Ir para o conteúdo principal
Steam Deck Right Button Board Replacement
Carsten Frauenheim
Carsten Frauenheim e 4 outros colaboradores
Última atualização em January 18, 2025
45 minutos - 1 hora
Moderado
Introdução
Ir para o passo 1
Use this guide to replace the right button board on your Steam Deck LCD.
Remember: follow general electrostatic discharge (ESD) safety procedures while repairing your device.
These steps only describe how to physically remove and replace your console’s button board. You may need additional software tools and calibration procedures to get a replacement board to function as intended.
O que você precisa
Ferramentas
Exibir mais…
  1. Steam Deck Right Button Board Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 1 %32 Steam Deck Right Button Board Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 2 %32 Steam Deck Right Button Board Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 3 %32
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck Right Button Board Replacement, Remove the back cover screws: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    FixMat
    $36.95
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four coarse thread 9.5 mm-long screws
    • Four fine thread 5.8 mm-long screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
  3. Steam Deck Right Button Board Replacement, Unclip the back cover: passo 3, imagem 1 %32 Steam Deck Right Button Board Replacement, Unclip the back cover: passo 3, imagem 2 %32
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
  4. Steam Deck Right Button Board Replacement, Remove the back cover: passo 4, imagem 1 %32 Steam Deck Right Button Board Replacement, Remove the back cover: passo 4, imagem 2 %32 Steam Deck Right Button Board Replacement, Remove the back cover: passo 4, imagem 3 %32
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
  5. Steam Deck Right Button Board Replacement, Uncover the hidden shield screw: passo 5, imagem 1 %32 Steam Deck Right Button Board Replacement, Uncover the hidden shield screw: passo 5, imagem 2 %32
    • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
  6. Steam Deck Right Button Board Replacement, Remove the shield screws: passo 6, imagem 1 %32 Steam Deck Right Button Board Replacement, Remove the shield screws: passo 6, imagem 2 %32
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
    • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
  7. Steam Deck Right Button Board Replacement, Remove the shield: passo 7, imagem 1 %32 Steam Deck Right Button Board Replacement, Remove the shield: passo 7, imagem 2 %32 Steam Deck Right Button Board Replacement, Remove the shield: passo 7, imagem 3 %32
    • Remove the board shield.
    • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
    • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
  8. Steam Deck Right Button Board Replacement, Disconnect the battery: passo 8, imagem 1 %32 Steam Deck Right Button Board Replacement, Disconnect the battery: passo 8, imagem 2 %32 Steam Deck Right Button Board Replacement, Disconnect the battery: passo 8, imagem 3 %32
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
  9. Steam Deck Right Button Board Replacement, Unclip the right trigger: passo 9, imagem 1 %32 Steam Deck Right Button Board Replacement, Unclip the right trigger: passo 9, imagem 2 %32
    • The right trigger will be on your left-hand side when working on the Steam Deck, as it's laying upside down.
    • The Steam Deck's triggers clip into place on two pegs on the trigger bracket, which doubles as the hinge.
    • Place the flat end of a spudger onto the inside edge of the trigger's right clip.
    • Pivot the trigger clip out, away, and up from the peg to unlatch it.
    • During reassembly, latch the outermost peg first. Once in place, push down on the trigger to latch the innermost peg, producing an audible "click" sound.
    • Check to make sure that the trigger spring is properly aligned. Test the trigger action before continuing reassembly.
  10. Steam Deck Right Button Board Replacement, Remove the right trigger: passo 10, imagem 1 %32 Steam Deck Right Button Board Replacement, Remove the right trigger: passo 10, imagem 2 %32
    • Remove the right trigger.
    • Take care to not lose the trigger spring. It press-fits onto a peg on the trigger's underside.
  11. Steam Deck Right Button Board Replacement, Remove the trigger bracket screws: passo 11, imagem 1 %32
    • Use a Phillips driver to remove the three 5.2 mm screws securing the right trigger bracket.
  12. Steam Deck Right Button Board Replacement, Remove the trigger bracket: passo 12, imagem 1 %32
    • Remove the right trigger bracket.
    • Replacement triggers require calibration to work as expected. To calibrate new triggers, follow this calibration guide.
  13. Steam Deck Right Button Board Replacement, Disconnect the right thumbstick: passo 13, imagem 1 %32 Steam Deck Right Button Board Replacement, Disconnect the right thumbstick: passo 13, imagem 2 %32 Steam Deck Right Button Board Replacement, Disconnect the right thumbstick: passo 13, imagem 3 %32
    • Use the pointed end of a spudger to lift up the small locking flap on the thumbstick cable's ZIF connector.
