Ir para o conteúdo principal
iPhone 8 LCD and Digitizer Replacement
Arthur Shi
Arthur Shi e 5 outros colaboradores
Última atualização em 14 de mai de 2025
45 minutos - 2 horas
Moderado
Introdução
Ir para o passo 1
For an easier repair, use our fix kit and follow this shorter guide to replace your iPhone’s entire screen.
For more advanced fixers, this guide will help you replace only the iPhone 8 LCD and digitizer assembly (a.k.a. the bare “front panel”). This requires you to transfer several components from your original screen to the new one before installing it—including the front-facing camera, earpiece speaker, LCD shield plate, and home button assembly.
For all screen/display repairs, it's important to carefully transfer the original home/Touch ID sensor onto the new display in order for it to function. The solid-state home button is paired to its original logic board by Apple, so replacing it will render it unusable.
Note: If your iPhone’s auto brightness feature does not work properly after your screen repair, make sure your iPhone is updated to iOS 12. True Tone functionality is disabled after a screen replacement, even when using an original Apple screen.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. iPhone 8 LCD and Digitizer Replacement, Remove the pentalobe screws: passo 1, imagem 1 %32
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    just how long are those screws- i turn and turn and turn and the lift off is soooo slight, seemingly insignificant…
    An. Jahnke - Responder
    I would recommend, from the very beginning, dumping all tools out of the kit (if you got it) and using that white paper tool box as a tray to organize the screws and braces in. It’s nice to work over because it catches screws well and makes it easy to see them if you drop any.
    Johnny Emrica - Responder
    That’s a great idea thank you
    Mohamed Dekkiche -
    Screw to the left of the charging port will not come out. Screw on the right came out no problem. Any ideas?
    Bill Maher - Responder
    Maybe the screw is stripped…
    Gabriel-Science -
    I already replaced my iPhone 8 battery with one from iFixit and honestly I wasn't impressed. It worked well for a few months, but then I started noticing the peak performance capability dropping significantly thereafter. I followed the initial charging instructions to a tee and only let it drop below 20% once a month. Normal everyday use for me... no intense apps like games, etc. I considered having Apple do it this time around, but for these older models they don't keep the batteries in-stock and you have to give them your phone for up to a week. So in the end, I opted to try another battery from iFixit instead. Hopefully this one will last longer.
    tripmusic - Responder
    Does it lasted longer ?
    Gabriel-Science -
    How with the gigantic kit do I not have a 3 1/2 pentalobe driver the very first screwdriver I reach for and that I need is not in any of these kits. What’s up with that?
    Michael Stephens - Responder
    Same problem. The kit comes with a screw driver, but not for this pentalobe screw. This is a problem.
    Yuji Ishitsuka - Responder
    I had to search what screwdriver bit I had to use from the ifixit toolkit; it's the P2 bit. (Maybe it's more obvious if you bought the battery kit, because it only has one type of pentalobe screwdriver.)
    Nathaniel Zielstra - Responder
    Definitely P2 bit
    Megolina - Responder
    I drained my battery completely before I did this thinking it might help prevent a fire if I accidentally puntured it. I don't know if that is the case... but figured it couldn't hurt.
  2. iPhone 8 LCD and Digitizer Replacement, Mark your opening picks: passo 2, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement, Mark your opening picks: passo 2, imagem 2 %32 iPhone 8 LCD and Digitizer Replacement, Mark your opening picks: passo 2, imagem 3 %32
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 8 LCD and Digitizer Replacement, Tape over the display: passo 3, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement, Tape over the display: passo 3, imagem 2 %32 iPhone 8 LCD and Digitizer Replacement, Tape over the display: passo 3, imagem 3 %32
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
    In case of broken glass you can make the suction cup much more effective by covering the glass with a broad piece of translucent tape which eliminate air leakage through cracks in the glass.
    lionno1 - Responder
    Il n’est pas nécessaire de mettre beaucoup de scotch.
    Au contraire plus vous mettez de scotch, plus il y aura de défauts et la ventouse ne collera pas.
    Une bande bien positionnée suffit.
    Chloé Bossuette - Responder
    I’ve used hot glue on low setting to remove all types of crystals. The hot glue will release with a little iso alcohol. No damage to glass or plastic faced crystals or screens. Use a narrow piece of wood as a prying handle.
    Emilio Gonzalez - Responder
    I recently had issues with removing the glass with the suction cup. I have done this many times with older generation iPhones but this time the glass seemed sealed on quite solidly. I told myself that the last option would be to use the screwdriver tip. After all my attempts, I transitioned to the option of using the screwdriver tip. Surprisingly, it was the easiest thing ever. I placed the 1mm flathead screwdriver at the interface between the glass and the cover (normal start location) and pried up very gently. Voila, the glass came up and I can’t even notice any dents or scratches. It felt much easier than the suction cup technique. If the suction cup is giving you a hard time consider using that 1mm flathead.
    forhereyesonly - Responder
    This is definetly the best option to open this thing up. I’ve spend 30min with trying to heat it up and remove it using the suction cup. I needed 3sec with the 1mm flat screwdriver and i t was’nt scary at all. No dents nor scratches here too. Thanks for your comment.
    Berggorilla -
    thank you!!!!!
    Adrian Phan -
    Great suggestion to use the screwdriver!! Thanks, it really helped
    obo12759 - Responder
    Duck Tape worked great for me. Thanks for the great instruction!
    Michael - Responder
    Tried several types of tape but finally used this screw driver solution. At first I wasn't pushing hard enough for fear of damaging things but with just a bit of extra force I was able to open it right up. Everything is fine with only a slight scratch on the frame.
    Wesley Shank - Responder
  4. iPhone 8 LCD and Digitizer Replacement, Anti-Clamp instructions: passo 4, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement, Anti-Clamp instructions: passo 4, imagem 2 %32 iPhone 8 LCD and Digitizer Replacement, Anti-Clamp instructions: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 8 LCD and Digitizer Replacement: passo 5, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 5, imagem 2 %32 iPhone 8 LCD and Digitizer Replacement: passo 5, imagem 3 %32
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 8 LCD and Digitizer Replacement: passo 6, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 6, imagem 2 %32
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    it looks like a....
    Gergely Soki - Responder
  7. iPhone 8 LCD and Digitizer Replacement, Heat the display: passo 7, imagem 1 %32
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
    No hair dryer so GENTLY heated over stove burner
    John Toth - Responder
    Hello,
    What temperature is suitable for removing the front display ? I bought i-Fixit ProTech which is not include the heating "roller" . Thanks for help
    Jiří Sítko - Responder
    I was about to ask the same Question...
