Ir para o conteúdo principal
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
Function Copper Strips On Digitizer
Hi,
Recently I was repairing an iPad and I had ordered a cheaper digitizer because the oem’s were sold out. Now I noticed that on the original digitizers there is a copperish square around the screen, but on the cheap digitizer, there is not.
Could somebody explain the function of the copper strip around the screen?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The copper color looking borders on the digitizer are there to stop interference with the chassis which can result in decreased touch sensitivity if not present.
I couldn’t really tell the difference between the silver and copper style digitizers they worked pretty much the same. The copper ones I believe are either OEM or close to OEM quality and the glass is generally thicker and less brittle.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thank you for explaining!
por
Adicionar a sua resposta
Pieter será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 413
