Ir para o conteúdo principal
Nintendo DSi XL Upper LCD Replacement
Brett Hartt
Brett Hartt e 3 outros colaboradores
Última atualização em 23 de mar de 2025
30 minutos - 2 horas
Muito difícil
Introdução
Ir para o passo 1
Get a better view of what you are playing by replacing a cracked, broken, or faulty Upper LCD in your DSi XL.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Nintendo DSi XL Upper LCD Replacement, Battery: passo 1, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement, Battery: passo 1, imagem 2 %32
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
    rust/white powder built up on a screw and can’t unscrew it
    Eco - Responder
  2. Nintendo DSi XL Upper LCD Replacement: passo 2, imagem 1 %32
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Upper LCD Replacement, Lower Case: passo 3, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement, Lower Case: passo 3, imagem 2 %32 Nintendo DSi XL Upper LCD Replacement, Lower Case: passo 3, imagem 3 %32
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Upper LCD Replacement: passo 4, imagem 1 %32
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Upper LCD Replacement: passo 5, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 5, imagem 2 %32 Nintendo DSi XL Upper LCD Replacement: passo 5, imagem 3 %32
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Upper LCD Replacement: passo 6, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 6, imagem 2 %32
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Upper LCD Replacement: passo 7, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 7, imagem 2 %32
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Upper LCD Replacement, Wi-Fi Board: passo 8, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement, Wi-Fi Board: passo 8, imagem 2 %32
    • Lift the Wi-Fi board up off its socket on the motherboard.
    • Do not attempt to completely remove the Wi-Fi board yet. It is attached to the motherboard by an antenna cable.
  9. Nintendo DSi XL Upper LCD Replacement: passo 9, imagem 1 %32
    • Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
    Can I use any other tool than a spudger?
    Noe - Responder
  10. Nintendo DSi XL Upper LCD Replacement, Motherboard: passo 10, imagem 1 %32
    • Use a spudger to pry the microphone cable off the motherboard.
    • Pry from underneath the cable.
    Note that the WiFi board has already been removed here! Including this extra step would be convenient here '-)
    Sjoerd Hulshof - Responder
  11. Nintendo DSi XL Upper LCD Replacement: passo 11, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 11, imagem 2 %32
    • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
    • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
  12. Nintendo DSi XL Upper LCD Replacement: passo 12, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 12, imagem 2 %32
    • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
    • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
  13. Nintendo DSi XL Upper LCD Replacement: passo 13, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 13, imagem 2 %32
    • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
    • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
  14. Nintendo DSi XL Upper LCD Replacement: passo 14, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 14, imagem 2 %32
    • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
    • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
    -This is where you can replace the charger port. i may change this comment later from May 21-June 5
    Artemy Matveev - Responder
  15. Nintendo DSi XL Upper LCD Replacement: passo 15, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 15, imagem 2 %32
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
    • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
  16. Nintendo DSi XL Upper LCD Replacement: passo 16, imagem 1 %32
    • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
    The battery connectors (socket) on the mother board are extremely fragile, so care should be taken to avoid breaking them.
    Other than this, the instructions given are precise and straighforward. I do agree with the other comments about step 20.
    Paulette Williams - Responder
    Be careful with the battery cable, I ripped the entire socket off with little force.
    Joel Griggs - Responder
  17. Nintendo DSi XL Upper LCD Replacement: passo 17, imagem 1 %32
    • Remove the screws securing the motherboard to the upper case:
    • A single 2.5 mm silver Phillips screw
    • Four 3.7 mm black Phillips screws
    the battery connector was (for me) extremely hard to remove. I broke the socket completely off the board hand had to hard solder it directly back.
    Rohan Grant-Dawes - Responder
    On Step 17, I only had the 3 black Philips screws on the left to remove.
    bfmackin - Responder
  18. Nintendo DSi XL Upper LCD Replacement: passo 18, imagem 1 %32
    • Deroute the microphone and antenna cables through the slot in the motherboard.
  19. Nintendo DSi XL Upper LCD Replacement: passo 19, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 19, imagem 2 %32
    • Rotate the motherboard off the lower case.
    • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
  20. Nintendo DSi XL Upper LCD Replacement: passo 20, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 20, imagem 2 %32
    • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
    • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
    • The motherboard is now free from the upper case.
