Ir para o conteúdo principal
Meta Quest 2 Headset Battery Replacement
O que você precisa
  1. Meta Quest 2 Headset Battery Replacement, Power off your Meta Quest 2: passo 1, imagem 1 %32
    • Hold the power button for three seconds to fully turn off your headset.
    • You'll hear a power down chime, and the LED next to the power button will turn off.
  2. Meta Quest 2 Headset Battery Replacement, Remove the facial interface: passo 2, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Remove the facial interface: passo 2, imagem 2 %32
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
    Photos of each step and interim made this guide so easy to follow.
    For.The.Tech.Of.It - Responder
  3. Meta Quest 2 Headset Battery Replacement: passo 3, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 3, imagem 2 %32
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
  4. Meta Quest 2 Headset Battery Replacement: passo 4, imagem 1 %32
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
  5. Meta Quest 2 Headset Battery Replacement, Unclip the side straps: passo 5, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Unclip the side straps: passo 5, imagem 2 %32 Meta Quest 2 Headset Battery Replacement, Unclip the side straps: passo 5, imagem 3 %32
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
  6. Meta Quest 2 Headset Battery Replacement: passo 6, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 6, imagem 2 %32
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
  7. Meta Quest 2 Headset Battery Replacement, Remove the top strap: passo 7, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Remove the top strap: passo 7, imagem 2 %32
    • Separate the hook and loop strip on the top strap.
  8. Meta Quest 2 Headset Battery Replacement, Remove the head strap: passo 8, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Remove the head strap: passo 8, imagem 2 %32
    • Unthread the top strap from its bracket.
    • Remove the head strap.
  9. Meta Quest 2 Headset Battery Replacement, Remove the eyepiece trim screws: passo 9, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Remove the eyepiece trim screws: passo 9, imagem 2 %32
    • Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
  10. Meta Quest 2 Headset Battery Replacement, Release the eyepiece trim clips: passo 10, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Release the eyepiece trim clips: passo 10, imagem 2 %32
    • Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
  11. Meta Quest 2 Headset Battery Replacement: passo 11, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 11, imagem 2 %32 Meta Quest 2 Headset Battery Replacement: passo 11, imagem 3 %32
    • Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
    • Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
    • Leave the opening pick in the seam to prevent the clips from reengaging.
  12. Meta Quest 2 Headset Battery Replacement: passo 12, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 12, imagem 2 %32 Meta Quest 2 Headset Battery Replacement: passo 12, imagem 3 %32
    • Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
    • During reassembly, press your fingers along the perimeter of the eyepiece trim to clip it back in place.
  13. Meta Quest 2 Headset Battery Replacement, Reposition the eyepiece trim: passo 13, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Reposition the eyepiece trim: passo 13, imagem 2 %32 Meta Quest 2 Headset Battery Replacement, Reposition the eyepiece trim: passo 13, imagem 3 %32
    • Don’t try to fully remove the eyepiece trim in this step. It’s still connected to the headset by a short cable.
    • Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
    • Set the trim down on your work surface, making sure not to strain the cable.
  14. Meta Quest 2 Headset Battery Replacement, Disconnect the face sensor: passo 14, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Disconnect the face sensor: passo 14, imagem 2 %32 Meta Quest 2 Headset Battery Replacement, Disconnect the face sensor: passo 14, imagem 3 %32
    • Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
  15. Meta Quest 2 Headset Battery Replacement: passo 15, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 15, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to pull the face sensor cable out of the ZIF connector.
  16. Meta Quest 2 Headset Battery Replacement, Remove the eyepiece trim: passo 16, imagem 1 %32
    • Remove the eyepiece trim.
  17. Meta Quest 2 Headset Battery Replacement, Reassembly note: passo 17, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Reassembly note: passo 17, imagem 2 %32
    • During reassembly:
    • Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
    • If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
  18. Meta Quest 2 Headset Battery Replacement, Reassembly note: passo 18, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Reassembly note: passo 18, imagem 2 %32 Meta Quest 2 Headset Battery Replacement, Reassembly note: passo 18, imagem 3 %32
    • During reassembly, the face sensor cable can be tricky to connect. Follow these tips to connect the cable:
    • Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
    • Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
    • Use a spudger to press the lock tab down towards the cable to lock it in place.