    Enno Winch -
    Ich habe eine heiße Wärmflasche verwendet. Das hat gut funktioniert :-)
    Moritz Hartges - Responder
    I laid my phone face-down on my 3D printer’s heated bed, and set the temperature to 60 C. After a few minutes, it was ready to loosen.
    Nate B - Responder
    Hey, that's smart !
    Gabriel-Science -
    If you don’t have an “iOpener” or heat gun, try using an electric heating pad. I have a small $11 pad I got at CVS for my knee. On medium heat it worked fine for removal and with the “pennies” for setting the new seal.
    Pete P - Responder
    I used a heated tea kettle and a tea towel, it worked!
    Adam Yavner - Responder
    I put on the furnace vent for 10 minutes to get it warm to the touch but not hot.
    terrelldoc - Responder
    I attached it to the after burner of my rocket ship and that worked.
    Matt Brown - Responder
    I'm holding mine just above an erupting volcano but I'm still waiting to see if it has worked. How long does it need?
    Paul Aron - Responder
    It won't work if you don't throw it in the lava.
    Gabriel-Science -
    I used a water-filled ziploc bag, heated it in microwave. fast, cheap, worked.
    John Barker - Responder
    Hairdryer works fine for this step. No issues.
    Agree! Just did it for 2 times to make sure I didn't overheat the phone.
    André Lopes -
    The most effective way to heat up the glue is to leave the phone in full sun - if it's available. In fact I would always wait for a sunny day to repair any glued together Apple device. The heat will be very even and the phone was probably designed to survive anything the sun can throw at it - although it can get very warm. (I'm in the UK) If you leave the phone turned on it will give a warning if it goes near the temperature limit.
    John - Responder
    I'm sorry but I tried both the hair dryer (for 3 minutes!) and the eye opener (also 3 minutes) and no luck. Not even a hint of loosening the adhesive holding down the display!! Do I send this kit back for a refund or what??!!
    John Noble - Responder
    No luck, guys. 3 minutes of hair drying and 3 minutes heating up the iopener. What next?
    Okay, a half hour later i finally got the screen loose, but not after super heating it for at leat 10 minutes with a hair drying and burning my hand trying to pry it open. Also, watch out for the power button because it inadvertently keeps switching the phone back on while you wrestle with it. More later . . .
    . . . and now I need to buy a new phone!!! the cable broke as I was trying to unscrew one of the top screws, so thanks! I FIXed IT but Good!!!!
    Nate B's advice was key. I couldn't get the temperature of the display hot enough to break the seal with a hair dryer. A heat gun set to low speed and 550F (287C) got the display up to just over 130F, close to the 60C Nate mentioned.
    Matt C - Responder
    This part was actually much easier than I thought. I used a hair dryer on max for 2 minutes on each side of the phone, less than half an inch away from the phone, just on the bottom half. It was hot! Screen came right out!
    Nuno Lopes - Responder
    I used a tube sock full of about 1 cup of white rice. Tied a knot in the top of the sock. Put the sock of rice in the microwave on 60% power for 1 minute. Kept doing this until the temp felt right. Put the sock of rice down, put bottom edge on sock, then covered w/ other half of the sock/rice. Put a piece of paper towel between phone and sock/rice to absorb any moisture. When lifting up on front panel, I rested the phone on the sock/rice. Worked nicely once I got the temp of the rice high enough.
    (threw the rice away later :-) )
    Burning Sensation - Responder
    “Threw the rice away later” has to be the best advice here. I wrapped my phone in a small heating pad and turned it up to 6 of 8. Worked great in 5 min or less! No need for water bottles, microwaves, heat guns, volcanoes, …. I kept the heating pad later ; )
    dantegd - Responder
    I popped my iPhone under a desk lamp with a 60w filament light bulb in it, switched it on, (See this photo) then read the iFixIt instructions and comments. By the time I’d done that, the glue had softened enough to start work. I managed to do the whole process, slowly and methodically, without incident. The iPhone even worked after I’d put it all back together. So we’ll done iFixIt. Another satisfied customer!
    Tony Houlihan - Responder
  8. iPhone 8 LCD and Digitizer Replacement, Separate the display: passo 8, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement, Separate the display: passo 8, imagem 2 %32
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Even with using high heat from a blow dryer, I had to put the suction cup over the home button or the bottom edge wouldn’t lift at all. That waterproof adhesive is incredibly strong.
    Aaron Soderholm - Responder
    As others have said, this part really stinks, but it’ll work if you keep trying. Agree with multiple rounds of hair dryer on high (did about 60-90s each time), and with having to out the suction cup over the home button. You don’t need a big gap to pry it open - it’ll be slight …
    Patience is the key here. Expletives and patience. Like previous comments say, putting the suction cup over the home button (I used packing tape to maintain the seal) will allow you to apply force to the proper location to separate the screen. Good luck!
    J Rawlinson - Responder
    Get a suction cup pliers. It’ll make this part fun
    Bradley Steiner - Responder
    iSclack EVO opened the iPhone easily even without heating with no fear of accidentally over-opening it like with a simple suction cup.
    Matti Haveri - Responder
    If you don't have the anti-clamp device, to prevent the screen from tearing open when suctioning it, I suggest some layers of tape around it and the back of the phone (the tape has to be stretchy enough to just minimise the momentum when separating the screen), or some big rubberbands
    Raziocinjo - Responder
    This was the time consuming part. I’d recommend having a thin bladed knife or similar to get things going. I used the small blade on my Swiss Army knife, but be careful. When it goes, it can be unexpectedly sudden. I also used a strong rubber band to stop any excessive opening of the screen.
    This was easier than I thought it would be. I used the suction cup that came with the kit and put the edge of it below the home button so the home button was inside of the suction cup. There was just enough room for it so it had full contact with screen. I didn't have packing tape and turns out I didn't need it.
  9. iPhone 8 LCD and Digitizer Replacement: passo 9, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 9, imagem 2 %32 iPhone 8 LCD and Digitizer Replacement: passo 9, imagem 3 %32
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    The screen on my phone was so broken, a suction cup did not work, so I softened the adhesive with a blow dryer and used a Jimmy to carefully pry open the phone from the bottom just enough to slip a pick in.
    charguy - Responder
    Just completed a smashed screen replacement, this is probably the most time consuming part. Used packing tape to cover the screen to help create a suction surface (had to replace it a couple times because it pulls away after a purple good pulls ) Used consistent heat for about 5 minutes, then stuck a pick in the tiniest opening… and pry pry pry!
    Brian Gill - Responder
    I failed at this step. No amount of heating, pulling, and rocking opened up enough of a gap to slip in even a knife let alone the blue plastic tool. That's with a phone that has an undamaged screen - just trying to replace the battery. Apple won this round :(
    Michael Sherman - Responder
    Be really careful here. I placed a sucker to the front and rear to help lever off the screen. However, the whole thing came away much easier than I anticipated and I ripped the front part completely away from the rear, tearing all three connector cables. New iPhone required.
