Ir para o conteúdo principal
Meta Quest 2 Controller Ring Shell Replacement
Arthur Shi
Arthur Shi
Última atualização em 29 de jul de 2025
15 - 30 minutos
Moderado
Introdução
Ir para o passo 1
This guide shows how to remove and replace a cracked controller ring shell for your Meta Quest 2 controller.
This guide is written with the right controller. If you're repairing the left controller, you can still use this guide, as the procedure is identical.
O que você precisa
Ferramentas
Exibir mais…
  1. Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: passo 1, imagem 1 %32 Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: passo 1, imagem 2 %32 Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: passo 1, imagem 3 %32
    • Use your fingers to slide the battery cover down towards the strap end of the controller.
    • Remove the battery cover.
    • If you're taking the controller apart for repairs, remove the batteries in the controller.
  2. Meta Quest 2 Controller Ring Shell Replacement, Remove the wrist strap: passo 2, imagem 1 %32 Meta Quest 2 Controller Ring Shell Replacement, Remove the wrist strap: passo 2, imagem 2 %32
    • Use your fingers to grasp the wrist strap near the anchor peg.
    • Lift the wrist strap anchor peg straight out of its recess.
    • Remove the wrist strap.
  3. Meta Quest 2 Controller Ring Shell Replacement, Loosen the faceplate adhesive: passo 3, imagem 1 %32
    • Heat an iOpener and apply it to the bottom edge of the controller faceplate for a minute.
    Why is this step needed? Yes there is adhesive on it, but it isn't that bad.
    DAB ARMY - Responder
    you dont need it, prob better to have it but not required to get the cover off
    jek - Responder
    For anyone stumbling across this like me, I can agree with the others: it is almost definitely a nice to have I'm sure, but I was able to get in just fine using an opening pick and opening tool.
    Aranohr - Responder
  4. Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: passo 4, imagem 1 %32 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: passo 4, imagem 2 %32 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: passo 4, imagem 3 %32
    • The controller faceplate is secured with adhesive and three friction pegs.
    • Press the edge of an opening tool into the seam between the controller faceplate and shell, near the Oculus button.
    • If you can’t get the opening tool into the seam, heat the area with an iOpener for a minute and try again.
    • Slide the opening tool to the base of the ring shell to loosen the adhesive.
  5. Meta Quest 2 Controller Ring Shell Replacement: passo 5, imagem 1 %32 Meta Quest 2 Controller Ring Shell Replacement: passo 5, imagem 2 %32
    • Use an opening tool to pry up on the seam to loosen the first friction peg.
  6. Meta Quest 2 Controller Ring Shell Replacement: passo 6, imagem 1 %32 Meta Quest 2 Controller Ring Shell Replacement: passo 6, imagem 2 %32
    • Continue prying around the entire faceplate to separate the remaining friction pegs and adhesive.
    • If you're having trouble, apply a heated iOpener to the faceplate for a minute and try again.
  7. Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: passo 7, imagem 1 %32 Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: passo 7, imagem 2 %32 Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: passo 7, imagem 3 %32
    • Remove the controller faceplate.
    • The three friction pegs should hold the faceplate securely, so you don’t need to replace the adhesive during reassembly. Be sure to firmly press the faceplate onto the controller so that all friction pegs fully engage.
  8. Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller ring shell: passo 8, imagem 1 %32 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller ring shell: passo 8, imagem 2 %32
    • Use a Torx T5 driver to remove the four screws securing the controller ring shell to the controller:
    • Two 4.7 mm‑long screws
    • Two 5.9 mm‑long screws
    those top screws in red are in very tight, and at an angle that prevents using a long screwdriver. I've found the only way I could get them out is using a bit, held down by my finger at the appropriate angle, while turning it with pliers.
    Ben Klopfenstein - Responder
    I wasn't able to remove the screws in red with a T5 bit, but switching to a T4 bit did the trick for me
    Aranohr - Responder
    same, used T4 instead
    Martin Samuelsson -
    Can also confirm, T4 is a good fit and doesn't feel like it might damage the screw or bit like T5 did.
    Nyanofilter -
  9. Meta Quest 2 Controller Ring Shell Replacement: passo 9, imagem 1 %32 Meta Quest 2 Controller Ring Shell Replacement: passo 9, imagem 2 %32
    • Press the point of a spudger firmly against the white alignment square to release the ring shell.
  10. Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: passo 10, imagem 1 %32 Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: passo 10, imagem 2 %32 Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: passo 10, imagem 3 %32
    • Use your fingers to grab the end of the ring shell that doesn’t have the white alignment square.
    • Gently lift the ring shell up and away from the controller to unclip it from the controller.
    • Remove the controller ring shell.
Conclusão
Gear Up For Future Repairs
Shop all
Arthur Shi
Membro desde: 01/03/18
300.762 Reputação
Autoria de 687 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 22.495 guias
1Comentário do guia
This Tutorial was really fast and easy also, I fixed my controller and it works very well now, Thank you!
# “‪Diamond‬” # - Responder
Comentar
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 39
Últimos 30 dias: 139
Ao todo: 5,446