    • Use a pair of tweezers to slide the cable out of its connector.
    • Grip the cable by the blue pull tab, not by the cable itself.
  14. Steam Deck Right Button Board Replacement, Remove the thumbstick screws: passo 14, imagem 1 %32 Steam Deck Right Button Board Replacement, Remove the thumbstick screws: passo 14, imagem 2 %32
    • Use a Phillips driver to remove the three 5.2 mm screws securing the thumbstick.
    • During reassembly, you may need to hold the Steam Deck off of the work surface so it isn't resting on the new thumbstick while you tighten down the screws.
  15. Steam Deck Right Button Board Replacement, Remove the right thumbstick: passo 15, imagem 1 %32 Steam Deck Right Button Board Replacement, Remove the right thumbstick: passo 15, imagem 2 %32
    • Remove the right thumbstick.
  16. Steam Deck Right Button Board Replacement, Disconnect the button board cable: passo 16, imagem 1 %32 Steam Deck Right Button Board Replacement, Disconnect the button board cable: passo 16, imagem 2 %32 Steam Deck Right Button Board Replacement, Disconnect the button board cable: passo 16, imagem 3 %32
    • Use the pointed end of a spudger to lift up the small locking flap on the button board cable's ZIF connector.
  17. Steam Deck Right Button Board Replacement, Disconnect the interconnect cable: passo 17, imagem 1 %32 Steam Deck Right Button Board Replacement, Disconnect the interconnect cable: passo 17, imagem 2 %32 Steam Deck Right Button Board Replacement, Disconnect the interconnect cable: passo 17, imagem 3 %32
    • Use the pointed end of a spudger to lift up the small locking flap on the button board interconnect cable's ZIF connector.
  18. Steam Deck Right Button Board Replacement, Disconnect the remaining button board cables: passo 18, imagem 1 %32 Steam Deck Right Button Board Replacement, Disconnect the remaining button board cables: passo 18, imagem 2 %32 Steam Deck Right Button Board Replacement, Disconnect the remaining button board cables: passo 18, imagem 3 %32
    • If any connectors are covered with tape, use a pair of tweezers to remove it.
    • Use the pointed end of a spudger to lift up the small locking flaps on the rest of the button board ZIF connectors. Use a pair of tweezers to slide the cables out of their connectors:
    • Disconnect the action buttons cable.
    • Disconnect the touchpad board cable.
    • Disconnect the touchpad cable.
  19. Steam Deck Right Button Board Replacement, Disconnect the right haptics: passo 19, imagem 1 %32 Steam Deck Right Button Board Replacement, Disconnect the right haptics: passo 19, imagem 2 %32 Steam Deck Right Button Board Replacement, Disconnect the right haptics: passo 19, imagem 3 %32
    • Exercise caution when lifting this connector—pry up on the connector itself, not its housing.
    • Use the pointed end of a spudger to lift up on the haptics cable to disconnect it.
    • Alternatively, you can leave the haptics connected to the button board and flip the board up and over the edge of the shell and out of the way.
  20. Steam Deck Right Button Board Replacement, Remove the button board screws: passo 20, imagem 1 %32
    • Use a Phillips driver to disconnect the four screws securing the right button board:
    • Three 5.2 mm screws
    • One 3.9 mm screw
  21. Steam Deck Right Button Board Replacement, Remove the button board: passo 21, imagem 1 %32 Steam Deck Right Button Board Replacement, Remove the button board: passo 21, imagem 2 %32
    • Remove the right button board.
    • Keep track of the quick access button and its membrane, as once the right button board is removed, they're no longer secured in place.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
6 outras pessoas executaram este guia.
Carsten Frauenheim
Membro desde: 03/10/20
136.272 Reputação
Autoria de 371 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.543 guias
42 comentários
When will this part be available?
Eric Canals - Responder
Is there any update to when this part will be available?
Tim Ceesay - Responder
Will this part not be available due to their need being a special calibration or hardware step? Having past six months this makes one think the part is not possible with end user due to another factor.
zZz - Responder
Is there any estimated time to when this part will become available?
David Chan - Responder
Parroting everyone else. When will this part be available?
Mario Noriega - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 102
Últimos 30 dias: 472
Ao todo: 20,472
