Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Apple Watch, use o nosso manual de serviço.
  1. Apple Watch X-ray Teardown, Apple Watch X-ray Teardown: passo 1, imagem 1 %32 Apple Watch X-ray Teardown, Apple Watch X-ray Teardown: passo 1, imagem 2 %32 Apple Watch X-ray Teardown, Apple Watch X-ray Teardown: passo 1, imagem 3 %32
    • Once upon a time, Creative Electron uploaded an X-ray teardown of the iPhone 6.
    • We geeked out. Hard. And proceeded to make them our new BFF.
    • More recently, some lucky tech writers got to spend the day playing with magic science at their offices in sunny San Marcos, CA.
    • Creative Electron's specs include:
    • A line of totally cool X-ray inspection systems
    • Amazing employees
    • Great insight
  2. Apple Watch X-ray Teardown: passo 2, imagem 1 %32 Apple Watch X-ray Teardown: passo 2, imagem 2 %32 Apple Watch X-ray Teardown: passo 2, imagem 3 %32
    • One of the first things we notice is that, while the battery dominates the interior space of the watch, it barely shows up in X-ray images. (It's the sort of smoky-looking patch on the right.)
    • Like everything in the Apple Watch, the battery was designed to be small and super thin. In larger devices such as smartphones, the thicker batteries absorb more X-rays, and thus are easier to spot.
    • The densest (and therefore darkest) components in the picture are the magnets—such as in the speakers on the lower left, the Taptic Engine, and the small magnet in the center that aligns the charger.
  3. Apple Watch X-ray Teardown: passo 3, imagem 1 %32
    • It's apples to oranges as we compare the Apple Watch to a Nike+ Sport GPS.
    • The Apple Watch is far more densely packaged, with virtually no extra space, and sports a very noticeable inductive charging coil.
    • The Nike features (comparatively) giant screws, spacious chip mapping, and sensors that spill out beyond the central watch body.
  4. Apple Watch X-ray Teardown: passo 4, imagem 1 %32 Apple Watch X-ray Teardown: passo 4, imagem 2 %32 Apple Watch X-ray Teardown: passo 4, imagem 3 %32
    • First stop, the Digital Crown. Apple made a lot of fuss over how cool this is, so of course we put it in a box and shot it full of rays.
    • Despite its tiny size, the crown features a very classical mechanical design—threaded components and a hefty bushing.
    • As we saw in our original teardown, the portion of the crown shaft on the inside of the watch body is covered in tiny notches. Immediately below this, what appears to be an optical emitter/sensor reads as the notches spin by.
    • Boom, encoder.
  5. Apple Watch X-ray Teardown: passo 5, imagem 1 %32 Apple Watch X-ray Teardown: passo 5, imagem 2 %32 Apple Watch X-ray Teardown: passo 5, imagem 3 %32
    • Moving along the outer edge, we come to the side button.
    • Even under the X-ray, this button looks distinctly Apple.
    • Not one to waste a good design palette, Apple opted for something that looks very similar to the iPhone 6's spring-loaded power button.
  6. Apple Watch X-ray Teardown: passo 6, imagem 1 %32 Apple Watch X-ray Teardown: passo 6, imagem 2 %32 Apple Watch X-ray Teardown: passo 6, imagem 3 %32
    • The Taptic Engine—and the shaking weight that composes it—is one of the darkest, and therefore densest components in the watch.
    • In order to get the most bang (vibration) for its buck (space), Apple packed a tiny, heavy weight into its Taptic Engine to provide the vibratory feedback to your wrist.
    • Even though it's tiny, it still consumes a lot of the Apple Watch's precious interior space. While some users would rather see that space go to a larger battery, Apple clearly sees the Taptic Engine as an important part of the user experience.
    • Thanks to the X-ray, you can see the "engine" is a linear actuator. The springs move the weight up and down (side to side, when on your wrist) to create the vibration effect.
    • Creative Electron has a great video of some vibration motors running in real time—inside an x-ray machine. Rad.
  7. Apple Watch X-ray Teardown: passo 7, imagem 1 %32 Apple Watch X-ray Teardown: passo 7, imagem 2 %32 Apple Watch X-ray Teardown: passo 7, imagem 3 %32
    • The next pressing matter, is that of the band-release button.
    • A seemingly simple mechanism is actually dense with dual layers of interlocking spring-powered pins.
    • And what's that to the right of the band? The mysterious diagnostic port.
