Ir para o conteúdo principal
The Apple Watch is one step closer to a super spy accessory with its Series 3 capable of making phone calls. What does a watch look like when Apple sticks a phone in it? Since teardowns are our calling we figure we'll dial right in!
Hot new tech is calling, will you pick up? Dial Facebook, Twitter, and Instagram to get on the party line for the newest gizmos!
O que você precisa
Ferramentas
Exibir mais…
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Apple Watch Series 3, use o nosso manual de serviço.
  1. Apple Watch Series 3 Teardown, Apple Watch Series 3 Teardown: passo 1, imagem 1 %32
    • What's that in your shiny new Apple Watch?
    • Second-generation OLED Retina display with Force Touch
    • Consistent with the original Apple Watch, the Series 3 comes in two sizes: 38 mm (272 × 340 pixels, 290 ppi) and 42 mm (312 × 390 pixels, 302 ppi).
    • Custom-designed Apple S3 SiP (System in Package)
    • Optional LTE and UMTS, built in GPS/GLONASS + NFC + Wi-Fi 802.11b/g/n 2.4 GHz + Bluetooth 4.2
    • Accelerometer + gyroscope + heart rate sensor + microphone + speaker + barometric altimeter + ambient light sensor
    • Water resistance rating (up to 50 meters)
    • WatchOS 4
  2. Apple Watch Series 3 Teardown: passo 2, imagem 1 %32 Apple Watch Series 3 Teardown: passo 2, imagem 2 %32
    • Before we get inside, put on your X-ray glasses for a sneak peek.
    • Many Bothans died to bring us this information. Just kidding. This image is courtesy of the friendly X-ray experts at Creative Electron.
    • While the overall layout is fairly unchanged from the original Apple Watch we tore down and X-rayed in 2015, it looks like there may be a few extra solder pads under the speaker (top right of this image).
  3. Apple Watch Series 3 Teardown: passo 3, imagem 1 %32 Apple Watch Series 3 Teardown: passo 3, imagem 2 %32 Apple Watch Series 3 Teardown: passo 3, imagem 3 %32
    • Time for a quick check of the back to make sure we bought the right watch.
    • Yep, this here is an Apple Watch Series 3, the most exclusive and top of the line Apple wrist computer, offering unparalleled computing power and fashion for the next 51 weeks.
    • We even got the LTE model!
    • Next to that secret diagnostic port we picked out a new model number: A1889.
  4. Apple Watch Series 3 Teardown: passo 4, imagem 1 %32 Apple Watch Series 3 Teardown: passo 4, imagem 2 %32 Apple Watch Series 3 Teardown: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    iOpener
    $17.99
  5. Apple Watch Series 3 Teardown: passo 5, imagem 1 %32 Apple Watch Series 3 Teardown: passo 5, imagem 2 %32
    • Cables de-ZIF'd, we're clear to get a look at the display.
    • Spec-wise, the display is unchanged from the Series 2, with one key difference—it now functions as a multifrequency (LTE?) antenna.
    • We'll be testing compatibility to see if the displays really are interchangeable.
    • This display has one fewer IC than last year. Probably wasn't important.
    • Analog Devices 343S00092 touch controller
    • NXP Semiconductor PN80V NFC module
    • Texas Instruments TPS36372 display power management (likely)
    • Empty solder pad (20211CP TD1628A goes here?)
  6. Apple Watch Series 3 Teardown: passo 6, imagem 1 %32 Apple Watch Series 3 Teardown: passo 6, imagem 2 %32 Apple Watch Series 3 Teardown: passo 6, imagem 3 %32
    Mako Driver Kit - 64 Precision Bits
    $39.95
    • As in the prior version, further access is barred by a tiny tri-point screw—one of 64 possible contingencies we've come prepared for.
    • The top third of the watch is labeled "Taptic Engine," and that's mostly true—but the label also hides a bracket that guards, among other things, the battery connector we're searching for.
    • Time to pick away the power pack and see what gives this watch its all-day go-juice.
    • Professional teardown engineer on a closed track. Do not attempt battery replacement on the go.