  19. Meta Quest 2 Headset Battery Replacement, Remove the front cover screws: passo 19, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Remove the front cover screws: passo 19, imagem 2 %32 Meta Quest 2 Headset Battery Replacement, Remove the front cover screws: passo 19, imagem 3 %32
    • Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
    • One recessed in the top-left corner
    • One recessed in the top-right corner
    • Three along the lower edge
  20. Meta Quest 2 Headset Battery Replacement, Release the front cover clips: passo 20, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Release the front cover clips: passo 20, imagem 2 %32
    • The front cover is still held in place by clips along the bottom and side edges.
    • Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
    • Pry with the opening pick to release the front cover clips.
  21. Meta Quest 2 Headset Battery Replacement: passo 21, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 21, imagem 2 %32 Meta Quest 2 Headset Battery Replacement: passo 21, imagem 3 %32
    • Slide the opening clip along the seam and pry to release all the clips securing the front cover.
  22. Meta Quest 2 Headset Battery Replacement, Remove the front cover: passo 22, imagem 1 %32
    • Remove the front cover.
  23. Meta Quest 2 Headset Battery Replacement, Disconnect the top right antenna: passo 23, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Disconnect the top right antenna: passo 23, imagem 2 %32 Meta Quest 2 Headset Battery Replacement, Disconnect the top right antenna: passo 23, imagem 3 %32
    • Use a pair of tweezers to grasp the metal neck of the top-right antenna cable.
    • Lift the antenna connector straight up to disconnect it.
    • Guide the antenna cable out of its metal clip holding it in place.
  24. Meta Quest 2 Headset Battery Replacement, Remove the battery cable bracket: passo 24, imagem 1 %32
    • Use a Phillips screwdriver to remove the three screws securing the battery cable bracket:
    • One 4.4 mm‑long screw
    • Two 2.3 mm‑long screws
  25. Meta Quest 2 Headset Battery Replacement: passo 25, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 25, imagem 2 %32 Meta Quest 2 Headset Battery Replacement: passo 25, imagem 3 %32
    • Use tweezers or your fingers to grasp the battery cable bracket.
    • Twist the cable bracket slightly so that its bottom left corner unclips from the motherboard.
    • Remove the battery cable bracket.
  26. Meta Quest 2 Headset Battery Replacement, Disconnect the battery: passo 26, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Disconnect the battery: passo 26, imagem 2 %32
    • Use a spudger to pry up and disconnect the battery press connector from the motherboard.
    • The battery press connector can disconnect accidentally during reassembly. Check this connector before you attach the bracket.
  27. Meta Quest 2 Headset Battery Replacement, Disconnect the antenna: passo 27, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Disconnect the antenna: passo 27, imagem 2 %32 Meta Quest 2 Headset Battery Replacement, Disconnect the antenna: passo 27, imagem 3 %32
    • Insert one arm of a pair of tweezers under the metal neck of the black antenna cable near the fan assembly.
  28. Meta Quest 2 Headset Battery Replacement, Loosen the front antenna assembly: passo 28, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Loosen the front antenna assembly: passo 28, imagem 2 %32
    • Use a Phillips screwdriver to remove the eight screws securing the antenna assembly to the headset:
    • Four 4.4 mm‑long screws
    • Two 4.8 mm‑long screws
    • Two 10.7 mm‑long screws
    I love the way you color-coded each set of screws to help with organization!
  29. Meta Quest 2 Headset Battery Replacement: passo 29, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 29, imagem 2 %32
    • Use your fingers to flip up the antenna assembly enough to access the cable underneath it.
  30. Meta Quest 2 Headset Battery Replacement: passo 30, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 30, imagem 2 %32
    • Use tweezers to unclip the antenna cable from its metal clip.
  31. Meta Quest 2 Headset Battery Replacement, Remove the front antenna assembly: passo 31, imagem 1 %32
    • Remove the front antenna assembly.
  32. Meta Quest 2 Headset Battery Replacement, Disconnect the fan: passo 32, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Disconnect the fan: passo 32, imagem 2 %32
    • Use tweezers to grab the fan connector and carefully slide it out of its socket.
  33. Meta Quest 2 Headset Battery Replacement, Loosen the LED flex cable: passo 33, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Loosen the LED flex cable: passo 33, imagem 2 %32
    • Use the point of an opening pick to loosen the adhesive securing the LED flex cable from the top of the fan assembly.
