Ir para o conteúdo principal
Samsung Galaxy S10 Loudspeaker Replacement
Arthur Shi
Arthur Shi e 3 outros colaboradores
Última atualização em August 16, 2022
40 minutos - 1 hora
Moderado
Introdução
Ir para o passo 1
Follow this guide to remove the loudspeaker in the Samsung Galaxy S10. For this model, the loudspeaker is built into the lower midframe.
The hardest part of this guide is removing the S10’s back cover.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Samsung Galaxy S10 Loudspeaker Replacement, Heat the back cover: passo 1, imagem 1 %32 Samsung Galaxy S10 Loudspeaker Replacement, Heat the back cover: passo 1, imagem 2 %32 Samsung Galaxy S10 Loudspeaker Replacement, Heat the back cover: passo 1, imagem 3 %32
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • As you wait, take a look at the image of the removed back cover and take note of where the adhesive is located.
    I think we should mention that the glass needs to be barely too hot to touch to determine when it's hot enough that a pick can be slid underneath.
    Or we can mention a thermometer temperature, but most diy people probably don't have a thermometer to check.
    A lot of people seem to have issues using the iopener to unglue phone parts like back glass (can Google it), likely because the glue didn't get hot enough, so mentioning the desired touch temperature can be helpful for DIYers to ensure that their glue is sufficiently weakened and they can begin working off the part.
    (Just being hot isn't enough for glue to weaken, as you can probably attest to if you've ever had your phone get really hot but the back cover never came loose)
    A X - Responder
  2. Samsung Galaxy S10 Loudspeaker Replacement, Create an opening gap: passo 2, imagem 1 %32 Samsung Galaxy S10 Loudspeaker Replacement, Create an opening gap: passo 2, imagem 2 %32 Samsung Galaxy S10 Loudspeaker Replacement, Create an opening gap: passo 2, imagem 3 %32
    • Rest the heated right edge of the phone on something that is about 0.5 inches (13 mm) thick. This angles the phone for the opening tool.
    • Brace the left edge of the phone with your fingers so that the phone won't slide. Pull on the suction cup with firm pressure.
    • Press the edge of an opening tool into the seam between the back cover and the frame.
    • With the opening tool in place in the seam, slide it back and forth along the seam to loosen the back cover.
    Will the Suction Cup work with a cracked back?
    Red Royal - Responder
    Might be hard with the suction cup on a cracked back. I'd rather break it off and buy a new back (it's super cheap, around 10$ online).
    Guenter -
    Yes! Apply a layer of packing tape to the cracked back cover first, and the suction cup will adhere to the smooth tape surface.
    Arthur Shi -
    I will open the one that I am taking out of the computer now and then I will follow where it is
    cabdi salaan - Responder
    Am besten 2 mal gut erwährmen. Danach geht das öfnen top.
    Martin Thiel - Responder
  3. Samsung Galaxy S10 Loudspeaker Replacement, Insert an opening pick: passo 3, imagem 1 %32 Samsung Galaxy S10 Loudspeaker Replacement, Insert an opening pick: passo 3, imagem 2 %32 Samsung Galaxy S10 Loudspeaker Replacement, Insert an opening pick: passo 3, imagem 3 %32
    • Heat an iOpener and apply it to the same edge of the phone for two minutes.
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible (where the adhesive is narrowest).
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances and strong adhesive, multiple attempts may be necessary to create a gap for the opening pick.
    • If you are having trouble creating a gap, the adhesive isn't weakened enough. Make sure you have heated the edge until just barely too hot to touch try this step again.
    • You can try applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
    • Do not apply excessive force with the pick, or you will risk cracking the back cover glass.
    I had trouble lifting up to create a gap. What I did is watch Jerry rig everything's teardown and he said the back glass must be barely too hot to touch in order for the adhesive to weaken.
