Nintendo DSi XL Upper LCD Replacement
Introdução
Ir para o passo 1Get a better view of what you are playing by replacing a cracked, broken, or faulty Upper LCD in your DSi XL.
O que você precisa
Peças
Ferramentas
Exibir mais…
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Remove the four rubber screw covers on the lower case by prying them up with a push pin.
Use a spudger to pry the microphone cable off the motherboard.
Note that the WiFi board has already been removed here! Including this extra step would be convenient here '-)
Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
-This is where you can replace the charger port. i may change this comment later from May 21-June 5
Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
The battery connectors (socket) on the mother board are extremely fragile, so care should be taken to avoid breaking them.
Other than this, the instructions given are precise and straighforward. I do agree with the other comments about step 20.
Be careful with the battery cable, I ripped the entire socket off with little force.
Remove the screws securing the motherboard to the upper case:
A single 2.5 mm silver Phillips screw
Four 3.7 mm black Phillips screws
the battery connector was (for me) extremely hard to remove. I broke the socket completely off the board hand had to hard solder it directly back.
Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
This step is unnecessary. The ribbon is a total pain in the butt to get back in, and if you dont get it PERFECT, the DS will not even fire back up. Unless it is absolutely necessary to remove it... DON'T !!! ( Personal experience, Everything else was SPOT ON) THANK YOU FOR THE HELP, saved me a lot of $$$
Fantastic! Fixed my daughter's irreplaceable DSi XL - you should see her smiles!! Not sure about step 20 I did this before reading the comments (guess there's a message there). Thanks so much whoever wrote this - you're a legend and you've made a child very happy (and a dad too thereby).
I put mine back together for my daughter with the new bottom screen, but it won't power on. It tries but won't I'm assuming that this ribbon is the cause.
The instructions are perfect though! Great thing to have these instructions it's a tremendous help! :-)
YHWH is the god of all knowledge. Put a piece of transparent tape on the ribbon cable to give more leverage to pull the cable up to slide it into the slot. Also turn the motherboard slightly so that you can get it closer to the cable.
I didn't get mine completely reinserted at first. The symptom I experienced when powering it back on is the power light comes on briefly and the bottom screen light flashes, then they both shut off. No flash from the upper display. Had to try reinserting 3 times before I had it in completely. I agree, DON'T REMOVE if you don't have to.
Turn the DSi XL over and open the display.
Use a pushpin to remove the four plastic screw covers on the front bezel.
Ferramenta utilizada neste passo:Tweezers$4.99
Using a pair of tweezers, pull the microphone out of its housing in the front bezel.
De-route the microphone cable, and pull it through the right hinge.
Using the flat end of a spudger, pry the left speaker out of its socket on the front bezel.
De-route the speaker cable along the top edge of the screen.
In the same manner described above, remove the right speaker from its socket on the front bezel.
Place both speakers on the back of the upper LCD.
Grasp the camera and upper LCD ribbon cables between your thumb and forefinger, pulling them out of the upper case slightly, slide them down through the slit in the upper case.
Rotate the front bezel assembly clockwise so that the ends of the camera and LCD cables slide sideways through the slit in the front bezel.
Lift the camera ribbon cable up off the upper LCD, minding any adhesive that may still be attached.
Insert the flat end of a spudger underneath the adhesive pad on the front of the upper LCD.
Slide the spuder to the left, detaching the adhesive pad along the bottom edge.
17 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all6Comentários do guia
I think a soldering tool needs to be added to the tool list. It may be a given for pros, but for amateur fixit wannabes this could be useful information to have before step 44.
Why is there two Upper LCD Replacements here? makes no sense, Can i have a explanation for this? One is "Difficult", and another is "Very difficult"
there's two different options?? why does this got to be so complicated. is there any place that does replacements for me?
You wait til the final STEP 44 to mention soldering is required…!?!
PLEASE add soldering into required tools… I just spent an hour disassembling the %#*@ thing to be told I need to buy a soldering kit.
this is why you always read the entire guide at least once before you start a project. but I do agree it should be in the tools list.
rust/white powder built up on a screw and can’t unscrew it
Eco - Responder
