Ir para o conteúdo principal
How to Attach Googly Eyes to the Anti-Clamp
Alex Diaz-Kokaisl
Alex Diaz-Kokaisl e 2 outros colaboradores
Última atualização em 16 de set de 2024
2 - 5 minutos
Fácil
Introdução
Ir para o passo 1
Use this guide to attach googly eyes to your Anti-Clamp.
The personified Anti-Clamp is colloquially referred to as Clampy, but you can name it whatever you want, e.g., Clampalot, Clampus, John, etc.
For tips on how to tame Clampy, follow this guide.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. How to Attach Googly Eyes to the Anti-Clamp, Clean Clampy: passo 1, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Clean Clampy: passo 1, imagem 2 %32
    • Before you begin, wipe down Clampy to ensure a clean surface for the googly eyes to adhere to.
  2. How to Attach Googly Eyes to the Anti-Clamp, Peel off the liner: passo 2, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Peel off the liner: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers, or your fingers, to peel off the paper liner and expose the googly eye's adhesive.
    • Repeat the previous two steps for Clampy's second eye (unless you want a Cyclops Clampy).
  3. How to Attach Googly Eyes to the Anti-Clamp, Peel off the adhesive: passo 3, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Peel off the adhesive: passo 3, imagem 2 %32 How to Attach Googly Eyes to the Anti-Clamp, Peel off the adhesive: passo 3, imagem 3 %32
    • If you want to use alternate adhesive, follow the next three steps. Otherwise, skip to this step.
    • Use tweezers to peel off a portion of pre-cut adhesive.
    • It doesn't have to be a lot of adhesive—just enough to allow the googly eye to stick securely.
    • You can also use double-sided tape instead of pre-cut adhesive. Clampy isn't picky.
  4. How to Attach Googly Eyes to the Anti-Clamp, Apply the adhesive to the eye: passo 4, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Apply the adhesive to the eye: passo 4, imagem 2 %32 How to Attach Googly Eyes to the Anti-Clamp, Apply the adhesive to the eye: passo 4, imagem 3 %32
    • Place the sticky side of the adhesive on the back of a googly eye.
    • Press down on the adhesive to ensure it's fully adhered to the eye.
  5. How to Attach Googly Eyes to the Anti-Clamp, Peel off the liner: passo 5, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Peel off the liner: passo 5, imagem 2 %32 How to Attach Googly Eyes to the Anti-Clamp, Peel off the liner: passo 5, imagem 3 %32
    • Peel off the remaining liner to expose the adhesive.
    • Repeat the previous three steps for Clampy's second eye.
    • The only thing limiting the amount of eyes Clampy can have is your imagination.
    I want a cyclops clampy
    Clay Eickemeyer - Responder
  6. How to Attach Googly Eyes to the Anti-Clamp, Apply the eyes: passo 6, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Apply the eyes: passo 6, imagem 2 %32 How to Attach Googly Eyes to the Anti-Clamp, Apply the eyes: passo 6, imagem 3 %32
    • You are about to perform the repair equivalent of ocular surgery! Proceed with caution and care for Clampy.
    • Place the googly eyes on the top arm of Clampy, just above the suction cups.
    • Press down on each eye to ensure they fully adhere to Clampy.
  7. How to Attach Googly Eyes to the Anti-Clamp, Alternative eye positions: passo 7, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Alternative eye positions: passo 7, imagem 2 %32 How to Attach Googly Eyes to the Anti-Clamp, Alternative eye positions: passo 7, imagem 3 %32
    • Depending on your Clampy's personality, you can position its eyes in various ways.
    • The following images are some examples of alternative Clampy styles:
    • Prey Clampy
    • Suction-Cup-For-Feet Clampy
    • Snail Clampy
  8. How to Attach Googly Eyes to the Anti-Clamp, Feed Clampy: passo 8, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Feed Clampy: passo 8, imagem 2 %32 How to Attach Googly Eyes to the Anti-Clamp, Feed Clampy: passo 8, imagem 3 %32
    • Congratulations, you have given Clampy the gift of sight! However, it will now hunger for devices to open.
    • Give your Clampy something modest to open, like an iPhone 13 mini.
    • Make sure to remove the two P2 Pentalobe screws from the iPhone before giving it to Clampy.
  9. How to Attach Googly Eyes to the Anti-Clamp: passo 9, imagem 1 %32
    • Watch Clampy open the device like a pro.
    • If your Clampy isn't sated, follow the next step.
  10. How to Attach Googly Eyes to the Anti-Clamp: passo 10, imagem 1 %32
    • Give your Clampy something larger, like an iPhone 13 Pro.
    • Watch Clampy open this device with ease.
    • If your Clampy seems to open this device even faster...almost like its appetite is growing, follow the next step.
  11. How to Attach Googly Eyes to the Anti-Clamp: passo 11, imagem 1 %32
    • Give your Clampy something monstrous, like an iPhone 13 Pro Max.
    • Watch Clampy lose control of itself and tear open the phone with unnecessary violence.
    • If you've run out of options, follow the next step.
  12. How to Attach Googly Eyes to the Anti-Clamp, Witness Clampy: passo 12, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Witness Clampy: passo 12, imagem 2 %32 How to Attach Googly Eyes to the Anti-Clamp, Witness Clampy: passo 12, imagem 3 %32
    Clampy - Anti-Clamp
    $24.95
    • Witness Clampy sit atop his pile of victims, each a testimony to his power of suction.
    • Legends tell of a clamp so powerful that even iPads shiver when they hear its name. Mothers all over the world tell their children that if they use too much adhesive on their electronics, a certain clamp will visit you in the night—and that clamp will show no mercy. These are only tales, however.
    • But, perhaps you've invoked this clamp-like being by attaching googly eyes to the Anti-Clamp. And that being's name is...
    • Clampy
Conclusão
To send Clampy back to the realm of repair gods, follow the instructions in reverse order.
40 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Alex Diaz-Kokaisl
Membro desde: 01/16/22
184.798 Reputação
Autoria de 857 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 22.751 guias
5Comentários do guia
I love this♥️💙💜💛🖤💚🧡🤍🤎
This is AMAZING!!!!!!
HelloMacOS - Responder
Clampy is hungry.
HeyItzRare - Responder
I love this website so much XD
MeowMix64 - Responder
My little clamps killed several friends of apple, and I rewarded it of course!
Ben Capehart - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 39
Últimos 30 dias: 157
Ao todo: 5,094
