Ir para o conteúdo principal
How to clean a Game Boy Cartridge
Andrew Tramposch
Andrew Tramposch e 5 outros colaboradores
Última atualização em 18 de dez de 2024
3 minutos
Muito fácil
Introdução
Ir para o passo 1
A guide on how to place a game into the cartridge reader, also for troubleshooting non-loading games.
O que você precisa
Fix Kit
Este kit contém todas as peças e ferramentas necessárias para executar este guia.
  1. How to clean a Game Boy Cartridge, How to clean a Game Boy Cartridge: passo 1, imagem 1 %32
    • First obtain a cartridge. This is where games for the Game Boy are located.
  2. How to clean a Game Boy Cartridge: passo 2, imagem 1 %32
    • Place cartridge into cartridge reader slot on the back of the Game Boy system.
    • The game graphic should be facing towards you when you place the cartridge into the reader slot.
  3. How to clean a Game Boy Cartridge: passo 3, imagem 1 %32 How to clean a Game Boy Cartridge: passo 3, imagem 2 %32
    • Push down until the game "locks" into place, and the top of the game is a small amount beneath the top of the system.
  4. How to clean a Game Boy Cartridge: passo 4, imagem 1 %32
    • If game does not load when the system is turned on, turn off system and remove cartridge.
    • Remove cartridge by placing thumb on the outside of the cartridge near the indentation and pushing up. Dislodging the cartridge from the cartridge reader.
  5. How to clean a Game Boy Cartridge: passo 5, imagem 1 %32 How to clean a Game Boy Cartridge: passo 5, imagem 2 %32
    • Apply some air into the cartridge bottom and into the cartridge reader itself.
    • Reinsert cartridge and try again.
    • If problem still persists, an internal problem may be the culprit.
    Please don't blow in it.
    Use compressed air, or clean the pins with 90+% isopropyl alcohol.
    Harley - Responder
    Attention que souffler dans la cartouche peut entrainer de l'oxydation, il est préférable soit d'utiliser une bombe d'air sec soit de frotter la piste de lecture de la cartouche avec un coton-tige et de l'alcool isopropylique.
    Guillaume Malecha - Responder
Conclusão
To play another game, remove cartridge and place new one in cartridge reader.
17 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Andrew Tramposch
Membro desde: 06/24/10
2.267 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 3-2, Johann Summer 2010 Membro de Cal Poly, Team 3-2, Johann Summer 2010
CPSU-JOHANN-R10S3G2
3 Membros
Autoria de 36 guias
5Comentários do guia
Step one: blow into the game
Bry W - Responder
This guide is completely unhelpful with how to clean a GameBoy game.
It would be better to refer to these videos on how to clean old game cartridges:
- https://www.youtube.com/watch?v=K4SCpHgW...
- https://www.youtube.com/watch?v=4Ej2Y2ch...
Ervin - Responder
Nothing like a good ol’ blow job to get those old cartridges feeling new again.
Igor Kolosha - Responder
my copy of frogger 2 still wont work
mail jack - Responder
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 38
Últimos 30 dias: 116
Ao todo: 21,844