    • Tell us your secrets! Unfortunately, X-rays don't make this Watch any less tight-lipped.
  8. Apple Watch X-ray Teardown: passo 8, imagem 1 %32 Apple Watch X-ray Teardown: passo 8, imagem 2 %32
    • Fortunately, X-ray vision does reveal the secrets of board-level components:
    • Inductors reveal their wire coils.
    • Capacitors remain dark and elusive with all their wrapped dielectric layers.
    • Resistors are almost invisible, except for the solder that melts and creates a fillet on the edges of the resistor.
    • Invisible crystals are hidden beneath protective walls, but close to the processor to minimize latency and signal interference.
    • While the dots and swirls in the second image may look like single-celled organisms, they are not.
    • The swirls are the wire coils of the inductive charger. The large, dark blobs are solder mounts for a chip, and the wavy background pattern is the flash memory chip. More on that later...
  9. Apple Watch X-ray Teardown: passo 9, imagem 1 %32
    • The precision of the layout of the electronics is incredible. Chip-scale packages (CSPs) litter the board, and with such tight space, accuracy is key—which means production costs are high.
    • Much of the cost is due to the board being heavily populated with CSPs as opposed to larger soldered packages.
  10. Apple Watch X-ray Teardown: passo 10, imagem 1 %32 Apple Watch X-ray Teardown: passo 10, imagem 2 %32 Apple Watch X-ray Teardown: passo 10, imagem 3 %32
    • And here it is. The Apple S1 computer-on-chip. Where we were earlier thwarted, we've got a better look with some interesting analysis.
    • By encasing the S1 in resin, Apple was able to make use of wire bonding to make many of the connections between chips in Package on Package (PoP) stacks. These are incredibly small bonds, typically 10-17 microns.
    • This saves space, as soldered packages would be thicker, but requires a whole new level of manufacturing expertise.
    • Here's the one exposed chip on the S1, an STMicroelectronics gyroscope and accelerometer.
  11. Apple Watch X-ray Teardown: passo 11, imagem 1 %32 Apple Watch X-ray Teardown: passo 11, imagem 2 %32
    • Our friends at Chipworks have spent the last two weeks hard at work cracking the S1. Here's what they found:
    • The Apple S1 System in Package (SiP) is composed of over 30 individual components, attached to a single board that is then overmolded with a silica or aluminum composite resin—similar to conventional IC packaging, but for an entire board.
    • At the heart of the S1, Apple's new APL0778 processor is fabbed on Samsung's 28 nm LP process.
    • This represents a slight step backward from Apple's 20 nm A8 processor, which shipped with the iPhone 6 in September. Power efficiency would seem to be, if anything, even more critical in the Apple Watch than in the iPhone. With Samsung now fabbing chips on an even smaller 14 nm scale, we expect improved battery life in the next Apple Watch.
    • Check out Chipworks' full analysis here.
  12. Apple Watch X-ray Teardown: passo 12, imagem 1 %32
    • The flash storage looks flip-chipped onto the substrate, with the solder points on the front side. We are taken aback by the unusual, irregular pattern.
    • The experts at Creative Electron tell us that by looking at the patterning on the chip itself, focusing on the directions of the connections and vias, it looks like this board is made of four layers—two signals, power, and ground.
    • Taking a closer look at the balls that connect the chip, we notice a few light-colored bubbles within. This is called voiding.
    • Most contacts between boards are copper. But because copper oxidizes (rusts) very quickly, you have to wash it with an acid before making the bond. This acid is called flux and is used to "wet" the solder to the metal pads. Voiding happens when the flux isn't completely cleaned off.
    • Depending on its extent, this can be bad for durability. Clean, even connections allow heat to dissipate, while voiding allows for heat build up, reducing the life of components.
  13. Apple Watch X-ray Teardown: passo 13, imagem 1 %32 Apple Watch X-ray Teardown: passo 13, imagem 2 %32
    • Another thing we noticed during the initial teardown is the irregularly-shaped blob of metallic material at the center of the S1.
    • In all likelihood, this is a heat sink for the S1's tightly packaged processor.
    • Under the X-ray, this area lines up nicely with the centering magnet for the charger. Possibly Apple designed the magnet to serve a dual purpose—aligning the charger, and bleeding heat from the S1 SiP.
  14. Apple Watch X-ray Teardown: passo 14, imagem 1 %32 Apple Watch X-ray Teardown: passo 14, imagem 2 %32 Apple Watch X-ray Teardown: passo 14, imagem 3 %32
    • We pop the display under the rays, to see if we missed anything.
