Ir para o conteúdo principal
Steam Deck Quick Access Button Replacement
O que você precisa
  1. Steam Deck Quick Access Button Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 1 %32 Steam Deck Quick Access Button Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 2 %32 Steam Deck Quick Access Button Replacement, Prepare your Steam Deck for disassembly: passo 1, imagem 3 %32
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
    Pergunte ao FixBot
    Comentar
  2. Steam Deck Quick Access Button Replacement, Remove the back cover screws: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    FixMat
    $36.95
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four coarse thread 9.5 mm-long screws
    • Four fine thread 5.8 mm-long screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
    Pergunte ao FixBot
    Comentar
  3. Steam Deck Quick Access Button Replacement, Unclip the back cover: passo 3, imagem 1 %32 Steam Deck Quick Access Button Replacement, Unclip the back cover: passo 3, imagem 2 %32
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
    Pergunte ao FixBot
    Comentar
  4. Steam Deck Quick Access Button Replacement, Remove the back cover: passo 4, imagem 1 %32 Steam Deck Quick Access Button Replacement, Remove the back cover: passo 4, imagem 2 %32 Steam Deck Quick Access Button Replacement, Remove the back cover: passo 4, imagem 3 %32
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
    Pergunte ao FixBot
    Comentar
  5. Steam Deck Quick Access Button Replacement, Uncover the hidden shield screw: passo 5, imagem 1 %32 Steam Deck Quick Access Button Replacement, Uncover the hidden shield screw: passo 5, imagem 2 %32
    • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
    Pergunte ao FixBot
    Comentar
  6. Steam Deck Quick Access Button Replacement, Remove the shield screws: passo 6, imagem 1 %32 Steam Deck Quick Access Button Replacement, Remove the shield screws: passo 6, imagem 2 %32
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
    • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
    Pergunte ao FixBot
    Comentar
  7. Steam Deck Quick Access Button Replacement, Remove the shield: passo 7, imagem 1 %32 Steam Deck Quick Access Button Replacement, Remove the shield: passo 7, imagem 2 %32 Steam Deck Quick Access Button Replacement, Remove the shield: passo 7, imagem 3 %32
    • Remove the board shield.
    • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
    • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
    Pergunte ao FixBot
    Comentar
  8. Steam Deck Quick Access Button Replacement, Disconnect the battery: passo 8, imagem 1 %32 Steam Deck Quick Access Button Replacement, Disconnect the battery: passo 8, imagem 2 %32 Steam Deck Quick Access Button Replacement, Disconnect the battery: passo 8, imagem 3 %32
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
    Pergunte ao FixBot
    Comentar
  9. Steam Deck Quick Access Button Replacement, Unclip the right trigger: passo 9, imagem 1 %32 Steam Deck Quick Access Button Replacement, Unclip the right trigger: passo 9, imagem 2 %32
    • The right trigger will be on your left-hand side when working on the Steam Deck, as it's laying upside down.
    • The Steam Deck's triggers clip into place on two pegs on the trigger bracket, which doubles as the hinge.
    • Place the flat end of a spudger onto the inside edge of the trigger's right clip.
    • Pivot the trigger clip out, away, and up from the peg to unlatch it.
    • During reassembly, latch the outermost peg first. Once in place, push down on the trigger to latch the innermost peg, producing an audible "click" sound.
    • Check to make sure that the trigger spring is properly aligned. Test the trigger action before continuing reassembly.
    Pergunte ao FixBot
    Comentar
  10. Steam Deck Quick Access Button Replacement, Remove the right trigger: passo 10, imagem 1 %32 Steam Deck Quick Access Button Replacement, Remove the right trigger: passo 10, imagem 2 %32
    • Remove the right trigger.
    • Take care to not lose the trigger spring. It press-fits onto a peg on the trigger's underside.
    Pergunte ao FixBot
    Comentar
  11. Steam Deck Quick Access Button Replacement, Remove the trigger bracket screws: passo 11, imagem 1 %32
    • Use a Phillips driver to remove the three 5.2 mm screws securing the right trigger bracket.
    Pergunte ao FixBot
    Comentar
  12. Steam Deck Quick Access Button Replacement, Remove the trigger bracket: passo 12, imagem 1 %32
    • Remove the right trigger bracket.
    • Replacement triggers require calibration to work as expected. To calibrate new triggers, follow this calibration guide.
    Pergunte ao FixBot
    Comentar
  13. Steam Deck Quick Access Button Replacement, Disconnect the right thumbstick: passo 13, imagem 1 %32 Steam Deck Quick Access Button Replacement, Disconnect the right thumbstick: passo 13, imagem 2 %32 Steam Deck Quick Access Button Replacement, Disconnect the right thumbstick: passo 13, imagem 3 %32
    • Use the pointed end of a spudger to lift up the small locking flap on the thumbstick cable's ZIF connector.
    • Use a pair of tweezers to slide the cable out of its connector.
    • Grip the cable by the blue pull tab, not by the cable itself.
