Ir para o conteúdo principal
Pebble Time Screen Replacement
Saud Al-Malki
Saud Al-Malki e 3 outros colaboradores
Última atualização em 8 de mar de 2025
7 minutos
Fácil
Introdução
Ir para o passo 1
Replacement guide for the screen of the Pebble Time.
O que você precisa
Ferramentas
  1. Pebble Time Screen Replacement, Screen Cover: passo 1, imagem 1 %32
    • Lay the watch flat on your workstation.
  2. Pebble Time Screen Replacement: passo 2, imagem 1 %32 Pebble Time Screen Replacement: passo 2, imagem 2 %32
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
    Just a note whilst removing the cover/screen - on my Pebble Time Steel, the LCD seemed to actually be attached to the glass, so when the adhesive around the outside seperated, I disconnected the ribbon cable and removed both as one piece - if you can, this definitely helps keep the end result a bit tidier!
    Aadi Bhamidipati - Responder
  3. Pebble Time Screen Replacement: passo 3, imagem 1 %32
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Screen Replacement: passo 4, imagem 1 %32
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Screen Replacement, Screen: passo 5, imagem 1 %32
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Screen Replacement: passo 6, imagem 1 %32
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Screen Replacement: passo 7, imagem 1 %32 Pebble Time Screen Replacement: passo 7, imagem 2 %32 Pebble Time Screen Replacement: passo 7, imagem 3 %32
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
    There might be some yellow / brown sticky tape that covers the lower end of the ribbon cable and those 6 shiny contact pads. You can carefully pull it off when you lift up the cable.
    Henrik L - Responder
Conclusão
Uma outra pessoa concluiu este guia.
Gear Up For Future Repairs
Shop all
Saud Al-Malki
Membro desde: 02/19/17
110 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-3, Sullivan Spring 2017 Membro de USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 Membros
Autoria de 10 guias
3Comentários do guia
Where can I buy the display replacement?
ulises - Responder
Hello Ulises,
Based off of my search, I couldn’t find any place where you can buy a display replacement. I advise you to look on Ebay, Amazon, or you can contact Pebble Time for more information at https://www.pebble.com or +18882245820. If none of this works out for you, you might want to check local tech repair shops.
Hope this helps.
Saud Al-Malki - Responder
Hola.
¿I have a question ?
What adhesive What adhesive should I buy to stick it again after placing the screen?
bladimir gonzalez matos - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 49
Ao todo: 3,502