    So I heated the iOpener till it was too hot to touch, but not so long that it would burst. Put on right edge for a few minutes. Then I lift with the suction cup, using my middle finger and thumb to grip the sides of the phone and my pointer finger to pull up on the suction cup .
    I cleaned the glass with an alcohol wipe beforehand to make the suction cup stick better, though I'm sure any cleaning method that removes fingerprints will help.
    I couldn't make as big a gap as shown in the picture, but I was able to stick my metal jimmy tool carefully into the crack between the glass and the metal frame and it was just enough to slide the tool a little. And I was very careful since it's a metal tool. After that I could stick the plastic pick in and slice the adhesive and then that gets you started removing the back cover. Reheat often to weaken and slice adhesive. STOP and reheat if it even gets a little harder to slice. DON'T risk cracking the glass.
    A X - Responder
    I think we should add that they should treat the back glass as gently as a raw eggshell. That's because I thought I wasn't applying excessive force and caused the glass to crack, but I didn't understand what counts as "excessive force." (A bit vague)
    What excessive force actually means is as soon as you feel any resistance at all when slicing glue with the pick, stop and apply more heat before continuing. The glass can crack very very easily, when pressure is applied in only a small section.
    A X - Responder
    See for me it was weird, the glass was weirdly weak. I just put the iOpener in the microwave and put it on there until it was almost too hot to touch and went around, the gap was like 0.5cm already, so I just went around and it came all off in like 10 seconds, I was kind of happy how easy it was, but sadly I went around too fast and now there's a line crack at the top left of my back glass, it's not sharp so it doesn't bother me.
    Oliver Fallon -
  4. Samsung Galaxy S10 Loudspeaker Replacement, Slice through the adhesive: passo 4, imagem 1 %32 Samsung Galaxy S10 Loudspeaker Replacement, Slice through the adhesive: passo 4, imagem 2 %32 Samsung Galaxy S10 Loudspeaker Replacement, Slice through the adhesive: passo 4, imagem 3 %32
    • Slide the opening pick along the edge of the phone, slicing through the adhesive.
    • Do not attempt to slice the adhesive holding the corners down before applying heat. If you do, you may crack the back cover.
    • Leave a pick in the seam to prevent the adhesive from re-sealing.
  5. Samsung Galaxy S10 Loudspeaker Replacement: passo 5, imagem 1 %32 Samsung Galaxy S10 Loudspeaker Replacement: passo 5, imagem 2 %32
    • Apply a heated iOpener to the bottom edge of the phone for two minutes.
    • Insert an opening pick into the right edge near the bottom right corner.
    • Carefully slide the pick around the corner. Continue cutting along the bottom edge and around the bottom left corner.
    • If the cutting feels difficult, re-apply heat to the edge before continuing.
    • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
  6. Samsung Galaxy S10 Loudspeaker Replacement: passo 6, imagem 1 %32 Samsung Galaxy S10 Loudspeaker Replacement: passo 6, imagem 2 %32 Samsung Galaxy S10 Loudspeaker Replacement: passo 6, imagem 3 %32
    • Continue heating and slicing around the remaining edges of the phone.
    • When cutting around corners, be sure that the corner is thoroughly heated.
  7. Samsung Galaxy S10 Loudspeaker Replacement: passo 7, imagem 1 %32 Samsung Galaxy S10 Loudspeaker Replacement: passo 7, imagem 2 %32 Samsung Galaxy S10 Loudspeaker Replacement: passo 7, imagem 3 %32
    • Once you have sliced around the phone, twist an opening pick in one of the edges to help separate the back cover from the frame.
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly, this is a good point to power on your phone and test all functions before you seal the back cover in place. Be sure to power your phone back down completely before you continue working.
    • Follow this guide to reinstall the back cover, transfer and install the camera bezel, and replace the adhesive.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it.