    Chris Wood - Responder
    Note that the opening pick they show here does not appear to come with the kit, which is a bummer! The plunger, the mini blue crowbar thing, these are too thick. I ended up using a really thin guitar pick.
    Following careful methods can mostly preserve the seal and reusable. Won’t be as water tight but probably still pretty good.
    Bottom edge is pull up with suction + separating tool. Use small precision scissor to cut any tape that gets overly stretched upon initial opening.
    - For the 2 long edges, use an exacto knife to separate the seal from the screen. This keeps the tape on the chassis. Go slow along the long sides. Becareful to avoid scratching the paint on underside of the screen’s edge.
    - Top corners have a thick sealed tape. Best to just use separating tool to twist it open.
    In summary, top and bottom edge use separating tool. Side long edges can use exacto knife to gradually gently separate the seal from underside of the screen’s edge.
    Howard - Responder
    4 picks and an exacto knife, plus 45 minutes later, I finally got it to open! Thanks tor the tip!
    Cat - Responder
    Intact screen, check. Tool kit, check. Hair dryer hot enough to make the phone too hot to touch, check. Following all instructions, check. Screen still in place and refusing to come off, check.
    I heated, reheated, pulled and pulled. I simply could not get it off. Worked at it for an hour and a half, and I’m not a small guy. Yes it is hard to hold, but could get a grip. Just could not get it to budge. Off to the iPhone repair shop tomorrow. Anybody want to buy a repair kit and replacement battery?
    Jim Meyers - Responder
    After struggling for 30m, I looked up some alternate methods and found this helpful:
    https://www.youtube.com/watch?v=25zAK5mG...
    - I used a utility knife and pried up right under the home button
    - the angle matters! I was trying to go too far down before going in. The top surface of the phone is rather thin, so you go in after barely getting under the chassis lip
    - tilt utility knife left to right once you’ve got it under to work it in
    - leave the utility knife in, and now add that pick
    Jared Wilk - Responder
    Pro-tip: don't be an idiot like me. Instead, remove the screen protector you have on the phone before applying the suction cups. Derp.
    hunter.geofizz - Responder
    I struggled with a hair dryer at first and a singular suction cup. However, I tried putting packing tape on the spot where I put the suction job (even though my screen isn't cracked) and I was able to do it first try with ease. Definitely recommend packing tape.
    Alessio Toniolo - Responder
    Suction cup pliers. Dead easy
    After successful screen replacement, returning to give my thanks here. Excellent tips from you all - if you’re using force, you’re doing it wrong. Heat, very very gentle exact-o knife barely down then fully under the screen below the home button … perfect. Slow and patient around the upper corners, and don’t forget to heat there as well! Thank you all!
    dantegd - Responder
    The problems with this step are (1) not having three hands and (2) managing to hold the phone in a way that doesn't put reverse pressure somewhere else on the screen. Exacto knife was the best tip. It's a little dangerous. On a misstep you may scratch the screen or jab yourself, but it's what got me in.
    thewrytstf - Responder
    sorry, could not lift off the display any nano-meter even after applying enough force I think and heating it up. need to visit a store.
    Andi Tony - Responder
    I used a razor blade and plenty of heat, and it somehow worked like a charm at the cost of me cutting myself. Definitely be careful when doing this, I used the razor blade on the left side of the iphone then wedged in a small screwdriver and then used the pick to cut the rest of the material away.
    Sharaf Kazi - Responder
    I used an electrician's heat gun for 90 seconds. Worked well. You don't have to pull up on the suction cup very much AT ALL. I bought a special, thin, Jerry Rig Everything metal spudger off Amazon. It easily made the first cut and then I used the blue plastic triangles with the 3mm marks to score around the rest of the edges. I did this in the exact order of the instructions and it worked well. Careful, slow and patient wins the day here. Careful at the top. Don't just lift up on the screen, definitely push the screen down toward home button as there are a couple of clips holding the screen to the body at the top of phone.
  10. iPhone 8 LCD and Digitizer Replacement: passo 10, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 10, imagem 2 %32 iPhone 8 LCD and Digitizer Replacement: passo 10, imagem 3 %32
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
    My Plektrum worked ok, but the edges broke off a bit towards the end
    griffin.weber - Responder
  11. iPhone 8 LCD and Digitizer Replacement, Screen information: passo 11, imagem 1 %32
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    I was trying to replace my battery, and accidentally cut one of the cords on my screen. I marked my pick, so i don't know how it happened.
    Gib Jeffries - Responder
  12. iPhone 8 LCD and Digitizer Replacement: passo 12, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 12, imagem 2 %32 iPhone 8 LCD and Digitizer Replacement: passo 12, imagem 3 %32
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    No pick in the kit you sent me.
    Ted Cooper - Responder
  13. iPhone 8 LCD and Digitizer Replacement: passo 13, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 13, imagem 2 %32
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
    There was no "small nub" but a fingernail popped the suction cup off easily.
  14. iPhone 8 LCD and Digitizer Replacement: passo 14, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 14, imagem 2 %32 iPhone 8 LCD and Digitizer Replacement: passo 14, imagem 3 %32
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
    I did end up using just a smidge of IFIXIT adhesive remover along the edge before opening and that seemed to really help
    Karen Flowers - Responder
    I have been using the pointed tweezers to pull the adhesive strands apart and out as the display comes off.
    This bit was awkward as to get a good grip I kept inadvertently switching the %#*@ phone on!
    wendyhoward - Responder
  15. iPhone 8 LCD and Digitizer Replacement: passo 15, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 15, imagem 2 %32
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
    I had trouble sliding down the display and found I hadn't separated the stop enough.
    Jeffrey Anderson - Responder
    When you are pulling the display downward, be very careful! I pulled a little too hard and the display cables tore from the downward (toward home button) motion. Now I have to replace the display! 😭
    So Munch Love - Responder
  16. iPhone 8 LCD and Digitizer Replacement: passo 16, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 16, imagem 2 %32 iPhone 8 LCD and Digitizer Replacement: passo 16, imagem 3 %32
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Nach RECHTS klappen - nicht nach links!
    Manfred Wachtel - Responder
    Als ich das Flachbandkabel auf der rechten Seite sah, hab ich mich auch gefragt, ob die das mit nach Links klappen ernst meinen, und das „Buch“ lieber auf japanische Art nach rechts aufgeklappt. Das sollte dringend in der Anleitung korrigiert werden!
    Sebastian Plickert - Responder
    “Up from the left” means lift up the left side.
    Which is the same as folding to the right.
    “Like the back cover of a book” explains it even more clearly.
    Maybe it gets lost in translation?
