Ir para o conteúdo principal
Pebble Time Screen Cover Replacement
Nicolas Hempe
Nicolas Hempe e um outro colaborador
Última atualização em 5 de mai de 2019
5 minutos
Moderado
Introdução
Ir para o passo 1
Replacement guide for the screen cover of the Pebble Time.
O que você precisa
Ferramentas
  1. Pebble Time Screen Cover Replacement, Screen Cover: passo 1, imagem 1 %32
    • Lay the watch flat on your workstation.
  2. Pebble Time Screen Cover Replacement: passo 2, imagem 1 %32 Pebble Time Screen Cover Replacement: passo 2, imagem 2 %32
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
    Just a note whilst removing the cover/screen - on my Pebble Time Steel, the LCD seemed to actually be attached to the glass, so when the adhesive around the outside seperated, I disconnected the ribbon cable and removed both as one piece - if you can, this definitely helps keep the end result a bit tidier!
    Aadi Bhamidipati - Responder
  3. Pebble Time Screen Cover Replacement: passo 3, imagem 1 %32
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Screen Cover Replacement: passo 4, imagem 1 %32
    • Carefully, pull apart the cover with the plastic opening tool.
Conclusão
Uma outra pessoa concluiu este guia.
Gear Up For Future Repairs
Shop all
Nicolas Hempe
Membro desde: 02/15/17
1.468 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-3, Sullivan Spring 2017 Membro de USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 Membros
Autoria de 10 guias
5Comentários do guia
What does one use to hold the screen on and reseal for waterproofing?
Shannon Oswald - Responder
Using RTV silicon is problematic, I got some on my LCD and now I’m looking for a replacement Pebble.
HI I scratched my Crystal on my Pebble Time watch. Can the Crystal be buffed to get the scratch out??
Janice Pruett - Responder
This is a brand new Pebble Time watch!!
CONCLUSION
To reassemble your device, follow these instructions in reverse order.”
Yeah, what about an adhesive or sealant? Best practice for doing so?
Adam MacDonald - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 1,767