  34. Meta Quest 2 Headset Battery Replacement, Remove the fan assembly: passo 34, imagem 1 %32
    • Remove the two screws securing the fan assembly to the headset:
    • One 4.4 mm‑long Phillips screw
    • One 3.6 mm‑long Torx T2 screw
  35. Meta Quest 2 Headset Battery Replacement: passo 35, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 35, imagem 2 %32 Meta Quest 2 Headset Battery Replacement: passo 35, imagem 3 %32
    • Lift the fan assembly and remove it.
  36. Meta Quest 2 Headset Battery Replacement, Remove the heat sink: passo 36, imagem 1 %32
    • Use a Phillips screwdriver to remove the four 2.3 mm‑long screws securing the heat sink to the motherboard.
  37. Meta Quest 2 Headset Battery Replacement: passo 37, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 37, imagem 2 %32
    • Use your fingers to lift the heat sink and remove it.
    • You may feel a bit of resistance. This is normal since the midframe is slightly bonded to the heat sink with thermal paste.
    • You can reuse the thermal paste if you keep it clean. Otherwise, use a spudger to scrape off the old paste and apply a small amount of viscous thermal compound (such as K5 Pro) to the processor.
  38. Meta Quest 2 Headset Battery Replacement, Reassembly note: passo 38, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Reassembly note: passo 38, imagem 2 %32
    • During reassembly, stop here and check if these twelve connectors are properly connected to the motherboard:
    • Two speaker connectors
    • Seven ZIF connectors
    • Two press connectors
    • One antenna connector
    • There are additional connectors on the motherboard, but they shouldn't be connected at this point.
  39. Meta Quest 2 Headset Battery Replacement, Disconnect the speaker connectors: passo 39, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Disconnect the speaker connectors: passo 39, imagem 2 %32 Meta Quest 2 Headset Battery Replacement, Disconnect the speaker connectors: passo 39, imagem 3 %32
    • Use tweezers to grip the left speaker cables at the base of their motherboard connector.
    • Lift the connector gently straight up to disconnect it.
    • During reassembly, use the flat end of a spudger to press the speaker cable into the rubber holding clip.
  40. Meta Quest 2 Headset Battery Replacement: passo 40, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 40, imagem 2 %32 Meta Quest 2 Headset Battery Replacement: passo 40, imagem 3 %32
    • Repeat the disconnection procedure for the right speaker connector.
  41. Meta Quest 2 Headset Battery Replacement, Disconnect the ZIF socket flex cables: passo 41, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Disconnect the ZIF socket flex cables: passo 41, imagem 2 %32
    • Use tweezers to gently peel the black tape covering the two top flex cables.
    • Set the tape aside to be reused during reassembly.
    Be careful not to pull the cable from the connector. Take extra care on this step.
    Carl Gilbert - Responder
  42. Meta Quest 2 Headset Battery Replacement: passo 42, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 42, imagem 2 %32 Meta Quest 2 Headset Battery Replacement: passo 42, imagem 3 %32
    • Use a clean fingernail or a spudger to pry up the lock tab securing the top left camera cable.
  43. Meta Quest 2 Headset Battery Replacement: passo 43, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 43, imagem 2 %32
    • Grasp the top left camera cable with tweezers and slide it out of its ZIF connector.
  44. Meta Quest 2 Headset Battery Replacement: passo 44, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 44, imagem 2 %32
    • Move counter-clockwise around the motherboard and disconnect the remaining six ZIF connectors:
    • Power button and LED board
    • Bottom left camera
    • Bottom right camera
    • Top right camera
    • Face sensor interconnect cable
    • Indicator LED cable
  45. Meta Quest 2 Headset Battery Replacement, Disconnect the press connectors: passo 45, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Disconnect the press connectors: passo 45, imagem 2 %32 Meta Quest 2 Headset Battery Replacement, Disconnect the press connectors: passo 45, imagem 3 %32
    • Use a spudger to pry up and disconnect the display cable.
  46. Meta Quest 2 Headset Battery Replacement: passo 46, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 46, imagem 2 %32 Meta Quest 2 Headset Battery Replacement: passo 46, imagem 3 %32
    • Use a spudger to pry up and disconnect the USB‑C and headphone jack cable.
  47. Meta Quest 2 Headset Battery Replacement: passo 47, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 47, imagem 2 %32 Meta Quest 2 Headset Battery Replacement: passo 47, imagem 3 %32
    • Insert one arm of a pair of tweezers under the metal neck of the side antenna cable.