  7. Apple Watch Series 3 Teardown: passo 7, imagem 1 %32 Apple Watch Series 3 Teardown: passo 7, imagem 2 %32
  8. Apple Watch Series 3 Teardown: passo 8, imagem 1 %32 Apple Watch Series 3 Teardown: passo 8, imagem 2 %32 Apple Watch Series 3 Teardown: passo 8, imagem 3 %32
    • So far so good. We pull out the standard Force Touch sensor/gasket, equipped with the same Analog Devices AD7149 capacitance sensor controller that we found in the Series 2.
    • Continuing our parts-picking spree, we pluck out the Taptic Engine, seemingly unchanged from watches yore.
    • Then out pops the antenna array, including what we believe to be the GPS antenna.
  9. Apple Watch Series 3 Teardown: passo 9, imagem 1 %32 Apple Watch Series 3 Teardown: passo 9, imagem 2 %32 Apple Watch Series 3 Teardown: passo 9, imagem 3 %32
    • The plucking continues, as we remove the self-emptying speaker, designed to sonically blast out water after your watch takes a dip.
    • After an entirely Series 2-ish experience, we're finally rewarded with something new—a whole new section of RF chips, surely responsible for handling the added LTE functionality.
    • In another new twist, the air vent hole next to the microphone is now populated by what looks like a barometric pressure sensor.
    • Apple touted a new barometric altimeter when it introduced the Series 3 at the Steve Jobs Theater—much to our confusion, since we already found a barometer in last year's model.
    • Time to pull this board!
  10. Apple Watch Series 3 Teardown: passo 10, imagem 1 %32 Apple Watch Series 3 Teardown: passo 10, imagem 2 %32
  11. Apple Watch Series 3 Teardown: passo 11, imagem 1 %32 Apple Watch Series 3 Teardown: passo 11, imagem 2 %32 Apple Watch Series 3 Teardown: passo 11, imagem 3 %32
    • Last call: back cover. It's press-fit over a teflon-like O-ring, but a thumbs-up and a firm push relieves it of duty.
    • The material has been standardized across watch models and souped up to snazzy ceramic, replacing the previous Ion-X or Sapphire options.
    • It also houses the PPG sensor array that is responsible for sensing heart rate.
    • It would've been cool to see some change from the Series 2 after complaints about accuracy in previous models. As far as wearables go, however, the Apple Watch is the best of the bad.
    • Also it appears that the wireless charging coil has been slightly modified to support most Qi wireless chargers.
    • Lastly, with the new barometric altimeter taking the spot next to the microphone, where did the air vent go? Answer: hiding out right here, next to the diagnostic port.
  12. Apple Watch Series 3 Teardown: passo 12, imagem 1 %32 Apple Watch Series 3 Teardown: passo 12, imagem 2 %32 Apple Watch Series 3 Teardown: passo 12, imagem 3 %32
    • Here's all the clockwork watchwork!
    • Final big thanks to Circuitwise for giving up a bit of their weekend to help us out!
    • And thanks again to Creative Electron for putting the X(-ray) in "excellent!"
  13. Considerações finais
    • Watch band replacements remain fast and simple.
    • Screen replacements are difficult but do-able—it's the first thing to come off, and detaches via simple ZIF connectors.
    • Battery replacements are tricky but fairly straightforward once you're inside, provided you're armed with a Y000 screwdriver.
    • While not proprietary, incredibly tiny tri-point screws are a repair hinderance.
    • Replacing any of the component cables requires microsoldering.
    • The mostly resin-encased S3 system makes most board-level repairs impossible.
    Índice de reparabilidade
    6
    Reparabilidade 6 de 10
    (10 é o mais fácil de reparar)
47 comentários
Great ! I was waiting for this since the day it was shown at the launch ! First to comment as well I guess
Yolo - Responder
is the rear housing the same as the series 2 as well?
during the announcement, they claimed the watch was made a little thicker.
karl - Responder
What’s the purpose of the air vent that began with Series 2? It’s clearly not for barometric readings since Series 2 lacked a barometric altimeter.
Andrew Estock - Responder
Not sure of I didn't See a barometer at the Apple Watch
eisblock -
does apple tv 4k teardown coming soon? i am curious about power supply voltage and ampere. nice btw.
Muhammad Faisal Kemal - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 29
Últimos 7 dias: 147
Últimos 30 dias: 448
Duração total: 250,923
