Lenovo Ideapad Gaming 3 15ACH6 Left SSD Replacement
Introdução
Ir para o passo 1Use this guide to replace the left SSD on your Lenovo IdeaPad gaming 3 15ACH6.
Your laptop might not come with a standoff screw to install an additional SSD. In this case, you'll need to purchase one.
Before you perform this repair, if at all possible, back up your existing SSD. If you are replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
Use a Phillips screwdriver to remove the 10 screws securing the lower case:
Six 12 mm screws
Four 4.5 mm screws
Insert an opening pick between the lower case and the chassis on the front right edge.
Slide the pick along the front edge to release the clips securing the lower case.
Continue sliding the opening pick along the left and right edges to release the remaining clips.
Lift the lower case from the chassis and remove it.
Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
Use a Phillips screwdriver to remove the 2.4 mm screw securing the left SSD.
Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo IdeaPad answers community for help.
3Comentários do guia
I want do to an ssd upgrade, but I have a 15ihu6 model. Are the instructions the same? And also, the slot is empty. Is there a screw by default? If no, then what length is it?
Nevermind, it's 2.4mm, i guess.
Hi! Yes, the left SSD screw is 2.4 mm as you stated. Also make sure your laptop has a standoff screw to put that 2.4 mm screw into (some laptops may not come with one installed).