  48. Meta Quest 2 Headset Battery Replacement, Remove the motherboard: passo 48, imagem 1 %32
    • Remove the five screws securing the motherboard to the headset:
    • Four 3.8 mm‑long Phillips screws
    • One 6 mm‑long 3.5 mm hex standoff screw
    hex and left down screw with washer
    k i - Responder
  49. Meta Quest 2 Headset Battery Replacement: passo 49, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 49, imagem 2 %32
    • At this point, the motherboard should be loose, with some thermal paste sticking it to the headset.
    • Use a spudger to pry up and separate the motherboard from the headset.
    • If it feels like the motherboard is caught on something, check that all the cables are disconnected from it.
  50. Meta Quest 2 Headset Battery Replacement: passo 50, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 50, imagem 2 %32
    • Remove the motherboard.
  51. Meta Quest 2 Headset Battery Replacement, Remove the camera covers: passo 51, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Remove the camera covers: passo 51, imagem 2 %32 Meta Quest 2 Headset Battery Replacement, Remove the camera covers: passo 51, imagem 3 %32
    • Use your fingers or tweezers to peel and remove the two camera covers from the top cameras.
    • During reassembly, align the cutouts on the camera covers to their respective pegs on the headset.
    • The camera covers have different alignment cutouts and aren't interchangeable.
  52. Meta Quest 2 Headset Battery Replacement, Loosen the screen and lens assembly: passo 52, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Loosen the screen and lens assembly: passo 52, imagem 2 %32
    • Peel and remove the black tape covering the antenna cable.
    • Set this tape aside to be reused during reassembly.
  53. Meta Quest 2 Headset Battery Replacement: passo 53, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 53, imagem 2 %32 Meta Quest 2 Headset Battery Replacement: passo 53, imagem 3 %32
    • Use tweezers to lift and unclip the black antenna cable from the metal grounding clips.
  54. Meta Quest 2 Headset Battery Replacement: passo 54, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 54, imagem 2 %32 Meta Quest 2 Headset Battery Replacement: passo 54, imagem 3 %32
    • Use a spudger to pry up the black lock tab securing the left microphone flex cable to the left interconnect cable.
    • Use your fingers or tweezers to slide the microphone cable out of the ZIF connector.
  55. Meta Quest 2 Headset Battery Replacement: passo 55, imagem 1 %32
    • Repeat the procedure to disconnect the right microphone cable.
  56. Meta Quest 2 Headset Battery Replacement: passo 56, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 56, imagem 2 %32
    • Slide the point of an opening pick underneath the battery flex cable to loosen the adhesive securing it from the headset.
    Tried this and the display cable broke because it probably wasn't adhesive
    Moses D - Responder
  57. Meta Quest 2 Headset Battery Replacement: passo 57, imagem 1 %32 Meta Quest 2 Headset Battery Replacement: passo 57, imagem 2 %32 Meta Quest 2 Headset Battery Replacement: passo 57, imagem 3 %32
    • Some interconnect cables have been removed in the following images for clarity purposes. You don't have to remove them as part of the procedure.
    • Use a Phillips screwdriver to remove the four screws securing the screen and lens assembly to the frame:
    • Two 6.5 mm‑long screws
    • Two 7.7 mm‑long screws
  58. Meta Quest 2 Headset Battery Replacement, Remove the screen and frame assembly: passo 58, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Remove the screen and frame assembly: passo 58, imagem 2 %32 Meta Quest 2 Headset Battery Replacement, Remove the screen and frame assembly: passo 58, imagem 3 %32
    • Grasp the screen and lens assembly with your fingers.
    • Slowly lift and separate the assembly from the outer shell, taking care to reposition any cables that get in the way.
    • Remove the screen and lens assembly.
  59. Meta Quest 2 Headset Battery Replacement, Reassembly note: passo 59, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Reassembly note: passo 59, imagem 2 %32 Meta Quest 2 Headset Battery Replacement, Reassembly note: passo 59, imagem 3 %32
    • During reassembly, be careful not to trap the twelve cables as you insert the lens assembly into the outer shell:
    • Three cables along the top edge—two flex cables and one LED flex cable
    • Two cables in the top right corner—the battery connector and an antenna cable
    • Two cables along the right edge—an antenna cable and a wide flex cable
    • Two flex cables along the bottom edge
    • Three cables along the left edge—one antenna cable, one flex cable, and one speaker cable
    • You can use a rubber band to help secure the cables out of the way.
