PowerA Enhanced Wireless Controller Motherboard Replacement
Introdução
Ir para o passo 1This guide will show you how to access and replace the motherboard of your PowerA Enhanced Wireless Controller for Nintendo Switch. Replacing the motherboard is a necessary step for fixing stick drift and power-related issues on your controller. Other motherboard issues are often characterized by unresponsive buttons and your controller failing to immediately turn on.
Before beginning the repair process, it's important to remove the batteries from your controller to ensure your safety during the repair and prevent any additional issues. Step 1 of this guide will show you how to access the battery compartment to remove the batteries.
O que você precisa
Ferramentas
Remove the battery cover by pressing down on the lever located on the top of the cover.
Apply pressure until it clicks out of place, and pull it off.
Gear Up For Future Repairs
Shop all1Comentário do guia
Je cherche un couvercle de batterie pour ma manette switch
Auriez-vous un site où il est possible de s’en procurer un ?
Merci
