Ir para o conteúdo principal
How to Replace a Standard Door Lock
Sanjeeve Krishnamoorthy
Sanjeeve Krishnamoorthy e 2 outros colaboradores
Última atualização em 10 de jun de 2021
15 minutos
Fácil
Introdução
Ir para o passo 1
If your door lock has finally succumbed to wear-and-tear or is no longer functioning the way it should, the steps in this guide will show you how to fully replace and install a new one.
A faulty door lock can lead to an unsafe environment and potentially cause harm to those occupying the property.
Before using this guide, ensure that the area around the lock and the door is clear of any debris that may interfere with the removal and installation of the new lock. Generally a small brush or cloth can be used to clear a small build up of dust or debris.
Additionally, make sure a cloth or container is placed below the door in case the lock falls off during installation to ensure no damage is done to the floor.
This fix should be relatively straight-forward and will take around 15-20 minutes to complete and won’t require any special skills.
Once you’ve cleared the area and have your tools ready, please proceed to step 1!
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. How to Replace a Standard Door Lock, Standard Door Lock: passo 1, imagem 1 %32 How to Replace a Standard Door Lock, Standard Door Lock: passo 1, imagem 2 %32
    • Place a piece of tape on both sides of the lock to ensure it doesn’t fall on the floor once unscrewed.
    • Make sure enough tape is placed on the lock as the current door lock may be heavier than expected and could fall off once unscrewed.
    • Ensure the surrounding area is free of any debris or dust that may interfere with the installation.
    • Place a towel, cloth, or even a container/bucket on the area below the door in case the lock falls to ensure no damage is done to the floor or the surrounding area.
  2. How to Replace a Standard Door Lock: passo 2, imagem 1 %32
    • Use your Phillips #0 screwdriver to remove the two 70 mm pan head screws on the side that holds the lock in place.
    • Hold one side of the lock for extra stability if required.
  3. How to Replace a Standard Door Lock: passo 3, imagem 1 %32 How to Replace a Standard Door Lock: passo 3, imagem 2 %32
    • Remove the tape on both sides of the lock carefully.
  4. How to Replace a Standard Door Lock: passo 4, imagem 1 %32 How to Replace a Standard Door Lock: passo 4, imagem 2 %32 How to Replace a Standard Door Lock: passo 4, imagem 3 %32
    • Align your new lock with the given holes on the door.
  5. How to Replace a Standard Door Lock: passo 5, imagem 1 %32 How to Replace a Standard Door Lock: passo 5, imagem 2 %32
    • Place a piece of tape on both sides of the new lock to ensure the lock does not move when placing the screws.
    • Make sure the enough tape is placed on the lock as it may fall off depending on the weight of the door lock.
    • Place a cloth or container underneath the lock in case it falls off to ensure no damage is done to the floor or the surrounding area.
  6. How to Replace a Standard Door Lock: passo 6, imagem 1 %32 How to Replace a Standard Door Lock: passo 6, imagem 2 %32 How to Replace a Standard Door Lock: passo 6, imagem 3 %32
    • Place the 70 mm pan head screws in the given holes and use your Phillips #0 screwdriver to screw them in accordingly.
Conclusão
Congratulations! You have successfully installed your new door lock!
Uma outra pessoa concluiu este guia.
Gear Up For Future Repairs
Shop all
Membro desde: 01/19/21
133 Reputação
Autoria de 1 guia
1Comentário do guia
Hi Sanjeeve, this is a great guide its really helpful with the photos you have included here to really walk you through it. I am going to change my door lock to another type and found this article with other types of door locks helpful for that.
Terry - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 30
Ao todo: 887