  60. Meta Quest 2 Headset Battery Replacement, Unfasten the headset battery: passo 60, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Unfasten the headset battery: passo 60, imagem 2 %32
    • Use a Phillips screwdriver to remove the six 4.5 mm‑long screws securing the battery to the outer shell:
    • Two along the front edge
    • Four along the back edge
  61. Meta Quest 2 Headset Battery Replacement, Remove the strap bracket: passo 61, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Remove the strap bracket: passo 61, imagem 2 %32
    • Use your fingers or tweezers to remove the top strap bracket.
  62. Meta Quest 2 Headset Battery Replacement, Remove the headset battery: passo 62, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Remove the headset battery: passo 62, imagem 2 %32
    • Lift and remove the headset battery.
  63. Meta Quest 2 Headset Battery Replacement, Remove the face sensor interconnect cable: passo 63, imagem 1 %32 Meta Quest 2 Headset Battery Replacement, Remove the face sensor interconnect cable: passo 63, imagem 2 %32 Meta Quest 2 Headset Battery Replacement, Remove the face sensor interconnect cable: passo 63, imagem 3 %32
    • Slide an opening pick under the face sensor interconnect cable to loosen the adhesive securing it to the battery.
    • Remove the sensor interconnect cable.
    • Transfer the cable to your replacement battery. Be sure to align it using the two alignment cutouts, and use some double-sided tape such as Tesa tape to secure it.
  64. Meta Quest 2 Headset Battery Replacement: passo 64, imagem 1 %32
    • Only the headset battery remains.
    You can remove the three T2 screws and to lift the metal cover off of the battery assembly to access the cell. The cell is secured with weak adhesive. Pour a bit of IPA into the tray and after a few minutes, use picks to pry the cell free of tray. Take your time with this to avoid cracking the tray.
    Once the cell is free, you can carefully peel away the strip of black tape from the top of the cell which allows you to slide the plastic cap off the cell and expose the main positive and negative terminals that directly connect the cell to the protection pcb. This provides a safer way to test the cell.
    You can detach the cell from the protection board and replace it with one that will fit the tray or try to charge it.
    My cell measured 2.0V. I am attempting to use a cheap TP4056 module to charge the cell up to full. A TP4056 will trickle charge a low cell up to about 3.5V and then will switch to normal charging rate up to 4.2V. I'll post a follow up comment if I have any success with this.
    Jason Buschman - Responder
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
15 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
284.882 Reputação
Autoria de 588 guias
Equipe
iFixit Membro de iFixit
Staff
120 Membros
Autoria de 20.056 guias
11Comentários do guia
I followed this to change the battery in my son's headset amd I have to say it was a life saver. Very well written and detailed, the photos and coloured circles were of particular help. Thanks for the effort - I'm about to use it again to replace the motherboard! Really frustrating that with a few simple design changes Meta could have made this a five minute job, but well done for helping us all out! :)
Paul Newman - Responder
This was a well written and very thorough how to guide that tool a lot of dedication and I commend you for it. I am contemplating taking on this endeavor on behalf of my adult son who was gracious enough to allow me to use his machine and I am now a huge fan, just in time for the battery to wear out. Still debating if I will attempt but know for sure I would not even begin.to consider it without your guide. Thank you for such a selfless endeavor!
Michael Johnson - Responder
I disassembled my quest because I have water damage. I have cleaned all corrosion, but I would like tot test the battery before I reassemble. How can I check if the battery is in good condition?
Cas - Responder
This guide made the job fun. Thanks!
john - Responder
where do you get the replacement battery? Thank you!
Kathryn Greacen - Responder
I found a couple on Amazon, which I imagine you have by now as well, but there may be better options available.
Jon R -
One Weird Trick Meta Doesn't Want You To Know: Amazing set of instructions. Thank you so much for your effort. It is a daunting task to replace the Occulus battery, but this guide has helped to ease the pain as much as possible.
Jon R - Responder
Fantastic guide. Really easy to follow. I struggled with the tape on step 41 and accidentally pulled a cable out before releasing the clip so take care on this step.
Mmm osea las baterías están justo detrás de las pantallas, si explotan dios no lo quiera adiós a los ojos ?!
Raquel Diaz - Responder
Comentar
Visualizações:
Últimas 24 horas: 59
Últimos 7 dias: 511
Últimos 30 dias: 2,060
Ao todo: 36,395
