Ir para o conteúdo principal
Joy-Con Battery Replacement
Jairo
Jairo e 6 outros colaboradores
Última atualização em April 16, 2025
5 - 10 minutos
Moderado
Introdução
Ir para o passo 1
This guide will show you how to replace the battery in your Joy-Con controller.
There are a few minor differences between the left and right Joy-Cons. These steps apply to both Joy-Cons.
O que você precisa
Fix Kit
Este kit contém todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
Vídeo de Apresentação
  1. Joy-Con Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the four Tri-Point Y00 screws from the back panel of the Joy-Con.
  2. Joy-Con Battery Replacement: passo 2, imagem 1 %32 Joy-Con Battery Replacement: passo 2, imagem 2 %32 Joy-Con Battery Replacement: passo 2, imagem 3 %32
    • Insert an Opening Pick into the bottom edge of the back panel (opposite the shoulder buttons).
    • Slowly slide the flat edge of your Opening Pick up the side of the Joy-Con.
    • Be careful not to slide the Opening Pick too far inside the Joy-Con. This may damage the inner components. The back panel loosens fairly easily, so not much pressure is needed.
  3. Joy-Con Battery Replacement: passo 3, imagem 1 %32 Joy-Con Battery Replacement: passo 3, imagem 2 %32
    • Open the Joy-Con like a book, with the charging rail facing away from you.
    • Don’t try to fully remove the back panel yet. There are still two cables connecting the charging rail to the motherboard.
  4. Joy-Con Battery Replacement: passo 4, imagem 1 %32 Joy-Con Battery Replacement: passo 4, imagem 2 %32 Joy-Con Battery Replacement: passo 4, imagem 3 %32
    • Use a Spudger to gently pry the battery connector from its socket on the motherboard. This will keep the Joy-Con from powering on during the repair.
    • Use caution while working around the vibration motor cable that runs close to the battery connector. If you are replacing the battery in a right Joy-Con, you will also need to work around an antenna cable during this step.
    Beim wiedereinstecken des Akkus hat sich für mich bewährt die Flache seite des Spudgers etwas zwischen die beiden Akkukabel zu stecken.
    Außerdem sollte man darauf achten, dass wenn man wie in den Bildern zu sehen den Akkustecker von der Platine entfernt nicht ausversehen die Bauteile von der Platine bricht die unmittelbar vor dem Stecker sind
    Sontha - Responder
    Hallo Sontha,
    danke für die Anmerkung. Viel Spaß mit deiner Switch!
    Viele Grüße!
    Fabian Neidhardt -
  5. Joy-Con Battery Replacement: passo 5, imagem 1 %32 Joy-Con Battery Replacement: passo 5, imagem 2 %32 Joy-Con Battery Replacement: passo 5, imagem 3 %32
    • Insert an Opening Pick between the battery and the Joy-Con housing.
    • Gently pry out the battery, which is lightly taped in place.
    • To install a new battery, press it into place and reconnect it. If the double-sided tape holding the battery in place came out with the battery, replace it before you install the new battery.
    thx for making this process ez and affordable.
    definitely saved the environment of dumping 4 perfectly reusable joy-cons.
    Noam Gonen - Responder
    Thank you Ifixit, I changed my battery fairly easy. Your guide has been very helpful!
    Flora Flex - Responder
    Easy-peasy. Joy-Con now works while disconnected again. Thanks, ifixit!
    barefootedmike - Responder
    What width of tape should I buy for this? The link to the store for the double sided-tape shows four choices (1, 2, 4 or 8mm). The kit we can buy comes with a tape card, but I need to change four batteries, and buying four kits would be a waste.
    Feather Antennae - Responder
Conclusão
71 outras pessoas executaram este guia.
Jairo
Membro desde: 02/09/12
5.259 Reputação
Autoria de 2 guias
Equipe
iFixit Membro de iFixit
Staff
121 Membros
Autoria de 19.827 guias
11Comentários do guia
Bonjour, après avoir suivi les étapes tout fonctionne ,SAUF la recharge … à savoir également que je me suis trompé dans la commande de la nouvelle batterie, celle-ci étant d'une capacité plus faible
Ced - Responder
Bonjour Ced ! Nous sommes désolés de l’apprendre. Avez-vous essayé de calibrer la batterie ? Veuillez prendre contact avec notre service client (support@ifixit.com pour la boutique américaine ou eustore@ifixit.com pour la boutique européenne et française) en indiquant votre numéro de commande. Ce sera un plaisir de vous porter assistance !
Claire Miesch -
Bei mir ging beim roten Joy Con oder Akku nicht mehr, ich hab ihn jetzt auseinandergeschraubt, das Kabel vom Akku gelöst und wieder eingesteckt.
als ich alles zusammengebaut habe ging er. Es war wahrscheinlich nur das Kabel was nicht richtig drin war.
Tobias No name - Responder
Hello, i'm unsure what to do now but I have replaced my battery but my switch still doesn't show the presence of my right joy-con. I opened up the joy-con while connected to the switch and the battery is only charging at 1.2v (without the battery the pins are the same) could it be the charging rail? Any tips would be appreciated. Thanks!
Logan Marynowich - Responder
Mir fiel der linke Joy Con bei einer wilden Play Session auf den Boden und funktioniert nicht mehr. Dank Anleitung und iFixit Set konnte ich den Joy Con öffnen und das Kabel des Akkus wieder fest einstecken - Problem gelöst. Danke ifixit!
Mike - Responder
What type of connector is on the battery.is jst molex dupont Jr futaba or something?can you tell me?
Ravinder Singh Negi - Responder
close up video of your hands are hairy like a guy's
travelox - Responder
What is the little mat with the ifixit logo on it that came with the kit? I thought it was a mini magnetic mat, but I tried to get a screw to stick to it and it didn't. It's very flexible and looks like it should be peelable, but I didn't want to attempt this on the off chance it is something else.
As far as the guide itself, it was very easy to follow and worked perfectly for me. Thank you!
Jordan - Responder
I believe that is replacement tape or adhesive for the battery, incase yours came off of the joycon case with the battery!
Caleb Prince -
Vielen Dank! Meine zwei Joy Cons haben nun wieder frische Akkus! :)
Franz Seidl - Responder
Hi! I recently preformed this repair successfully, but now the buttons on the rail do not work. However the rail itself still works and connects to the switch. There are no broken ribbon cables or loose connections to my knowledge. Could it be the way the ribbon cables are positions inside the casing, maybe I placed them back in wrong? Any help would work, thanks!
Caleb Prince - Responder
Comentar
Visualizações:
Últimas 24 horas: 97
Últimos 7 dias: 598
Últimos 30 dias: 2,739
Ao todo: 145,766
