Ir para o conteúdo principal
iPad 7 LCD Replacement
Robert Boyd
Robert Boyd e 2 outros colaboradores
Última atualização em 28 de jul de 2025
30 minutos - 2 horas
Difícil
Guia em destaque
Introdução
Ir para o passo 1
Use this guide to replace the liquid crystal display (LCD) in your iPad 7. Unlike newer iPads and most phones, the glass digitizer and LCD on the iPad 7 are not fused together.
Note: this guide is for the Wi-Fi version only. For the LTE version, click here.
For your safety, discharge the battery below 25% before disassembling your iPad. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage. If you choose to complete the guide without isolating the battery, avoid using metal tools except when completely necessary (like when removing screws) to prevent shorting the battery and damaging sensitive circuit components.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
O que você precisa
Ferramentas
Exibir mais…
  1. iPad 7 LCD Replacement, Heat the left edge: passo 1, imagem 1 %32
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
  2. iPad 7 LCD Replacement, Screen removal information: passo 2, imagem 1 %32 iPad 7 LCD Replacement, Screen removal information: passo 2, imagem 2 %32 iPad 7 LCD Replacement, Screen removal information: passo 2, imagem 3 %32
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
  3. iPad 7 LCD Replacement, Anti-Clamp instructions: passo 3, imagem 1 %32 iPad 7 LCD Replacement, Anti-Clamp instructions: passo 3, imagem 2 %32 iPad 7 LCD Replacement, Anti-Clamp instructions: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad 7 LCD Replacement: passo 4, imagem 1 %32 iPad 7 LCD Replacement: passo 4, imagem 2 %32 iPad 7 LCD Replacement: passo 4, imagem 3 %32
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad 7 LCD Replacement: passo 5, imagem 1 %32 iPad 7 LCD Replacement: passo 5, imagem 2 %32
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad 7 LCD Replacement, Insert an opening pick: passo 6, imagem 1 %32 iPad 7 LCD Replacement, Insert an opening pick: passo 6, imagem 2 %32 iPad 7 LCD Replacement, Insert an opening pick: passo 6, imagem 3 %32
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
    I had a screen that was lightly cracked, and when I pulled up on the glass it cracked even further and made a mess of my removal. So, I would recommend taping cracks even if you can get suction so that you don’t induce even more cracks.
    Andrew Dixon - Responder
    I actually had a really badly cracked digitizer. Using the suction cup did nothing but shatter the digitizer more. I intentionally drove a flat head screw driver into the digitizer to reveal the recess in the body where they are showing the opening-pick. Working around the edge, the glass shattered. You still need to be careful at all of spots noted in step 2.
    Do not go under the digitizer more than the 1 mm along the sides or 3-4 mm at the corners as shown in step 29 using the flat grey ring around the edge for a reference. Direct all of your tool force into the body to prevent slipping into critical parts.
    The antennas at either side of the home button were the trickiest part as they were thin and slightly attached to the digitizer. I would recommend using a plastic tool for these parts if you are having to 'scrape' the glass off of the tabs of the antenna.
    adoller - Responder
  7. iPad 7 LCD Replacement, Separate the left adhesive: passo 7, imagem 1 %32 iPad 7 LCD Replacement, Separate the left adhesive: passo 7, imagem 2 %32 iPad 7 LCD Replacement, Separate the left adhesive: passo 7, imagem 3 %32
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. iPad 7 LCD Replacement: passo 8, imagem 1 %32 iPad 7 LCD Replacement: passo 8, imagem 2 %32 iPad 7 LCD Replacement: passo 8, imagem 3 %32
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. iPad 7 LCD Replacement: passo 9, imagem 1 %32 iPad 7 LCD Replacement: passo 9, imagem 2 %32 iPad 7 LCD Replacement: passo 9, imagem 3 %32
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. iPad 7 LCD Replacement, Heat the top edge: passo 10, imagem 1 %32
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
    How do you heat the iopener?
    Steve Passmore - Responder
  11. iPad 7 LCD Replacement, Separate the top left adhesive: passo 11, imagem 1 %32 iPad 7 LCD Replacement, Separate the top left adhesive: passo 11, imagem 2 %32 iPad 7 LCD Replacement, Separate the top left adhesive: passo 11, imagem 3 %32
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
    There is a lot of adhesive in this corner, so if the glass is very shattered here, this procedure is extremely difficult. Even when heated up and glass surface taped, the adhesive is stronger than the shattered glass. This means that attempting to move the pick below it will shatter the glass even more, rather than separate the digitizer from the adhesive.
