Google Pixel 7 Pro Screen Replacement
Introdução
Vá para o passo 1This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the screen for your Google Pixel 7 Pro.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Your new replacement screen should come with the fingerprint reader already attached. If not, you will need to reinstall the original fingerprint reader to your new replacement screen and recalibrate the reader to maintain its functionality.
Caution: The Pixel 7 Pro contains class 1 lasers. Disassembly could result in exposure to invisible infrared laser emissions.
Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
You'll need replacement adhesive in order to complete this repair.
O que você precisa
Fix Kit
Este kit contém todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
Vídeo de Apresentação
Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
During the removal procedure, make sure to insert your opening picks in the right position to avoid separating the screen from its safety frame.
There are several plastic clips around the whole screen. If your opening pick gets blocked during the screen removal procedure, you've inserted your pick too deep underneath the screen.
Ferramenta utilizada neste passo:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your phone.
Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
Squeeze the cups together to apply suction.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the phone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
Insert an opening pick into the gap.
The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a third opening pick underneath the bottom left corner of the screen.
Slide the opening pick along the left edge of the screen to slice the adhesive and to release the plastic clips.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick at the top left corner of the screen.
Slide the opening pick along the top edge of the phone to slice the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive and release the right plastic clips.
Lift the right edge of the screen up and towards the left side of the device, like opening a book.
Rest the screen upside down and parallel to the frame.
Ferramenta utilizada neste passo:Tweezers$4.99
Insert one arm of a pair of tweezers into the opening at the upper end of the display cable bracket.
Push the bracket inwards and pry up to release it.
Use a pair of tweezers to remove the display cable bracket by pulling it from underneath the midframe and in direction of the camera.
Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
Remove the screen.
If you replaced your screen, check the front-facing camera hole and the sensor cutout on your replacement screen, and remove any remaining liners.
Check the frame for deformed grounding springs that stick straight up. These spring contacts should rise at a shallow angle. Use your finger to gently bend any deformed springs downward.
Follow this guide if you're using custom-cut adhesives for your device. Follow this guide in case you're using a pre-cut adhesive card.
If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 7 Pro answers community for help.
130 outras pessoas executaram este guia.
99 comentários
To get the fingerprint scanner to work... Fingerprint scanner not working after replacing screen. Pixel 6 Pro
After doing a few of these, using the fingerprint calibration tool is always needed. https://pixelrepair.withgoogle.com/udfps
I think it should be included in the final steps for completeness.
Also, the plastic bracket on the back of the screen usually is more willing to separate from the screen than from the phone chassis. I think this may lead to confusion for some people who may try to install the new screen over the old plastic. Some mention of this would be helpful.
All guides say we have to recalibrate the fingerprint sensor after a screen replacement by going here https://pixelrepair.withgoogle.com/udfps
Problem is that this does not work anymore. With a Pixel 7 Pro it says software failed to install. Looking at Android and Google forums is seems a common problem that broke this year. Is there another way to install the fingerprint calibration software on the phone without that link above??
I never change any mobile phone parts.
Should I try it?
Yes. It worked like a charm. I just followed the steps, and after calibrating the fingerprint sensor, everything was working 100%.
