide the opening pick along the top edge of the iPad, stopping just before you reach the front camera.
Heat an iOpener and apply it to the right edge of the iPad for two minutes.
Rotate the pick around the top-right corner of the iPad to separate the adhesive.
Insert a new opening pick and slide it to the middle of the iPad's right edge.
Heat an iOpener and apply it to the bottom edge of the iPad for two minutes.
Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
Leave the pick in the corner before moving to the next step.
Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
Slide the pick over the antenna, stopping just before the home button.
Leave the pick to the left of the home button before continuing.
While supporting the digitizer, slide an opening pick between the two digitizer cables to separate the last of the adhesive.
Ferramenta utilizada neste passo:Magnetic Project Mat$19.95
Use a Phillips screwdriver to remove the four 4.2 mm-long screws securing the LCD to the frame.
Remove any tape obscuring the LCD screws.
In addition to these four screws, my iPad 9th Gen LCD was glued to each of the four corners with black silicone adhesive so be careful!. A quick search brought up this handy video: https://www.youtube.com/watch?v=ATCAYY75... which was most helpful in filling in the blanks!
What purpose have the foam strip around the LCD itself. What can it be replace with if removed or missing? Share your knowledge please.
Hi there.
I believe the foam serves two functions: to buffer the LCD panel to the digitizer and to insulate the exposed copper perimeter. While I've personally seen the iPad work fine with parts of the foam missing, it's not a good idea to remove it. We don't sell the foam by itself, but you can wrap an insulator, like Kapton Tape, around the copper perimeter to prevent the frame from interfering with touch inputs.
Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the frame.
Lay the LCD down onto a clean, soft, lint-free surface to allow access to the display cables.
Use a Phillips screwdriver to remove the 2.3 mm-long screw securing the battery connector to the logic board.
Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
Leave the battery blocker in place as you work.
Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the display cable bracket.
Use the flat end of a spudger to pry up and disconnect the LCD cable press connector.
Remove the LCD completely and rest it face down on a clean, soft, lint-free surface.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 9 Answers community for help.
12 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all2Comentários do guia
I love you guys and what you do here, but this is not an iPad 9 in your photos. Although there are similarities with the 7th and 8th Gen, there are also some minor differences between those and the 9th gen. The front camera retention bracket (which is why I wanted to view this tear down. The replacement screen I was sent from a different vendor (not from ifixit, I'll clarify) as a 9th gen did not have the proper orientation of the camera retention bracket, nor the openings for the dual ambient light sensors. The adhesive cutout is also different on the 9th gen to accommodate these things) is not the same as the 7th and 8th gen. As a matter of fact, many part suppliers are selling 7th gen screens as compatible with 9th gen iPads. The connectors may be the same, but the location of the ambient light sensors as well as the camera retention bracket and home button flex hold down are NOT the same. I know for the basic repair technique they are similar, but there does seem to be some confusion in the industry about these minor (but important) differences.
Hi Chad!
Thanks for your response and feedback. Yes, you're right—the top half of the iPad 9 is quite different from previous generations. This is actually why we haven't posted any guides for the front-facing camera or other top components—we're currently writing the specific guides! This guide is specifically for replacing the LCD panel. We decided to use existing content because the procedure is the same, and the new changes shouldn't affect the LCD replacement procedure.
