Ir para o conteúdo principal
Mac Pro First Generation RAM Replacement
Andrew Kim
Andrew Kim e 3 outros colaboradores
Última atualização em 6 de jul de 2025
5 - 10 minutos
Fácil
Guia do aluno destaque
Introdução
Ir para o passo 1
Accessing the RAM is easy and requires no tools. Use this guide to add or replace RAM for your Mac Pro.
  1. Mac Pro First Generation RAM Replacement, Case Panel: passo 1, imagem 1 %32
    • Lift the lever to unlock the case.
  2. Mac Pro First Generation RAM Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    Anti-Static Wrist Strap
    $7.95
    • Remove the side panel of the Mac Pro.
    • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
  3. Mac Pro First Generation RAM Replacement, RAM: passo 3, imagem 1 %32
    • Locate the two RAM trays at the bottom of the Mac Pro.
  4. Mac Pro First Generation RAM Replacement: passo 4, imagem 1 %32 Mac Pro First Generation RAM Replacement: passo 4, imagem 2 %32
    • Pull the RAM tray out of the case by using both hands holding the edge of the ram board as shown.
    • Make sure you give enough time for the computer to cool down before you remove any internal hardware parts.
  5. Mac Pro First Generation RAM Replacement: passo 5, imagem 1 %32 Mac Pro First Generation RAM Replacement: passo 5, imagem 2 %32 Mac Pro First Generation RAM Replacement: passo 5, imagem 3 %32
    • Push down on the ejectors on each side of a ram stick firmly and lift the RAM stick straight out carefully by holding each side.
    • To insert a new RAM stick, place the RAM into the slot with the correct orientation and push on the stick using both hands until the ejectors are clicked into place.
Conclusão
22 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Andrew Kim
Membro desde: 10/12/14
1.263 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 6-24, Maness Fall 2014 Membro de Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 Membros
Autoria de 19 guias
2Comentários do guia
What is the name/or type of memory chip to use in the MacPro 2008.
Curtis - Responder
Hi Curtis, hope you found the RAM type ok.
Basically server RAM, ECC, 667Mhz, FB always in Pairs.
Retired Apple, PC etc engineer.
coopernewlyn - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 42
Ao todo: 21,157