    • Looks pretty much like what we saw before; cables, chip, sensor etc.
    • However, a closeup shows what might be force touch strain gauges at the bottom of the screen.
    • Those rectangular patches sure look familiar anyway.
    • The footprint of the touchscreen controller and the ribbon cable traces look more like art than miniaturized tech.
  15. Apple Watch X-ray Teardown: passo 15, imagem 1 %32 Apple Watch X-ray Teardown: passo 15, imagem 2 %32 Apple Watch X-ray Teardown: passo 15, imagem 3 %32
    • Now for a few images we mostly like 'cause they're pretty.
    • The X-ray bed can be adjusted, allowing for these cool angled shots. It makes us feel like we're racing over a city on the Grid.
    • Another fun thing the X-ray reveals, are the tiny screws, embedded in the watch body.
    • You can see there's not much room to make them any bigger!
    • The intricate ribbon cable traces are like tiny, beautiful, TRON metro maps, and they even come in color!
    • Changes in color indicate a change in density, just like with greyscale images.
  16. Apple Watch X-ray Teardown: passo 16, imagem 1 %32 Apple Watch X-ray Teardown: passo 16, imagem 2 %32 Apple Watch X-ray Teardown: passo 16, imagem 3 %32
    • Fade to black... cue lights! Time to shine some illuminating rays on our next target, the inductive charger.
    • By adjusting the power level and exposure, we can see different strata of the charger.
    • For example, in the first image we see a high-contrast silhouette of the charger's internals, nested in the haziness of the plastic outer case. And in the last image, the board-level components are visible.
    • X-ray fun fact: Power and current are adjustable. Lower power equals better resolution—and fewer frames per second. Creative Electron's X-ray machines do up to 60 FPS, but this was slower than that.
    • X-ray fun fact 2: The zoom level of the image is directly proportional to the distance between the tungsten sensor and the object. It's also inversely proportional to the distance between the object and the X-ray source.
  17. Apple Watch X-ray Teardown: passo 17, imagem 1 %32 Apple Watch X-ray Teardown: passo 17, imagem 2 %32 Apple Watch X-ray Teardown: passo 17, imagem 3 %32
    • Don't worry, this UFO isn't here to abduct you. Not unless you're tiny, and ferromagnetic. It's just a centering magnet to ensure good alignment for charging.
    • Looking at this Oreo cookie of a charger, we find the inductive coils in the lower section, and a dense weight in the upper portion.
    • Speaking of density, here's a map with COLORS.
    • This fancy 3D graph shows the density of the charger's internals, with higher points representing greater density. That dark red semi-circle is the magnet, while the yellow indicates the charging coils.
  18. Apple Watch X-ray Teardown: passo 18, imagem 1 %32 Apple Watch X-ray Teardown: passo 18, imagem 2 %32 Apple Watch X-ray Teardown: passo 18, imagem 3 %32
    • On the left we see a row of dark coupling caps—probably in parallel. The tiny, light-colored dots within are invading microorganisms more of those little soldering voids, a remnant of the manufacturing process.
    • There is a relatively vast amount of brains in the charger. It probably understands the charging profile of the battery—so the watch doesn't have to. Cha-ching—space savings!
    • Up top, we spot a large BGA (ball grid array) which probably denotes the presence of a power management IC.
    • While the board is relatively complex, it only appears to be one layer, with no components on the bottom of the board (which makes sense because it needs to lay flat and charge).
    • With close inspection we spot a littler resistor network.
    • Each filament in the network connects different points with a different resistor.
    • One-layer PCB power management—probably no more than 0.031 inch thick.
  19. Apple Watch X-ray Teardown: passo 19, imagem 1 %32
    • X-rays reveal one last unseen innovative goodie: cable strain relief.
    • This springy bit of metal has some extra wire wrapped around it, so that if you pull too aggressively, you won't rip the cable off its contacts.
    • Looks like Apple put some serious thought into durability, it may well outlast the watch it's meant to charge.
    • Knock-off buyers beware, this is no dumb charger.
  20. Apple Watch X-ray Teardown: passo 20, imagem 1 %32
    • Thanks again, to our friends at Creative Electron!
    • We're looking forward to working with them more, to keep bringing you the power of X-ray vision.
    • In case you missed it, be sure to check out our original Apple Watch Teardown.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 31
Últimos 30 dias: 115
Duração total: 73,690