    Mark Østergaard - Responder
  12. iPad 7 LCD Replacement, Separate the top adhesive: passo 12, imagem 1 %32 iPad 7 LCD Replacement, Separate the top adhesive: passo 12, imagem 2 %32 iPad 7 LCD Replacement, Separate the top adhesive: passo 12, imagem 3 %32
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. iPad 7 LCD Replacement: passo 13, imagem 1 %32 iPad 7 LCD Replacement: passo 13, imagem 2 %32 iPad 7 LCD Replacement: passo 13, imagem 3 %32
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. iPad 7 LCD Replacement: passo 14, imagem 1 %32 iPad 7 LCD Replacement: passo 14, imagem 2 %32 iPad 7 LCD Replacement: passo 14, imagem 3 %32
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. iPad 7 LCD Replacement, Heat the right edge: passo 15, imagem 1 %32
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
  16. iPad 7 LCD Replacement, Separate the top right adhesive: passo 16, imagem 1 %32 iPad 7 LCD Replacement, Separate the top right adhesive: passo 16, imagem 2 %32 iPad 7 LCD Replacement, Separate the top right adhesive: passo 16, imagem 3 %32
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
  17. iPad 7 LCD Replacement, Separate the right adhesive: passo 17, imagem 1 %32 iPad 7 LCD Replacement, Separate the right adhesive: passo 17, imagem 2 %32 iPad 7 LCD Replacement, Separate the right adhesive: passo 17, imagem 3 %32
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
    There are sensitive display/digitizer cables no less than five inches from the bottom edge of the iPad. Insert the pick further down than this, or deeper than 1mm beyond this point and you risk irreparably damaging these cables.
    Three inches is much too far down this side of the iPad to use picks.
    rcrandall85 - Responder
  18. iPad 7 LCD Replacement, Heat the bottom edge: passo 18, imagem 1 %32
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
  19. iPad 7 LCD Replacement, Separate the bottom left adhesive: passo 19, imagem 1 %32 iPad 7 LCD Replacement, Separate the bottom left adhesive: passo 19, imagem 2 %32 iPad 7 LCD Replacement, Separate the bottom left adhesive: passo 19, imagem 3 %32
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the bottom-left corner before moving to the next step.
  20. iPad 7 LCD Replacement, Separate the bottom adhesive: passo 20, imagem 1 %32 iPad 7 LCD Replacement, Separate the bottom adhesive: passo 20, imagem 2 %32 iPad 7 LCD Replacement, Separate the bottom adhesive: passo 20, imagem 3 %32
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. iPad 7 LCD Replacement: passo 21, imagem 1 %32 iPad 7 LCD Replacement: passo 21, imagem 2 %32 iPad 7 LCD Replacement: passo 21, imagem 3 %32
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
    Be careful with this step. Only insert the tip, 2-3mm. I broken the touch id and home button. No replace or fix to get the touch id working again.
    Juan Luis Montoya - Responder
  22. iPad 7 LCD Replacement: passo 22, imagem 1 %32 iPad 7 LCD Replacement: passo 22, imagem 2 %32 iPad 7 LCD Replacement: passo 22, imagem 3 %32
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. iPad 7 LCD Replacement, Heat the right edge: passo 23, imagem 1 %32
  24. iPad 7 LCD Replacement: passo 24, imagem 1 %32 iPad 7 LCD Replacement: passo 24, imagem 2 %32
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. iPad 7 LCD Replacement: passo 25, imagem 1 %32 iPad 7 LCD Replacement: passo 25, imagem 2 %32
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  26. iPad 7 LCD Replacement, Separate the right adhesive: passo 26, imagem 1 %32 iPad 7 LCD Replacement, Separate the right adhesive: passo 26, imagem 2 %32 iPad 7 LCD Replacement, Separate the right adhesive: passo 26, imagem 3 %32
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
  27. iPad 7 LCD Replacement: passo 27, imagem 1 %32 iPad 7 LCD Replacement: passo 27, imagem 2 %32
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
    While reassembling, REALLY make sure the display cables and the home button cable won't be folded / bent while closing the digitizer. I'm not exactly sure what I did, but I broke the home button and touch ID since I bent the home button cable to the point that it broke. These ribbon cables are SUPER fragile.
    op_ - Responder
  28. iPad 7 LCD Replacement, Remove the LCD: passo 28, imagem 1 %32 iPad 7 LCD Replacement, Remove the LCD: passo 28, imagem 2 %32
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the four 4.3 mm-long screws securing the LCD to the frame.