    Pergunte ao FixBot
    Comentar
  14. Steam Deck Quick Access Button Replacement, Remove the thumbstick screws: passo 14, imagem 1 %32 Steam Deck Quick Access Button Replacement, Remove the thumbstick screws: passo 14, imagem 2 %32
    • Use a Phillips driver to remove the three 5.2 mm screws securing the thumbstick.
    • During reassembly, you may need to hold the Steam Deck off of the work surface so it isn't resting on the new thumbstick while you tighten down the screws.
    Pergunte ao FixBot
    Comentar
  15. Steam Deck Quick Access Button Replacement, Remove the right thumbstick: passo 15, imagem 1 %32 Steam Deck Quick Access Button Replacement, Remove the right thumbstick: passo 15, imagem 2 %32
    • Remove the right thumbstick.
    Pergunte ao FixBot
    Comentar
  16. Steam Deck Quick Access Button Replacement, Disconnect the button board cable: passo 16, imagem 1 %32 Steam Deck Quick Access Button Replacement, Disconnect the button board cable: passo 16, imagem 2 %32 Steam Deck Quick Access Button Replacement, Disconnect the button board cable: passo 16, imagem 3 %32
    • Use the pointed end of a spudger to lift up the small locking flap on the button board cable's ZIF connector.
    Pergunte ao FixBot
    Comentar
  17. Steam Deck Quick Access Button Replacement, Disconnect the interconnect cable: passo 17, imagem 1 %32 Steam Deck Quick Access Button Replacement, Disconnect the interconnect cable: passo 17, imagem 2 %32 Steam Deck Quick Access Button Replacement, Disconnect the interconnect cable: passo 17, imagem 3 %32
    • Use the pointed end of a spudger to lift up the small locking flap on the button board interconnect cable's ZIF connector.
    Pergunte ao FixBot
    Comentar
  18. Steam Deck Quick Access Button Replacement, Disconnect the remaining button board cables: passo 18, imagem 1 %32 Steam Deck Quick Access Button Replacement, Disconnect the remaining button board cables: passo 18, imagem 2 %32 Steam Deck Quick Access Button Replacement, Disconnect the remaining button board cables: passo 18, imagem 3 %32
    • If any connectors are covered with tape, use a pair of tweezers to remove it.
    • Use the pointed end of a spudger to lift up the small locking flaps on the rest of the button board ZIF connectors. Use a pair of tweezers to slide the cables out of their connectors:
    • Disconnect the action buttons cable.
    • Disconnect the touchpad board cable.
    • Disconnect the touchpad cable.
    Pergunte ao FixBot
    Comentar
  19. Steam Deck Quick Access Button Replacement, Disconnect the right haptics: passo 19, imagem 1 %32 Steam Deck Quick Access Button Replacement, Disconnect the right haptics: passo 19, imagem 2 %32 Steam Deck Quick Access Button Replacement, Disconnect the right haptics: passo 19, imagem 3 %32
    • Exercise caution when lifting this connector—pry up on the connector itself, not its housing.
    • Use the pointed end of a spudger to lift up on the haptics cable to disconnect it.
    • Alternatively, you can leave the haptics connected to the button board and flip the board up and over the edge of the shell and out of the way.
    Pergunte ao FixBot
    Comentar
  20. Steam Deck Quick Access Button Replacement, Remove the button board screws: passo 20, imagem 1 %32
    • Use a Phillips driver to disconnect the four screws securing the right button board:
    • Three 5.2 mm screws
    • One 3.9 mm screw
    Pergunte ao FixBot
    Comentar
  21. Steam Deck Quick Access Button Replacement, Remove the button board: passo 21, imagem 1 %32 Steam Deck Quick Access Button Replacement, Remove the button board: passo 21, imagem 2 %32
    • Remove the right button board.
    • Keep track of the quick access button and its membrane, as once the right button board is removed, they're no longer secured in place.
    Pergunte ao FixBot
    Comentar
  22. Steam Deck Quick Access Button Replacement, Remove the quick access button membrane: passo 22, imagem 1 %32 Steam Deck Quick Access Button Replacement, Remove the quick access button membrane: passo 22, imagem 2 %32
    • Use a pair of tweezers to remove the quick access button membrane.
    Pergunte ao FixBot
    Comentar
  23. Steam Deck Quick Access Button Replacement, Remove the quick access button: passo 23, imagem 1 %32 Steam Deck Quick Access Button Replacement, Remove the quick access button: passo 23, imagem 2 %32
    • Use a pair of tweezers to remove the quick access button.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
Uma outra pessoa concluiu este guia.
Carsten Frauenheim
Membro desde: 03/10/20
166.862 Reputação
Autoria de 439 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 27.557 guias
3Comentários do guia
My all buttons not working just touch screen,volume and power button works
Kindly guide me which thing is faulty
Bilal Ahmed - Responder Compartilhar
Why did I imagine just popping the back of the case off and getting right at it? lol
Can I just pay a professional to do this for me? Does someone certified offer this service?
Brandon Nebitt - Responder Compartilhar
Donde obtener la placa completa del lado derecho “Steam Deck L R Button Board” la Mia es de 12 pines
Wladimie - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 29
Últimos 30 dias: 144
Ao todo: 11,638