    Nick Shtangey -
    Fold to THE RIGHT - not to the left!
    Jim Glenys - Responder
    When I saw the ribbon cable on the right side, I also wondered if they were serious about folding it to the left, and the "book" would rather be opened to the right in the Japanese way.This should be corrected urgently in the manual!
    Hi Jim, the display opens from the left side, toward the right side. It should look like the back cover of a book. Hope this helps. Good luck with the repair!
    Adam O'Camb -
    DO NOT LAY THE TWO HALVES FLAT!!! There is a reason why the third photo shows the screen half leaning against a box! This really needs to be a warning in addition to the one about not separating the display.
    Mangled Jargon - Responder
    If you're skipping the screen and taptic engine removal like I did, I suggest you tape the back of the phone to the table, and also tape the screen to the vertical object it lays on, so it stays still. That way you will avoid having to constantly readjust it because of the sliding of the housing of the phone when you're working on it. Be careful where you're putting the tape on the screen though, if you're doing it on the internal components.
  17. iPhone 8 LCD and Digitizer Replacement, Disconnect the battery: passo 17, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement, Disconnect the battery: passo 17, imagem 2 %32
    Magnetic Project Mat
    $19.95
    • Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • Two 2.8 mm screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
    • Remove the bracket.
    Not Y000 this time haha
    Easy Repair - Responder
    can same length screws mixed up?
    Brook布魯克 - Responder
    It is not ideal, but possible for these screws.
    Arthur Shi -
    using the repair kit i purchased with my screen replacement, i am currently having issues removing these screws with the PH000. please help
    Mark Ordaz - Responder
    I was too, thankfully I had another set that contained the PH00 bit, that worked great for me.
    William Mitchell -
    Ok. My screw is stuck. How do I remove it? Philips head is stripped.
    Kristina Graham - Responder
    Solved it myself. Firm pressure did the trick.
    Kristina Graham -
    Takes a little pressure with the Philips head
    Upon this step, I noticed I had no bracket or screws. I had my screen replaced previously and I’m disappointed to find out the repairperson made no effort to replace these parts. I’ll start trusting myself more to do my own repairs.
    O D - Responder
    took me awhile to figure out I needed to use PHOO bit for the 2 -1.3 screws
    It is important to keep careful track of the screws' position. Have a tidy workplace -- a few times when I tried to re-attach the very tiny screws with the tweezer, they slipped and flew away and I almost lost them.
    can you strip the screws / how can you tell if its strip or not
    antonio - Responder
    I was lucky enough to do this on a ship where the electrical shop has a jeweler's mirror! I would have had to get more magnified readers if I had tried this on shore... Also, I used plastic containers with lids to separate each group of screws and their corresponding brackets, putting a little note inside each.
  18. iPhone 8 LCD and Digitizer Replacement: passo 18, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 18, imagem 2 %32
    • Use the point of a spudger to pry the battery connector out of its socket in the logic board.
    • Bend the battery connector cable slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    Make sure you pry the battery connector off from the right hand side as shown in the picture. Theres a delicate component on the logicboard near the battery connector called a Mosfet which is linked to the battery charging software. If you knock it off accidently you’ll loose battery charging and the phone will boot loop and youll need to have it re-soldered back on.
    Gareth - Responder
    I can confirm this as I learned my lesson by unknowingly prying the mosfet off. The phone will not charge now and is useless. I really wish they would add a note about this on Step 12 as a warning.
    Jeff -
    So this is it. You don’t have to go any further removing the screen. You can replace the battery right from this point.
    John M - Responder
    I wish I saw this comment 2 hours ago
    Kenneth Moore -
    If I have to repeat this, I'd also consider removing replacing the battery at this point. The loose display must be then carefully fixed so the connectors don't break. And then it is not possible to re-attach the waterproof seal.
    The waterproof seal was included in the kit, but there were no instructions for it so I now skipped that. I later found YouTube video which seems to describe it (starting at 7:40):
    https://www.youtube.com/watch?v=RcgGRhaX...
    Matti Haveri -
    This is where I broke my phone, a phone that was working quite well, paid for in full. Just because I had a cracked screen. Be super careful when connecting the cables. I was in a hurry and not paying attention, used too much force when re-connecting and broke those teeny little pins that could not be repaired. A tech tried for an hour to no avail. cautionary tale. Good luck
    The display ribbon is a certain length and allows for some give, but behind it is hidden the Home button/TouchID ribbon, which sits against what amounts to a razor blade. This ribbon is much more taut than the display one, and therefore you have far less freedom of movement than you think you do. This is absolutely an intentional trap to discourage replacing your own battery. Quite frankly, it’s despicable.
    Anyway, so beware of that, because although I was very careful and did not even swing the screen very far (not more than 90°), the Home button ribbon tore and now needs to be serviced. Home button is disabled now.
    Apple should be ashamed of themselves for this. Please do look at the legislation effort that people are doing to try to get this kind of sabotage illegal, as well as all sorts of other gimmicks they pull. For a company that makes phenomenal products, they’re controlling like an abusive spouse.
    Dan Knight
    daniel - Responder
    That happened to me and I could not figure out how it got broken. It's the home button and fingerprint reader.
    But I'm not bothering to get it fixed and I'm not replacing the entire screen. I went into system prefs/accessibility and activated the on-screen home button. Oh, well.
    Mangled Jargon -
    I cannot get the new battery reconnected to the connection port. Any tips/tricks? New and old battery connections appear similar. It wasn't difficult to disconnect to old battery.
    Robert Ast - Responder
    Some reports here seem to indicate that the battery must be the very last connector to re-connect because otherwise there might be malfunction in some display components?
    It wasn't difficult to disconnect to old battery. But the most difficult part for me was to get the new battery reconnected to the connection port. I tried many times to carefully position and press it down with my fingertip or the flat end of the spudger but it did not hold its position. Maybe I pressed too weak because I was afraid breaking the connector and the mosfet above (?) it. But finally to my surprise it connected (at that point I temporarily booted the iPhone with the loose display to verify that the battery was connected). Whew, it succeeded!
    The connectors have very little "click" to them when they do seat properly, and are covered with soft foam. Very challenging to attach them by feel, and having the screen propped up, blocks light from exactly where you need it.
    Steve Trotman - Responder
    Make sure the new battery connector cable has similar length and width to the one of the original battery. I got a third party battery and the cable was longer and not folded in a "U" way near the connector, like the one in the genuine battery was, only folded at a 90 degree angle. That "U" actually perfectly fits in the small space between battery and connector port, so the cable doesn't stick up thus making connecting it or closing the screen impossible. So fold the cable, connect it, and while holding it to prevent it from disconnecting, stick the battery so the "U" curve of the cable sits down just between battery and connector port.
