Ir para o conteúdo principal
Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement
Austin Blakely
Austin Blakely e 2 outros colaboradores
Última atualização em November 15, 2022
25 - 30 minutos
Fácil
Introdução
Ir para o passo 1
This guide will show you how to replace the M.2 Solid State Drive in your Lenovo IdeaPad Flex 5 1570 laptop. The solid state drive (SSD) is a storage device, which houses all the data on your device, from the filesystem to the operating system. Problems that you may experience from a faulty SSD are a corrupted memory or OS, difficulty starting the computer, or missing files. You may also run into a situation where your SSD becomes too full and you run out of storage space on your computer, which may prompt an upgrade. Replacing or upgrading the SSD in your device should alleviate any of these problems in a traditional laptop.
However, the Flex 5 1570 is capable of running two storage devices in tandem, utilizing both a PCIe port and a SATA port. Typically this would be used to run a hard disk drive, which is slower, but cheaper for more memory, and a solid state drive for programs and files which need to be accessed quickly. Because there may be two storage devices on your device, you may have to do some investigating as to which one is faulty. If you suspect your computer is having storage problems and replacing the SSD didn’t help, check out our Lenovo IdeaPad Flex 5 1570 Hard Drive Replacement Guide.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #0 Screwdriver
Exibir mais…
  1. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Back Panel: passo 1, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 2, imagem 2 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 2, imagem 3 %32
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 3, imagem 2 %32
    • Once all the clips have been disengaged, lift off the back cover.
    You should probably disconnect the battery immediately after opening the laptop. Don’t want to risk damaging your nice hardware.
    Zack Colman - Responder
  4. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Battery Disconnect: passo 4, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Battery Disconnect: passo 4, imagem 2 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Battery Disconnect: passo 4, imagem 3 %32
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
  5. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, M.2 SSD: passo 5, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, M.2 SSD: passo 5, imagem 2 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, M.2 SSD: passo 5, imagem 3 %32
    • Remove the single 2.9 mm screw holding down the solid state drive with a Phillips #0 screwdriver.
    • The SSD will rise to rest at an angle once the screw is removed.
  6. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 6, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 6, imagem 2 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 6, imagem 3 %32
    • Pull the solid state drive out of its port to the right at a similar angle to which it rests.
    • Remove the SSD from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Austin Blakely
Membro desde: 03/11/19
21.439 Reputação
Autoria de 53 guias
Equipe
iFixit Membro de iFixit
Staff
120 Membros
Autoria de 20.002 guias
1Comentário do guia
Very informative, the pictures were most helpful.
IDK if you've got a guide detailing the drive cloning process or not but that would put the icing on the cake.
Thank you
FaQue Microsoft - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 95
Ao todo: 6,759
