Pebble Time Screen Cover Replacement
Introdução
Ir para o passo 1Replacement guide for the screen cover of the Pebble Time.
O que você precisa
Use the metal spudger to carefully pull apart the screen cover from the case.
Replace the metal spudger with a plastic opening tool to hold the cover open.
Just a note whilst removing the cover/screen - on my Pebble Time Steel, the LCD seemed to actually be attached to the glass, so when the adhesive around the outside seperated, I disconnected the ribbon cable and removed both as one piece - if you can, this definitely helps keep the end result a bit tidier!
Uma outra pessoa concluiu este guia.
Gear Up For Future Repairs
Shop all5Comentários do guia
What does one use to hold the screen on and reseal for waterproofing?
Using RTV silicon is problematic, I got some on my LCD and now I’m looking for a replacement Pebble.
HI I scratched my Crystal on my Pebble Time watch. Can the Crystal be buffed to get the scratch out??
This is a brand new Pebble Time watch!!
“CONCLUSION
To reassemble your device, follow these instructions in reverse order.”
Yeah, what about an adhesive or sealant? Best practice for doing so?