    This step is unnecessary. The ribbon is a total pain in the butt to get back in, and if you dont get it PERFECT, the DS will not even fire back up. Unless it is absolutely necessary to remove it... DON'T !!! ( Personal experience, Everything else was SPOT ON) THANK YOU FOR THE HELP, saved me a lot of $$$
    Jerod Cook - Responder
    Completed, worked perfectly! I agree with the comment about step 20, completely unnecessary.
    ian - Responder
    Fantastic! Fixed my daughter's irreplaceable DSi XL - you should see her smiles!! Not sure about step 20 I did this before reading the comments (guess there's a message there). Thanks so much whoever wrote this - you're a legend and you've made a child very happy (and a dad too thereby).
    lb9 - Responder
    I put mine back together for my daughter with the new bottom screen, but it won't power on. It tries but won't I'm assuming that this ribbon is the cause.
    bigdrum1998 - Responder
    The instructions are perfect though! Great thing to have these instructions it's a tremendous help! :-)
    YHWH is the god of all knowledge. Put a piece of transparent tape on the ribbon cable to give more leverage to pull the cable up to slide it into the slot. Also turn the motherboard slightly so that you can get it closer to the cable.
    Deanna Cortez - Responder
    I didn't get mine completely reinserted at first. The symptom I experienced when powering it back on is the power light comes on briefly and the bottom screen light flashes, then they both shut off. No flash from the upper display. Had to try reinserting 3 times before I had it in completely. I agree, DON'T REMOVE if you don't have to.
    DONT follow this step, i missed these comments and removed my cable, it took me almost an hour (I know, way too long, I just couldn't get the cable far enough in to the slot) before the top screen finally worked. Was afraid I destroyed the cable, but it survived luckily enough.
    SaakS - Responder
  21. Nintendo DSi XL Upper LCD Replacement, Rear Bezel: passo 21, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement, Rear Bezel: passo 21, imagem 2 %32 Nintendo DSi XL Upper LCD Replacement, Rear Bezel: passo 21, imagem 3 %32
    • Turn the DSi XL over and open the display.
    • When re-assembling the device, be sure to re-install the ABXY and Start/Select buttons, as they are likely to fall out once the handheld console is turned over.
    • Use a pushpin to remove the four plastic screw covers on the front bezel.
  22. Nintendo DSi XL Upper LCD Replacement: passo 22, imagem 1 %32
    • Remove the four 3.5 mm silver Phillips screws securing the rear bezel to the front bezel.
  23. Nintendo DSi XL Upper LCD Replacement: passo 23, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 23, imagem 2 %32
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  24. Nintendo DSi XL Upper LCD Replacement: passo 24, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 24, imagem 2 %32
    • Insert a spudger into the gap between the front and rear bezel.
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  25. Nintendo DSi XL Upper LCD Replacement: passo 25, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 25, imagem 2 %32
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  26. Nintendo DSi XL Upper LCD Replacement: passo 26, imagem 1 %32
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  27. Nintendo DSi XL Upper LCD Replacement: passo 27, imagem 1 %32
    • Using the flat end of a spudger, pry the rear camera off the rear bezel.
    • Remove the rear bezel.
  28. Nintendo DSi XL Upper LCD Replacement, Front Bezel Assembly: passo 28, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement, Front Bezel Assembly: passo 28, imagem 2 %32 Nintendo DSi XL Upper LCD Replacement, Front Bezel Assembly: passo 28, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Close the DSi XL and turn it over.
    • Using a pair of tweezers, pull the microphone out of its housing in the front bezel.
    • De-route the microphone cable, and pull it through the right hinge.
  29. Nintendo DSi XL Upper LCD Replacement: passo 29, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 29, imagem 2 %32 Nintendo DSi XL Upper LCD Replacement: passo 29, imagem 3 %32
    • Using the flat end of a spudger, pry the left speaker out of its socket on the front bezel.
    • De-route the speaker cable along the top edge of the screen.
    • Work carefully and slowly, holding onto the wire and not the speaker itself. The solder joints may break if pulled on too hard.
    • In the same manner described above, remove the right speaker from its socket on the front bezel.
    • Place both speakers on the back of the upper LCD.
  30. Nintendo DSi XL Upper LCD Replacement: passo 30, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 30, imagem 2 %32
    • Ensuring that the upper LCD does not fall out of the front bezel, turn the DSi XL over.
    • Remove the seven 2.5 mm silver screws securing the power board to the upper case.
    • Lift the power board up off the upper case.
  31. Nintendo DSi XL Upper LCD Replacement: passo 31, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 31, imagem 2 %32
    • Peel the rubber button pads off the backside of the D-pad and power button.
    como consertar placas eletrônicas de máquina de lava roupas
    Jurandir - Responder
  32. Nintendo DSi XL Upper LCD Replacement: passo 32, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 32, imagem 2 %32
    • Open the case slightly.
    • Push the D-pad up through its housing in the upper case. Remove the D-pad.
    • In the same way, remove the power button from the upper case.
  33. Nintendo DSi XL Upper LCD Replacement: passo 33, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 33, imagem 2 %32
    • Using a pair of tweezers, remove the LED diffuser bracket and the LED diffuser from the upper case of the DSi XL.
  34. Nintendo DSi XL Upper LCD Replacement: passo 34, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 34, imagem 2 %32 Nintendo DSi XL Upper LCD Replacement: passo 34, imagem 3 %32
    • In the following steps, you will be using a spudger to remove the hinge pin from the left side of the DSi XL.
