Ir para o conteúdo principal
PSP 1000 Front Casing Replacement
Henry Lee
Henry Lee e 13 outros colaboradores
Última atualização em 3 de mai de 2024
10 minutos
Fácil
Introdução
Ir para o passo 1
This guide will show you how to remove the PSP's housing/frame.
O que você precisa
Ferramentas
  1. PSP 1000 Front Casing Replacement, Battery: passo 1, imagem 1 %32
    • Turn the PSP over so its back is facing you.
  2. PSP 1000 Front Casing Replacement: passo 2, imagem 1 %32 PSP 1000 Front Casing Replacement: passo 2, imagem 2 %32
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
    You are dumbbb... BRO YOUR DUMB BC U DIDNT HAVE TO USE A TOOL TO OPEN THE DOOR. USE YOUR FINGER""
    Paulo Moments - Responder
    The battery door can be damaged dont use a tool
    That also happend to me it got destroyed by screwdriver
  3. PSP 1000 Front Casing Replacement: passo 3, imagem 1 %32 PSP 1000 Front Casing Replacement: passo 3, imagem 2 %32
    • Using your finger, remove the battery upwards from the system as shown.
    The use of the opening tool is completely unnecessary. There is a finger actuated opening latch button that says “PUSH” on it. Simply press down with your thumb then slide your thumb down and away, dragining the battery door with it. It will then come off. Assuming the system still has its original plastics, they may have become brittle enough that the opening tool could damage the release button or the plastic cover.
    Franklin Allen - Responder
  4. PSP 1000 Front Casing Replacement, Front Casing: passo 4, imagem 1 %32 PSP 1000 Front Casing Replacement, Front Casing: passo 4, imagem 2 %32
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the guarantee sticker to access the screw on the lower left.
    Much luck to you if you have a tiny, metal screwdriver like I did, the screws might be stuck in there and may require some force.
    Squib - Responder
    you need to peel back the warranty sticker in order to access both the lower left and lower left screws
    Frederick zzstu Geib - Responder
    This is a bit misleading, you should only remove the two black screws in the battery compartment. The silver ones can stay.
    Damian Cartwright - Responder
    The two left hand screws won’t come out of mine
    XULF - Responder
    iFixit screwdriver bits aren't thin enough to reach the two screws on the right near the memory stick slot.
    Fliggle_Slaps - Responder
    Can't edit previous comment so here's a new one:
    Standard or older iFixit screwdriver bits aren't thin enough to reach the two screws on the right near the memory stick slot. You'll need precision bits that have longer tips to reach these deep screws.
  5. PSP 1000 Front Casing Replacement: passo 5, imagem 1 %32
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove screws from back righthand side within the holes.
  6. PSP 1000 Front Casing Replacement: passo 6, imagem 1 %32 PSP 1000 Front Casing Replacement: passo 6, imagem 2 %32
    • Gently separate the outer plastic casing from the rest of the system as shown.
Conclusão
34 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Henry Lee
Membro desde: 01/14/10
866 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 5-6, Forte Winter 2010 Membro de Cal Poly, Team 5-6, Forte Winter 2010
CPSU-FORTE-W10S5G6
5 Membros
Autoria de 34 guias
3Comentários do guia
Thank you! Awesome help!
Jay Vee - Responder
My psp is updating then psp is fallen down and battery comeout so please help me please thank you
Bye
National Nazeer - Responder
i also made a video on this for anyone who needs to do it that way.
https://www.youtube.com/watch?v=EIAaJyIx...
DAS Repair - Responder
Comentar
Visualizações:
Últimas 24 horas: 17
Últimos 7 dias: 117
Últimos 30 dias: 396
Ao todo: 46,589