    Reconnecting this after I replaced the battery was the hardest part that took the most care and patience. The connector is attached to the battery itself and it had to be bent/folded in exactly the right angle to fit into its mate.
  19. iPhone 8 LCD and Digitizer Replacement, Disconnect the display and digitizer: passo 19, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement, Disconnect the display and digitizer: passo 19, imagem 2 %32
    • Use the point of a spudger to pry the lower display connector out of its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    I broke the lower display connector. Is it possible to replace that part separately or do I need to buy a full screen replacement?
    Ross Mckellar - Responder
    You need to buy a new screen
    conrad veldhouse -
    이렇게 친절하게 정성스럽게 분해도 올리신 분은 처음이네요 진정 프로/ 기타 나머지 잡것들은 대충 올려 돈이나 벌어보자는 업자num들/ 배터리 교체하는 유툽 영상보다...업자가 올린 ...배터리 교체는 따라했으나 그후 배터리 교체와는 전혀 상관 없는 액정 뒤판을 jo빤다고 설명도 없이 뜯어 그것까지 따라하다 액정이 나가버려 지금 무주공산에서 홀로 검색하다 이걸 보게됨
    평생놀아난다 - Responder
    The tip about how to re-attach press connectors without damaging them should really be at the last press connector step since we're following the steps in reverse order to reassemble.
    mike eng - Responder
  20. iPhone 8 LCD and Digitizer Replacement: passo 20, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 20, imagem 2 %32
    • Use the point of a spudger to disconnect the second lower display cable.
  21. iPhone 8 LCD and Digitizer Replacement: passo 21, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 21, imagem 2 %32
    • Remove the three 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
    If you are replacing the adhesive liner, the remaining release liner strips will interfere with the two outer screws. I had to cut a working section out of the liner at each location and move it aside with the spudger.
    Thomas Tritt - Responder
    This part is throwing me for a loop. Having difficulty finding the read head for these screws. Is it the same size as the two small 1.3mm screws in step 12?
    Jared Hensley - Responder
    These are the same size screws mentioned in Step 17.
    Douglas Walker -
    ended up getting it with the PH000, I must of just been rushing it.
    My bracket looks different and none of the screw heads I have fits.
    Ray Rushing - Responder
    Mine too? Any help?
    George Waller -
    These screws did not stick to the magnetic screwdriver. Extremely difficult to get them back in place - but with some patience i succeeded :)
    Niklas Brammer - Responder
  22. iPhone 8 LCD and Digitizer Replacement: passo 22, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 22, imagem 2 %32
    • Use the point of a spudger to disconnect the front panel sensor assembly connector.
    Do you have a link for the flex cord shown in the pictures so I can purchase it? Having a hard time locating that exact assembly
    Regal Carveiro - Responder
    It’s of a piece with the front camera.
    xint - Responder
    ここの、マザーボード側のピンが数本なくなっていた場合
    交換するには、どの部品名で探せば良いですか?
    ren12o7.2011 - Responder
  23. iPhone 8 LCD and Digitizer Replacement, Remove the display assembly: passo 23, imagem 1 %32
    Hi ifixit, if you find my method dangerous, please remove it.
    After Step 17, I skipped Step 18 to Step 28.
    At Step 29, I lifted up the four adhesive black pull-tabs to expose the white adhesive side. Next, I use hot air gun and blow on the back cover of the iphone for about a minute (maybe a hairdryer will work too) .
    Warning: Don't overheat the iPhone, or you may accidentally ignite the battery.
    I think the temperature was around 60 DegC.
    Extreme Caution: Do Not overheat. I use my hand to gauge the hotness. Careful not to burn yourself or the board.
    I was able to pull out all the white adhesive tapes easily as the adhesive soften.
    DO NOT TRY this method if you are a novice or inexperience! I am not responsible if you hurt yourself or damage your iphone!
    John - Responder
    Hey John! I’m glad the repair worked out for you!
    From our research, applying heat does soften the adhesive strips, but it also causes them to lose structural integrity and break more easily. That’s why we normally suggest using heat after the strips are already broken. Removing the Taptic Engine definitely takes a few extra steps, but we feel that it gives fixers the best chance of pulling out the adhesive strips intact.
    Arthur Shi -
    I agree with John, skip 18 through 27. These are to make it easier to remove the battery adhesive. I replaced the batteries on two IPhone 8s. The first one I did all that stuff and the adhesive still broken and I had to carefully pry the battery out anyway. When I reassembled the phone the Home button no longer worked. Looking it up, this is apparently fairly common due to all the fragile wires involved in these steps. The second I skipped these steps and when I reassembled it everything worked fine. Not one of the eight (both phones) adhesive strips came out properly. I fully drained the batteries before doing the repairs. By the way, I use the virtual home button on the one phone, it’s a little annoying, but the phone is still usable if you’re not ready to shell out for a new phone.
    Gary Berman -
    I also skipped removing the Taptic Engine. I could only half-way pull the lower battery tapes and completely the upper tapes after carefully prying them loose with the tweezer. I then used a hair-dryer for a minute to warm the battery and the other side of the phone (I used my other hand to make sure I did not apply too much heat. Make sure you do not blow the tiny loose screws away with the hair dryer!) and then slowly lifted the upper battery somewhat with the Opening pics tool, then re-heated the lower remaining tapes and quite easily lifted the battery out.
    I had bought two-sided tape to reconnect the battery but it had the tapes pre-installed (I wonder if it is necessary to tape the battery at all?).
    Matti Haveri -
    I also skipped these steps. I won’t say it was entirely successful - two of the four adhesive strips broke and could not be grabbed with tweezers. But I had gotten most of the adhesive out already and the battery was quite loose, so I used a warmer under the phone, then gently slid a flat plastic blade under one end of the battery and slowly worked it up the phone. (Dental floss would have been safer-don’t do what I did, kids!)
    Matt D - Responder
    Likely can skip step 18-28 and all the risks. Battery tape is relatively removable by the following method
    - use a tweezer to pull up a corner of each tape. Then use fingers to peel back all the black tab on top of battery
    - use 2 hands. Index and thumb on both. Pull about 1/4” with one hand, hold the tension and pull 1/4” with the other hand. Alternate, go slow. Pull out all 4 tape completely. I think the pause after each 1/4” while holding the stretched tape firmly prevents the tape from over stretching to become too thin and break.
    - Don’t apply heat, I would guess that makes tape softer and break easier.
    Have tried other methods and failed in the past. Pulling too fast (tape will snap) or use a tweezer to twist/roll (sharp edges will cut tape) Anyway, just use index/thumb on both hands and alternately pull slowly
    I did do 2 iPhone 8 battery change this way. One removed all tape without breaking. Another broken all 4 tape after about 1/3 pulled so likely some factory assembly differeces.