    • Place the tip of a spudger in the LED diffuser compartment, on the face of the clutch hinge.
    • Push the clutch hinge to the left.
    • Some force will be required. You will hear an audible "pop" when the clutch has cleared the lower case. It will move about 0.25".
  35. Nintendo DSi XL Upper LCD Replacement: passo 35, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 35, imagem 2 %32
    • Lift the left side of the front bezel away from the upper case.
    • Do not lift too far, or else the hinge pin will break. Only lift enough to clear the LED compartment, about 1".
    • Pull the front bezel to the left, separating the front bezel from the upper case.
    • Do not attempt to fully separate the two halves yet. There are still ribbon cables running through the upper case.
  36. Nintendo DSi XL Upper LCD Replacement: passo 36, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 36, imagem 2 %32 Nintendo DSi XL Upper LCD Replacement: passo 36, imagem 3 %32
    • Grasp the camera and upper LCD ribbon cables between your thumb and forefinger, pulling them out of the upper case slightly, slide them down through the slit in the upper case.
    • Rotate the front bezel assembly clockwise so that the ends of the camera and LCD cables slide sideways through the slit in the front bezel.
  37. Nintendo DSi XL Upper LCD Replacement: passo 37, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 37, imagem 2 %32
    • In order to remove the upper LCD and the cameras from the front bezel, it is helpful to coil the ribbon cables together.
    • Carefully coil the two ribbon cables together, so that the connectors are on the inside of the spool.
    • Wrap the ribbon cables tightly, but not too tight, as bending the connectors will render them inoperable.
  38. Nintendo DSi XL Upper LCD Replacement: passo 38, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 38, imagem 2 %32
    • Holding the upper LCD and the cameras together, pull the cables through the hinge in the front bezel.
    • Pull slowly, making sure that the cables do not catch on the hinge pin and tear.
    • Uncoil the ribbon cables.
  39. Nintendo DSi XL Upper LCD Replacement, Camera Ribbon: passo 39, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement, Camera Ribbon: passo 39, imagem 2 %32
    • Lift the camera ribbon cable up off the upper LCD, minding any adhesive that may still be attached.
  40. Nintendo DSi XL Upper LCD Replacement, Upper LCD: passo 40, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement, Upper LCD: passo 40, imagem 2 %32
    • Insert the flat end of a spudger underneath the adhesive pad on the front of the upper LCD.
    • Slide the spuder to the left, detaching the adhesive pad along the bottom edge.
  41. Nintendo DSi XL Upper LCD Replacement: passo 41, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 41, imagem 2 %32
    • In the same manner as previously described, remove the adhesive along the right edge of the upper LCD.
  42. Nintendo DSi XL Upper LCD Replacement: passo 42, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 42, imagem 2 %32
    • In the same manner as previously described, remove the adhesive along the top edge of the upper LCD.
  43. Nintendo DSi XL Upper LCD Replacement: passo 43, imagem 1 %32 Nintendo DSi XL Upper LCD Replacement: passo 43, imagem 2 %32
    • Firmly grasp the upper screen, and lifting from the right edge, pull the upper screen off of the upper LCD.
  44. Nintendo DSi XL Upper LCD Replacement: passo 44, imagem 1 %32
    • Removing the upper LCD, requires desoldering the speakers from the LCD assembly. If you require assistance soldering, please consult our soldered connections guide.
    • Desolder the speaker wires.
    • During reassembly, keep track of the location of each wire. The black wire is soldered to the right pad; the red wire is soldered to the left pad.
    • Upper LCD remains.
Conclusão
17 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Brett Hartt
Membro desde: 04/12/10
130.736 Reputação
Autoria de 143 guias
Equipe
iFixit Membro de iFixit
Staff
120 Membros
Autoria de 23.080 guias
6Comentários do guia
I think a soldering tool needs to be added to the tool list. It may be a given for pros, but for amateur fixit wannabes this could be useful information to have before step 44.
Amanda Langston - Responder
Why is there two Upper LCD Replacements here? makes no sense, Can i have a explanation for this? One is "Difficult", and another is "Very difficult"
Santi12008 - Responder
there's two different options?? why does this got to be so complicated. is there any place that does replacements for me?
Tony Gunk -
You wait til the final STEP 44 to mention soldering is required…!?!
Andy Bravo - Responder
PLEASE add soldering into required tools… I just spent an hour disassembling the %#*@ thing to be told I need to buy a soldering kit.
Michael Mikulík - Responder
this is why you always read the entire guide at least once before you start a project. but I do agree it should be in the tools list.
ssanchez7610 -
Comentar
Visualizações:
Últimas 24 horas: 17
Últimos 7 dias: 111
Últimos 30 dias: 579
Ao todo: 40,463
