Ir para o conteúdo principal
Atari 5200 Motherboard Cleaning
Zach Petryszyn
Zach Petryszyn e 12 outros colaboradores
Última atualização em December 21, 2021
15 - 30 minutos
Fácil
Introdução
Ir para o passo 1
This guide will explain how to disassemble your Atari system in order to clean the dust from the motherboard. Dust build up can cause electrical problems for your Atari system, possibly causing it run very slow or not turn on. [WARNING: follow instructions as carefully as possible as failure to do so can damage your system.]
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Atari 5200 Motherboard Cleaning, Atari 5200 Motherboard Cleaning: passo 1, imagem 1 %32
    • Flip your Atari Entertainment System over to its top so you can see the bottom. You'll see seven screws holding your system together. Use a Philips #0 screwdriver to remove all seven screws.
  2. Atari 5200 Motherboard Cleaning: passo 2, imagem 1 %32
    • Flip the Atari Entertainment System back over so that you can now see the top.
    • Use your hands to gently remove the top by sliding it off.
  3. Atari 5200 Motherboard Cleaning, Access: Granted: passo 3, imagem 1 %32
    • You will now have access to the motherboard.
    • The motherboard can be cleaned with a moist paper towel.
    • Be sure the motherboard is fully dry before playing your Atari Entertainment System or you may damage it!
Conclusão
Uma outra pessoa concluiu este guia.
Zach Petryszyn
Membro desde: 09/26/14
21 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 13-1, Staggers Fall 2014 Membro de USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Membros
Autoria de 17 guias
1Comentário do guia
This "tutorial" does not even cover gaining access to the motherboard.
Dannot - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 27
Ao todo: 2,810