    Howard - Responder
    I second this, this method works well in most cases. Removing the haptics helps to keep the angle low and pulling the tape as straight as possible
    Hein Blöd -
    Howards method for removing the adhesive works like a charm. The only addition I made was to slightly warm the back of the iphone on a rice pack (used for sore neck muscles—haha). Going back and forth between hands is really crucial. While on hand gives a gentle pull, the other holds the phone from moving. Slow back and forth. Thanks.
    Lynn Thomas - Responder
    Struggling with the glued down display, then properly cleaning all the remains of the old seal, then positioning the new seal is 95% of this job. I purchased my phone refurbished and it clearly had already been serviced once, there were remnants of an old seal below the current seal due to improper cleaning and prep that made getting the phone open harder than it needed to be.
    For my 2nd iPhone 8 battery replacement, I chose not to remove the display completely, or the Taptic Engine and I was successful. You have to pay extra attention and it is a bit trickier to keep the display from moving around too much, but I think minimizing the amount of screws and connections to take out, the better. You can easily lose the screws and you have to mind which ones go where, as there are so many different lengths. YMMV.
    In retrospect, I also would have skipped ahead to step 33. I didn't, but my efforts at removing the adhesive tape were also unsuccessful so steps 23-33 were for naught. Ended up applying isopropyl alcohol, then warming the back, and finally just physically levered the battery out. Battery was slightly deformed and became slightly warm, so as soon as I got it out I just put it outside on a brick.
    But the replacement worked.
    Peter Benson - Responder
  24. iPhone 8 LCD and Digitizer Replacement, Remove the home/Touch ID sensor bracket: passo 24, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement, Remove the home/Touch ID sensor bracket: passo 24, imagem 2 %32
    • Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
    • One 1.2 mm screw
    • Remove this screw first. Excess pressure may bend the home button bracket if you remove the 1.3mm screws first.
    • Three 1.3 mm screws
    • During reassembly, be careful not to overtighten these screws, or your home button may not work.
    Bei meinem iPhone waren das Y00 Schrauben, nicht Y000
    Andreas Veeser - Responder
    If the screw on the home button is broken, you can bend the metal sides upwards and pull down out of the phone and push and refold into the new display. Example: https://www.youtube.com/watch?v=DTCQA-jn...
    Andy Knapp - Responder
    Andy Knapp - wherever you are - you saved me. NOTE: the iphone 8 has four tri-wing screws - that means you need a tri-wing screwdriver. I ordered an entire replacement set and mine had one in there, but it does not mention anything about tri-wing in these instructions… so. Hope that helps someone.
    Paula Lofland -
    On my iPhone, these were Y00 screws, not Y000
    Dutch version speaks of one 1,3 mm screw, but has 3 of those screws.
    Fonne Van Gils - Responder
    There is a difference between Y00 and Y000. I realized this after unknowingly trying the Y000 and damaging the tip of the screwdriver, as the metal is apparently softer than the screw. I was able to use the corner of a flat metal file to make the cheap Y0000 work (which came with the replacement kit) by making 3 adjustments: 10 filing down the tip, 2) filing the shoulders to make the tips more pointed, and 3) cleaning out the 3 channels to remove burrs from the tip edges.
    Robert Lanzafame - Responder
    Note on the bracket, it’s above the attached washers to the plate backing the screen. The image here is obscured by the yellow and red circles. Also, the bracket has a red herring hole that doesn’t serve an apparent purpose - don’t freak out and think you lost a screw
    Wandra - Responder
  25. iPhone 8 LCD and Digitizer Replacement, Disconnect the Touch ID sensor: passo 25, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement, Disconnect the Touch ID sensor: passo 25, imagem 2 %32 iPhone 8 LCD and Digitizer Replacement, Disconnect the Touch ID sensor: passo 25, imagem 3 %32
    • Use an opening tool to pry under the left edge of the home button cable connector to disconnect it from its socket.
    • If the entire connector begins to flip up without separating, press down on the cable at the top edge of the connector with the flat end of your spudger, while simultaneously prying up the left edge of the connector. Be very careful not to damage the cable or connector, or you will permanently disable the sensor.
    To have a better view on this connection I have removed the metal plate covering the back of the glass. Its a thin piece of metal held by 9 screws. To unscrew the 8 screws you need the screwdriver head with 3 sides like the Mercedes Benz symbole. The last is with a phillips near the camera.
    I thought I was going to tear the cable doing it the way it’s suggested in the guide. After examining the cable on the replacement screen, I found it easier to hold the bottom connector pressed against the screen with one leg of needle nose tweezers whilst gently prying off the top connector with an opening tool.
    Cool_Breeze - Responder
    See step 22 to get a clearer picture of what the connector looks like when it is separated from its socket. Your replacement screen will have a new socket (i.e., the bottom piece of the connector). My replacement screen had a new socket attached to the unit by a thin piece of plastic. For reassembly, when working the Home Button/Touch ID assembly back into the new screen, I had to work the connector cable under the socket in order to get the connector re-attached.
    Be extra careful with this step: it wasn’t clear to me from the description that the connector wrapped from underneath to connect, nor did my set come with picks. I used a blade from the wrong side, inadvertently (but way too easily) severing the connector and destroying the function of the home button and thus the entire phone.
    Jennifer Indeliclae - Responder
    Be careful, I initially didn’t found the connector and nearly ripped the cable. The connector leads to a cable that goes under the metal plate. Found a YouTube video with very good close ups for this part (go cell phone repair detailed version)
    Svenja Büsing - Responder
    I initially didn’t found the connector and cable and nearly broke it. The connector leads to a cable that goes under the metal plate, I needed YouTube video with good close ups to understand the setup.
    There is a socket that sticks down from the screen that should go over the button cable. Then you must fold the button into the the Touch ID.. Then the bracket can go back on the the screen. The home button and Touch ID works for me, so I must have done it right.
    Daylen Westwood - Responder
  26. iPhone 8 LCD and Digitizer Replacement, Remove the Touch ID sensor: passo 26, imagem 1 %32
    • Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
    • Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
    • Don't overheat the display. It should be slightly too hot to touch comfortably.
    The stove top works well also. Remember, as the main instructions say, it should be slightly too hot to touch comfortably.
    I used my heat gun to soften the adhesive and peal off the old button and cable here. The new home button which I ordered of eBay was able to hold itself from the stickyness of the cable. Then I put the screws back in and everything was fine.
  27. iPhone 8 LCD and Digitizer Replacement: passo 27, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 27, imagem 2 %32 iPhone 8 LCD and Digitizer Replacement: passo 27, imagem 3 %32
    • Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
    My original assembly broke trying to follow this step carefully. :(
    Ann - Responder
    This one’s kind of hard to reconnect. Just remember to be gentle, take your time, and use your hands so that you can really feel it out.