    • Remove any tape obscuring the LCD screws.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  29. iPad 7 LCD Replacement, Flip the LCD over: passo 29, imagem 1 %32 iPad 7 LCD Replacement, Flip the LCD over: passo 29, imagem 2 %32 iPad 7 LCD Replacement, Flip the LCD over: passo 29, imagem 3 %32
    • Don't attempt to fully remove the LCD during this step, as it's still connected by several cables at the home button end.
    • Only lift the LCD from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the frame.
    • Lay the LCD down onto a clean, soft, lint-free surface to allow access to the display cables.
    When flipping the LCD over be aware the the cable can be just short enough that when you flip it the tension caused can potentially cause damage if not carefully paid attention to. When LCD loosened from mounts, the bottom two corners can be left within the frame after you flip it.
    William Harwood - Responder
  30. iPad 7 LCD Replacement, Disconnect the battery: passo 30, imagem 1 %32 iPad 7 LCD Replacement, Disconnect the battery: passo 30, imagem 2 %32
    • Use a Phillips screwdriver to remove the 2.3 mm-long screw securing the battery connector to the logic board.
  31. iPad 7 LCD Replacement, Battery connector information: passo 31, imagem 1 %32 iPad 7 LCD Replacement, Battery connector information: passo 31, imagem 2 %32 iPad 7 LCD Replacement, Battery connector information: passo 31, imagem 3 %32
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  32. iPad 7 LCD Replacement, Disconnect the battery: passo 32, imagem 1 %32 iPad 7 LCD Replacement, Disconnect the battery: passo 32, imagem 2 %32 iPad 7 LCD Replacement, Disconnect the battery: passo 32, imagem 3 %32
    • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Ensure that the iFixit logo on the battery blocker is facing up.
    • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at about a 15 degree angle.
    • Leave the battery blocker in place as you work.
  33. iPad 7 LCD Replacement, Unfasten the display cable bracket: passo 33, imagem 1 %32 iPad 7 LCD Replacement, Unfasten the display cable bracket: passo 33, imagem 2 %32
    • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the display cable bracket.
  34. iPad 7 LCD Replacement, Remove the display cable bracket: passo 34, imagem 1 %32 iPad 7 LCD Replacement, Remove the display cable bracket: passo 34, imagem 2 %32
    • Remove the display cable bracket.
  35. iPad 7 LCD Replacement, Disconnect the LCD: passo 35, imagem 1 %32 iPad 7 LCD Replacement, Disconnect the LCD: passo 35, imagem 2 %32
    • Use the flat end of a spudger to disconnect the LCD cable by lifting straight up on the press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  36. iPad 7 LCD Replacement, Remove the LCD: passo 36, imagem 1 %32 iPad 7 LCD Replacement, Remove the LCD: passo 36, imagem 2 %32
    • Remove the LCD completely and rest it face down on a clean, soft, lint-free surface.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 7 Answers community for help.
3 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Robert Boyd
Membro desde: 02/01/21
30.557 Reputação
Autoria de 94 guias
2Comentários do guia
On step 29, when you flip the LCD screen over, I strongly suggest covering the LCD with any kind of clean cloth. If you flip the screen like shown, the remainings of the adhesive on the frame will stick to the LCD and you will have to carefully clean it later. I also advise to cover the LCD entirely whenever touching it either for flipping over, or when you remove it entirely from the iPad. Or maybe work with it wearing gloves. I had adhesive residue and lot of fingerprints on LCD, quite hard to clean. Although I tried to be careful, sadly in the end I could notice some small scratches on the LCD.
rmackowski - Responder
Good advice. I am facing a similar issue. I saw this suggestion 24 hours too late.
Sticky Fingers - Responder
Comentar
Visualizações:
Últimas 24 horas: 33
Últimos 7 dias: 108
Últimos 30 dias: 395
Ao todo: 12,592