    Thank's for the help I will try to repair my phone with a new battery all on my
    ron hayes - Responder
  8. Samsung Galaxy S10 Loudspeaker Replacement, Remove the midframe: passo 8, imagem 1 %32
    • Remove the eight 4 mm Phillips screws securing the top midframe to the phone.
    ネジが堅くて回らず、緩める方法はありますか?
    win1683 - Responder
    ネジロックが原因である可能性があるため、iOpener で熱を加えてみてください。
    Oliver Fallon -
  9. Samsung Galaxy S10 Loudspeaker Replacement: passo 9, imagem 1 %32 Samsung Galaxy S10 Loudspeaker Replacement: passo 9, imagem 2 %32
    • The midframe is still held in place by a few plastic clips around the edge.
    • Insert the point of a spudger into the notch on the right edge of the midframe, near the volume up button.
    • Pry up to loosen the midframe from the phone.
    Bei mir war die Kerbe durch den Klebstoff komplett verdeckt. Am bestern den Kleber vorher entfernen. Dann geht es einfacher.
  10. Samsung Galaxy S10 Loudspeaker Replacement: passo 10, imagem 1 %32 Samsung Galaxy S10 Loudspeaker Replacement: passo 10, imagem 2 %32 Samsung Galaxy S10 Loudspeaker Replacement: passo 10, imagem 3 %32
  11. Samsung Galaxy S10 Loudspeaker Replacement, Disconnect the battery: passo 11, imagem 1 %32 Samsung Galaxy S10 Loudspeaker Replacement, Disconnect the battery: passo 11, imagem 2 %32 Samsung Galaxy S10 Loudspeaker Replacement, Disconnect the battery: passo 11, imagem 3 %32
    • Insert the flat end of a spudger underneath the battery connector, which is attached to the motherboard below the rear-facing camera.
    • Pry upwards to disconnect the connector from its socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Gently push the battery's flex cable away from the motherboard socket to prevent accidental contact.
    Between this step and the next (Step 12, Battery), the lower mainframe is removed in the images but there is no instruction to do so. I was able to remove the battery (1 min of heating with iOpener, plus 8 total drops [2 in each corner] of 90% IPA) without removing this lower mainframe.
    Claire Porter - Responder
  12. Samsung Galaxy S10 Loudspeaker Replacement, Remove the loudspeaker: passo 12, imagem 1 %32
    • Remove the seven 4 mm Phillips screws securing the lower midframe.
  13. Samsung Galaxy S10 Loudspeaker Replacement: passo 13, imagem 1 %32 Samsung Galaxy S10 Loudspeaker Replacement: passo 13, imagem 2 %32
    • Insert the point of a spudger underneath the top right corner of the lower midframe.
    • Pry up to release the midframe from the phone.
  14. Samsung Galaxy S10 Loudspeaker Replacement: passo 14, imagem 1 %32 Samsung Galaxy S10 Loudspeaker Replacement: passo 14, imagem 2 %32 Samsung Galaxy S10 Loudspeaker Replacement: passo 14, imagem 3 %32
    • Grasp the loosened end of the midframe with your fingers and lift upwards slowly.
    • Wiggle the midframe slightly to help release the remaining edge clips.
    • Remove the lower midframe. The loudspeaker is built into the lower midframe.
Conclusão
After you've completed the repair, follow this guide to test your repair.
6 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
283.138 Reputação
Autoria de 587 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.548 guias
2 comentários
in 14 Schritten wird haarklein beschrieben wie man den lautsprecher ausbaut , jeder Schaube wird eingezeichnet. Am Ende aber >Der Lautsprecher ist in den unteren Mittelrahmen eingebaut.< für ein Foto hat es dann nicht mehr gereicht ? Koitus interruptus .Sechs setzen.
Rolf - Responder
Waarom niet no 1 of 2 foto's toegevoegd om te laten zien welk onderdeel de speaker is en hoe lost te maken ????
Gérard Van Wijk - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 29
Últimos 30 dias: 150
Ao todo: 14,414
