Ir para o conteúdo principal
Singer Simple Sewing Machine (Model 2263) Needle Replacement
Renee Allred
Renee Allred e um outro colaborador
Última atualização em December 12, 2023
10 minutos
Fácil
Introdução
Ir para o passo 1
Use this guide to replace a broken needle on a Singer Simple Sewing Machine (Model 2263).
A broken sewing machine needle while sewing can be frustrating, but with this guide it can be a quick fix.
This guide will provide step by step instructions to remove the broken needle and replace it with a new one. No special skills are needed.
Before proceeding, make sure the sewing machine is turned off and unplugged. The needles have sharp edges, so use caution when handling.
  1. Singer Simple Sewing Machine (Model 2263) Needle Replacement, Needle: passo 1, imagem 1 %32
    • Turn off the sewing machine and unplug it.
  2. Singer Simple Sewing Machine (Model 2263) Needle Replacement: passo 2, imagem 1 %32
    • Push the back lever up and remove the presser foot.
  3. Singer Simple Sewing Machine (Model 2263) Needle Replacement: passo 3, imagem 1 %32
    • Raise the needle bar by turning the handwheel toward you.
  4. Singer Simple Sewing Machine (Model 2263) Needle Replacement: passo 4, imagem 1 %32
    • With the provided Singer screwdriver or a flat-head screwdriver, loosen the clamp screw by turning it toward you.
  5. Singer Simple Sewing Machine (Model 2263) Needle Replacement: passo 5, imagem 1 %32
    • Remove the broken needle.
  6. Singer Simple Sewing Machine (Model 2263) Needle Replacement: passo 6, imagem 1 %32 Singer Simple Sewing Machine (Model 2263) Needle Replacement: passo 6, imagem 2 %32
    • Insert the new needle with the flat side (the side with the numbers) facing the back of the sewing machine. Tighten the clamp screw by turning it toward the back.
  7. Singer Simple Sewing Machine (Model 2263) Needle Replacement: passo 7, imagem 1 %32 Singer Simple Sewing Machine (Model 2263) Needle Replacement: passo 7, imagem 2 %32
    • Put the presser foot back on by pushing the back lever up and guiding the bar on the presser foot onto the hook of the needle bar. Release the lever to secure.
Conclusão
Once the pressure foot is attached, thread the needle before plugging in the sewing machine and turning it on.
Renee Allred
Membro desde: 09/15/23
145 Reputação
Autoria de 1 guia
1Comentário do guia
Please assist me with adjusting needle bar height for Singer Simple 2263 cannot find how to adjust hook timing either have watched sooo many videos none have helped me
Maria L. Soto - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 42
Ao todo: 546