    Keep in mind, there’s a tiny rubber ring gasket between the Touch ID button and the display. In my experience when removing the button, the gasket stuck partly to the the button and partly to the display. I gently removed the part that was sticking to the display and guided it back on the button. If you’re missing that gasket it won’t be waterproof.
    Sam Tropper - Responder
    I used a heat gun set at 300*F to heat up the glass side for about 20 seconds and on connector side for about 10 seconds (touchscreen was a little too hot to the touch). Pulled connector with fingers and pried off with plastic tool.
    anonymous 6745 - Responder
  28. iPhone 8 LCD and Digitizer Replacement: passo 28, imagem 1 %32
    • Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
    • To reinstall, first feed the cable through the hole in the front of the display as shown.
    • Your replacement part may come with extra Y000 screws already installed near the Home Button. Remove the unnecessary screws so that you can reinstall the home button bracket.
    Instructions were great. Putting the connections back is a bit of a hassle, but patience is your friend. Phone is up and running. Thanks iFixit.
    pwpfef01 - Responder
    Couldn’t get the Home Button (original one I was transferring) to work. I know the instructions said something about not tightening down the 4 screws around the Home Button too much, but how much is too much. Also, a day later, the screen I bought starting having green vertical lines. Took everything back apart and started from scratch the next day and still had the same 2 problems. Just for the heck of it, I put the old cracked screen back on the phone and everything started working again. Figured I wasted about 6-8 hours total on this rather small project and I’m right back where I started again. Something definitely wrong with the screen I ordered and I’m very disappointed. I’ve bought products from ifixit before and they worked, but no such luck this time. Anyone know how I get my 70 bucks back?
    Todd Skobjak - Responder
    Hi Todd!
    I’m sorry to hear about your experience! Please contact our customer support and we will get the issue resolved!
    Arthur Shi -
    They charged you $70 bucks for a new replacement screen for an iphone8 and it didn't even work right that's crazy they are over charging people considering my wife only payed $23 for a new replacement screen kit that comes with the new screen and everything else you need to change it out plus a extra screen protector and I just finished replacing the screen and so far so good no green vertical lines running down my screen. I like ifixit because they show me how to fix what I need to fix but I don't think I will be buying anything from them anytime soon.
    Lincoln -
    I greatly support Ifixit… but.. for me the same story as Todd Skobjak. Put in the new screen. Touch button is not found. Retried with screws loosened and refitting the plug. Nothing. Put the old screen back and the touch button worked again. So.. something with the new provided screen from Ifixed must be the case. I'll also get in touch with customer support.
    Ifixed: not only check the screen but also the cable to the touch button!
    Ton Vaes - Responder
    What’s the trick here?
    Getting an “unable to activate Touch ID” after replacing the home button and a new screen - somewhat similar to that above. Any troubleshooting steps/resolution? I loosened, tightened screws holding the assembly, no effect.
    schaferjon - Responder
    The button is paired with the motherboard. if you change the screen, always attempt to retrieve the original button.. otherwise touchid will not be available
    Bill McNamara -
    The instructions for this home/touch button repair were spot on! The special tip in red for Step 19 was extremely useful because that was exactly what I encountered while attempting to remove the original home/touch button from the original front screen. Step 21 and accompanying photos were a life saver as well, but this process did require heating the screen with my wife’s hair dryer several times to be able to gently pry up the adhesive for the home/touch button ribbon without ripping it to pieces. And yes my phone worked great after completing this repair. Time spent meant money saved and a personal satisfaction and pride in a job well done. Thank you Team iFixit!
    Jeffery Anderson - Responder
    the steps to move the front camera and speaker to the new screen are missing, right?
    martijn.klabbers - Responder
    do you really neec to replace the home button?
    ineedtoreplacemyphonescreen - Responder
    Do you foget to pick up and set the inner camera?
    Or, is that too easy for you to instract in it...?
    Actually I got that by myself,,,
    M Moto - Responder
  29. iPhone 8 LCD and Digitizer Replacement, Remove the earpiece bracket: passo 29, imagem 1 %32
    • Remove the three Phillips screws securing the top earpiece bracket to the front panel:
    • Two 2.6 mm screws
    • One 1.8 mm screw
    I updated the step to clarify that!
    Arthur Shi -
  30. iPhone 8 LCD and Digitizer Replacement: passo 30, imagem 1 %32
    • Remove the earpiece speaker bracket.
  31. iPhone 8 LCD and Digitizer Replacement, Move the front-facing camera: passo 31, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement, Move the front-facing camera: passo 31, imagem 2 %32
    • Lift the front facing camera up out of its socket and swing it out of the way.
  32. iPhone 8 LCD and Digitizer Replacement, Remove the earpiece speaker: passo 32, imagem 1 %32
    • Remove the two Phillips screws securing the earpiece speaker to the front panel:
    • One 1.8 mm screw
    • One 2.3 mm screw
  33. iPhone 8 LCD and Digitizer Replacement: passo 33, imagem 1 %32
    • Remove the earpiece speaker.
    The metal faceplate that you can see in the image on my speaker has been scratched an scored from a previous repair by someone else. Could this affect the speaker in any way?
    Kyle Webb - Responder
    Hi Kyle,
    The metal shield should have no effect on the speaker. Granted, it may hint that damage was done around the area, which may have damaged the speaker module.
    Arthur Shi -
    Hi , I have Changed with success the camera piece but after reassembling, the speaker does Not work.A weird fact ist that Wireless Headphones will now reproduce músic but Not Phone Sounds(voices)! Have you Got any idea about this ? I am quite Sure I didn t damage the speaker but before changing It(as a posible Next step)I world like to ask you for any comment ! Thanks
    enbernat - Responder
    Check the connectors. They're just metal pads, and if you got them dirty or oily (from your fingers) they may not be making contact.
    Calion -
  34. iPhone 8 LCD and Digitizer Replacement, Remove the front camera and sensor cable: passo 34, imagem 1 %32
    • Heat an iOpener and apply it to the upper edge of the display to soften the adhesive holding the front camera and sensor assembly in place.
    • Wait about two minutes before moving on to the next step to adequately soften the adhesive.
  35. iPhone 8 LCD and Digitizer Replacement: passo 35, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 35, imagem 2 %32
    • Use the point of a spudger to gently pry the proximity sensor out of its recess on the front panel.
    • Try to get your tool all the way under the sensor to pry it away from the clear plastic beneath. If you pry only against the cable, the sensor may separate from the cable assembly and will need replacement. If you're replacing the sensor/cable assembly anyway, then it doesn't matter.
