Ir para o conteúdo principal
Game Boy Speaker Replacement
Andrew Tramposch
Andrew Tramposch e 16 outros colaboradores
Última atualização em March 28, 2022
Nenhuma estimativa
Difícil
Introdução
Ir para o passo 1
This guide explains how to replace the speaker in a first-generation Nintendo Game Boy system.
O que você precisa
Ferramentas
Exibir mais…
Vídeo de Apresentação
  1. Game Boy Speaker Replacement, Batteries: passo 1, imagem 1 %32 Game Boy Speaker Replacement, Batteries: passo 1, imagem 2 %32
    • Switch your Game Boy off and remove the cartridge.
  2. Game Boy Speaker Replacement: passo 2, imagem 1 %32 Game Boy Speaker Replacement: passo 2, imagem 2 %32 Game Boy Speaker Replacement: passo 2, imagem 3 %32
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
  3. Game Boy Speaker Replacement: passo 3, imagem 1 %32 Game Boy Speaker Replacement: passo 3, imagem 2 %32
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
  4. Game Boy Speaker Replacement, Outer Case: passo 4, imagem 1 %32
    • Remove the six Triwing screws from the back of the device.
    The Game Boy uses Y1 screws for the outer case
    Rumia1 - Responder
  5. Game Boy Speaker Replacement: passo 5, imagem 1 %32
    • Gently separate the device's front casing from the back casing after you remove the screws.
    • Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
  6. Game Boy Speaker Replacement: passo 6, imagem 1 %32
    • Slide the front side of the casing down to expose the ribbon cable connector.
  7. Game Boy Speaker Replacement: passo 7, imagem 1 %32
    • Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
    • Separate the front and back casings.
  8. Game Boy Speaker Replacement, Speaker: passo 8, imagem 1 %32
    • Remove the 10 Phillips #00 screws from the motherboard.
  9. Game Boy Speaker Replacement: passo 9, imagem 1 %32 Game Boy Speaker Replacement: passo 9, imagem 2 %32
    • Use a plastic opening tool to gently lift the motherboard up and remove it from the front plastic case.
    • Use caution when lifting the board since the speaker is attached.
  10. Game Boy Speaker Replacement: passo 10, imagem 1 %32 Game Boy Speaker Replacement: passo 10, imagem 2 %32 Game Boy Speaker Replacement: passo 10, imagem 3 %32
    • Desolder the two wires connecting the speaker to the motherboard.
    • Remove the speaker.
    • If you're new to soldering, refer to this guide for tips that will help with desoldering the speaker wires and/or soldering the new ones in place.
Conclusão
16 outras pessoas executaram este guia.
Andrew Tramposch
Membro desde: 06/24/10
2.258 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 3-2, Johann Summer 2010 Membro de Cal Poly, Team 3-2, Johann Summer 2010
CPSU-JOHANN-R10S3G2
3 Membros
Autoria de 35 guias
2Comentários do guia
This is just a guide to remove the speaker not replacing it so change the title as it is misleading as people that following this will want know how to replace not remove only
Paul - Responder
As stated in the conclusion, you simply follow the steps in reverse to install your replacement speaker.
Jeff Suovanen -
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 36
Últimos 30 dias: 220
Ao todo: 34,775
