Game Boy Speaker Replacement
Introdução
Ir para o passo 1This guide explains how to replace the speaker in a first-generation Nintendo Game Boy system.
O que você precisa
Ferramentas
Exibir mais…
Vídeo de Apresentação
Remove the six Triwing screws from the back of the device.
16 outras pessoas executaram este guia.
2Comentários do guia
This is just a guide to remove the speaker not replacing it so change the title as it is misleading as people that following this will want know how to replace not remove only
As stated in the conclusion, you simply follow the steps in reverse to install your replacement speaker.
