Ir para o conteúdo principal
Nintendo Switch Pro Controller Battery Replacement
Daniel Tagalog
Daniel Tagalog e 15 outros colaboradores
Última atualização em 19 de jan de 2024
5 - 10 minutos
Fácil
Introdução
Ir para o passo 1
Welcome! Does the battery in your controller not last as long as it used to or not at all? You must be looking to replace the battery in your Nintendo Switch Pro Controller, well you have come to the right place! Below you will find instructions for replacing the battery in your controller, read them carefully and follow the steps in order from one to six.
The Switch Pro Controller uses JIS screws. Be sure not to use a Phillips screwdriver to remove them, as it will potentially strip the screws.
NOTE: an improperly sync Switch Pro controller will not charge properly. To determine if your battery is faulty and needs replacing, you can first re-sync your controller and, while plugged in, check within the Switch controllers menu if it is charging properly.
CAUTION: The handling of any swollen batteries should be done with the utmost care. For information on how to identify, what to do with, how to handle, and how to dispose of swollen batteries follow the link below.
What to do with a swollen battery
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Nintendo Switch Pro Controller Battery Replacement, Remove the screws: passo 1, imagem 1 %32
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
    Be carefull, these screws are super easy to strip even with the right tools.
    Lukas Eberharter - Responder
    I tried editing these instructions after I had trouble with stripping screws, but it doesn't seem to take. The issue is that these are JIS and not Phillips screws. They are VERY similar looking but a Phillips head screwdriver will strip the screws.
    Isaac Webb - Responder
    I tried using a Philips #00 screwdriver but it didn’t work
    vincent ingrassia - Responder
    Don't even think about trying Phillips. There are some other guides online that say you'll be fine, but they're wrong. Even one attempt with Phillips WILL strip these, and you will never, ever get this controller open once that happens. Even with JIS they're really hard to get out and really easy to strip.
    Luke T. Allen - Responder
  2. Nintendo Switch Pro Controller Battery Replacement, Remove the handle covers: passo 2, imagem 1 %32 Nintendo Switch Pro Controller Battery Replacement, Remove the handle covers: passo 2, imagem 2 %32 Nintendo Switch Pro Controller Battery Replacement, Remove the handle covers: passo 2, imagem 3 %32
    • Carefully remove the handle covers by pulling them away from the main body.
  3. Nintendo Switch Pro Controller Battery Replacement, Remove the screws: passo 3, imagem 1 %32
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
  4. Nintendo Switch Pro Controller Battery Replacement, Unclip the plastic cover: passo 4, imagem 1 %32 Nintendo Switch Pro Controller Battery Replacement, Unclip the plastic cover: passo 4, imagem 2 %32 Nintendo Switch Pro Controller Battery Replacement, Unclip the plastic cover: passo 4, imagem 3 %32
    • Carefully pry away the clear plastic cover using your fingernail.
  5. Nintendo Switch Pro Controller Battery Replacement, Remove the clear plastic cover: passo 5, imagem 1 %32
    • Remove the clear plastic cover.
  6. Nintendo Switch Pro Controller Battery Replacement, Remove the battery: passo 6, imagem 1 %32 Nintendo Switch Pro Controller Battery Replacement, Remove the battery: passo 6, imagem 2 %32 Nintendo Switch Pro Controller Battery Replacement, Remove the battery: passo 6, imagem 3 %32
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
Conclusão
For optimal performance, calibrate your newly installed battery after completing this guide.
41 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Daniel Tagalog
Membro desde: 10/10/19
1.925 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S11-G2, Regan Fall 2019 Membro de Cal Poly, Team S11-G2, Regan Fall 2019
CPSU-REGAN-F19S11G2
5 Membros
Autoria de 44 guias
13Comentários do guia
now what after taking the battery out
Seani M - Responder
Install the replacement battery and follow the steps in reverse order…
frzno72 -
easy peasy only have to recycle battery
Dan Carroll - Responder
Where can I buy genuine ctr-003 batteries in germany/europe?
smol_tsukiko - Responder
You can buy them directly in the iFixit Europe or in your case in the Germany store.
Henrynaja -
My controller would not turn on one day. Followed this guide to remove the battery and just reseat it . Works now! Thank you!
Unthar - Responder
Used the iFixit PH00 and it stripped my screws
gpetit - Responder
Taken directly from iFixit themselves.
"Bits with the prefix "J" and "PH" are often thought to be the same bit. Don't be fooled by their similar appearance—they are quite different.
Phillips (PH) screws are designed to make a Phillips screwdriver cam out if too much torque is applied. This prevents damage to screws and screwdrivers or bits.
Japanese Industrial Standard (J) screws do not provide a cam-out option, and have 90 degree corners."
This guide calls for a JIS00 and not PH00, So that is why the screws stripped.
WinDVD -
Guide facile à suivre et rapide à exécuter. Merci!
Philippe Côté - Responder
Thanks for sharing this "how to" guide. Upon replacing my battery I realize that there was a malfunctioning into the USB-C port which was not charging batteries through the controller port. I'm writing this in order to alert some people that the problem with batteries been depleted can be related to charging issues. Check it before replacing batteries! =)
Danilo Mazzolani - Responder
質問ですが、バッテリーを抜いた状態でusbで繋いだら動きますか?
兼城賢蔵 - Responder
動く。有線無線どちらも。
Ahellina -
The battery says to charge it to 100% + 2 hours and then use the controller so that it uses up the entire battery and then charge to 100% again. If you're not playing Nintendo for hours, how do you use up the battery in the controller?
robbieleffel - Responder
Comentar
Visualizações:
Últimas 24 horas: 45
Últimos 7 dias: 311
Últimos 30 dias: 1,655
Ao todo: 84,531