    Achtung: sehr kritische Operation !!! Kabel löst sich sehr schnell vom Sensor…nur am Sensor arbeiten, nicht am Kabel ziehen…gut wärmen und Geduld !
    ubrunner - Responder
    Attention: very critical operation !!! Cable detaches very quickly from the sensor... only work on the sensor, do not pull the cable... warm well and patience !
  36. iPhone 8 LCD and Digitizer Replacement: passo 36, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 36, imagem 2 %32
    • Slide the tip of a spudger underneath the ambient light sensor flex cable, and lift the sensor out of its housing.
  37. iPhone 8 LCD and Digitizer Replacement: passo 37, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 37, imagem 2 %32 iPhone 8 LCD and Digitizer Replacement: passo 37, imagem 3 %32
    • Slide an opening pick underneath front camera cable assembly, separating the adhesive holding the camera and sensor cable.
  38. iPhone 8 LCD and Digitizer Replacement: passo 38, imagem 1 %32
    • Remove the front camera and sensor cable.
    Thank you, what about removing the camera support or the little plastic squares to hold the sensor?
    Francisco O - Responder
    Why is there a screw still left on the frame, should I remove that too. When I connect the front camera flex cable to the motherboard it gets super hot and smells like burn rubber.⏎
    Could it be because I did not remove the last screw and connector flex cable? As shown in the iFixit photo they left one screw and flex cable behind.
    Inino - Responder
    What is not said here is what an amazingly complex procedure it is to fold the replacement sensor cable. I put a red dot on the old one (to remember which is which), then folded the new one as similarly as possible. I put the earpiece speaker in to the folds of the cable and put the speaker and cable in place together. Then put the long screw into the speaker partway before readjusting and lining up other holes with a needle.
    Thomas Hayes - Responder
  39. iPhone 8 LCD and Digitizer Replacement, Separate the LCD and digitizer: passo 39, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement, Separate the LCD and digitizer: passo 39, imagem 2 %32
    • Remove the six 1.2 mm Y000 screws from both sides of the display.
    Bei meinem iPhone 8 handelt es sich hierbei um Y00 Schrauben, der Y000 Bit greift nicht richtig
  40. iPhone 8 LCD and Digitizer Replacement: passo 40, imagem 1 %32
    • Heat an iOpener and lay it over the edge of the shield closest to the home button to soften the adhesive holding it in place.
  41. iPhone 8 LCD and Digitizer Replacement: passo 41, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 41, imagem 2 %32 iPhone 8 LCD and Digitizer Replacement: passo 41, imagem 3 %32
    • Use an opening pick to break up the adhesive near the home button that holds the flat display cable to the LCD shield plate.
  42. iPhone 8 LCD and Digitizer Replacement: passo 42, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 42, imagem 2 %32 iPhone 8 LCD and Digitizer Replacement: passo 42, imagem 3 %32
    • Insert an opening pick from the bottom right corner and continue to separate the display cable from the LCD shield plate.
  43. iPhone 8 LCD and Digitizer Replacement: passo 43, imagem 1 %32 iPhone 8 LCD and Digitizer Replacement: passo 43, imagem 2 %32
    • Gently lift the LCD shield plate from the display assembly.
    • Be careful not to snag the display data cables when removing the LCD shield plate.
  44. iPhone 8 LCD and Digitizer Replacement: passo 44, imagem 1 %32
    • Only the LCD and digitizer remain.
Conclusão
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our iPhone 8 Answers community for troubleshooting help.
83 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
300.711 Reputação
Autoria de 687 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 22.478 guias
21Comentários do guia
So I’m pretty sure I know the answer to this - but can I test out the screen replacement without hooking up the camera, home button, etc? Can I just attach the three cables to the phone to make sure the screen works, or would it brick the phone?
Sarah Ybarra - Responder
Hi Sarah,
You can test the display without bricking your phone. It may boot-loop when the front sensor/camera assembly isn’t connected though. Be careful while you work with an opened phone with the battery connected…it is easy to accidentally short things out!
Arthur Shi -
After replacing the iPhone 8 LCD Screen and Digitizer, it seems that the battery is draining faster. I just wanted to see if this is a normal problem or was there something I missed during the install process?
Jason Adams - Responder
My daughters phone was repaired and the same thing is happening to her
tiffinycook -
Do you have to remove the plastic holder for the camera?
Diego Cisneros - Responder
Hi Diego,
If your replacement part did not come with the plastic holder, you will have to transfer the old one onto the new frame.
Arthur Shi -
Sometimes, just depends if your new/replacement screen came with one or not.
Sam the Techman -
Between step 30 and 31, a screw is removed that’s not mentioned in the guide. Should probably add what screw that was. And why.
Brage Boman - Responder
Hi Brage,
Good catch! The screw holds the earpiece speaker flex cable in place. You do not need to remove that screw (it actually shows up again in step 33). In the meantime, I will look into correcting the step.
Arthur Shi -
Is it safe to place the coins and heavy books on the iPhone 8 as it has the glass back?
Archie Cottam - Responder
Yeah, it shouldn't be any major concern. I've put a lot more pressure on them than that would, just by hand, and rubber bands, etc to help secure the adhesive on front and backs. You want to have the pressure even though, not localized to one spot. If you do that, you risk cracking it. For example, way back in the day I was doing a 5S and right at the very end snapping the screen in, I pressed too hard in the bottom corner and cracked the new screen. So, just avoid doing similar lol.
Sam the Techman -
Any reason my earpiece doesn’t work after my install? Everything worked before, I wonder if its a cheap digitizer, or if i didn’t attach the speaker back flush
G S - Responder
maybe you have damaged the flat or the earpiece isn’t correctly connected.
neax -
Check the connector, and make sure it is properly seated, or just disconnect and reconnect. If it still doesn't work, you can wiggle the cable or try pressing on different parts of it, but if none of that works, there's a good chance it was accidentally damaged, unfortunately.
Sam the Techman -
Thanks for a great guide, I’ve used it a few times now. Also, great tips along the way.
Jamie Oyakawa - Responder
The screen blinks on some places if I push it.
How is this possible ?
Simon Rutten - Responder
after replacing the complete display, my touch id no longer works on the new display.
instead on the old display it works fine.
what can be the problem!?
kamal - Responder
You must transfer the tuch id sensor from the old screen to the new: it is paired to your specific motherboard and won’t work even if you install another original sensor, because… Apple.
Daniele Carminati -
Great guide, easy to understand, had no problems. Thank you.
Mark Robart - Responder
OK, but what about the adhesive screen? How do you position it?
RobertAncet - Responder
Just line it up as if you were putting a screen protector on. Same idea. You can use tweezers or such to help align it if it's difficult with fingers.
Sam the Techman -
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 96
Últimos 30 dias: 577
Ao todo: 120,192
