Ir para o conteúdo principal
How to Attach Googly Eyes to the Anti-Clamp
O que você precisa
  1. How to Attach Googly Eyes to the Anti-Clamp, Clean Clampy: passo 1, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Clean Clampy: passo 1, imagem 2 %32
    • Before you begin, wipe down Clampy to ensure a clean surface for the googly eyes to adhere to.
  2. How to Attach Googly Eyes to the Anti-Clamp, Peel off the liner: passo 2, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Peel off the liner: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers, or your fingers, to peel off the paper liner and expose the googly eye's adhesive.
    • Repeat the previous two steps for Clampy's second eye (unless you want a Cyclops Clampy).
  3. How to Attach Googly Eyes to the Anti-Clamp, Peel off the adhesive: passo 3, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Peel off the adhesive: passo 3, imagem 2 %32 How to Attach Googly Eyes to the Anti-Clamp, Peel off the adhesive: passo 3, imagem 3 %32
    • If you want to use alternate adhesive, follow the next three steps. Otherwise, skip to this step.
    • Use tweezers to peel off a portion of pre-cut adhesive.
    • It doesn't have to be a lot of adhesive—just enough to allow the googly eye to stick securely.
    • You can also use double-sided tape instead of pre-cut adhesive. Clampy isn't picky.
  4. How to Attach Googly Eyes to the Anti-Clamp, Apply the adhesive to the eye: passo 4, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Apply the adhesive to the eye: passo 4, imagem 2 %32 How to Attach Googly Eyes to the Anti-Clamp, Apply the adhesive to the eye: passo 4, imagem 3 %32
    • Place the sticky side of the adhesive on the back of a googly eye.
    • Press down on the adhesive to ensure it's fully adhered to the eye.
  5. How to Attach Googly Eyes to the Anti-Clamp, Peel off the liner: passo 5, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Peel off the liner: passo 5, imagem 2 %32 How to Attach Googly Eyes to the Anti-Clamp, Peel off the liner: passo 5, imagem 3 %32
    • Peel off the remaining liner to expose the adhesive.
    • Repeat the previous three steps for Clampy's second eye.
    • The only thing limiting the amount of eyes Clampy can have is your imagination.
  6. How to Attach Googly Eyes to the Anti-Clamp, Apply the eyes: passo 6, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Apply the eyes: passo 6, imagem 2 %32 How to Attach Googly Eyes to the Anti-Clamp, Apply the eyes: passo 6, imagem 3 %32
    • You are about to perform the repair equivalent of ocular surgery! Proceed with caution and care for Clampy.
    • Place the googly eyes on the top arm of Clampy, just above the suction cups.
    • Press down on each eye to ensure they fully adhere to Clampy.
  7. How to Attach Googly Eyes to the Anti-Clamp, Alternative eye positions: passo 7, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Alternative eye positions: passo 7, imagem 2 %32 How to Attach Googly Eyes to the Anti-Clamp, Alternative eye positions: passo 7, imagem 3 %32
    • Depending on your Clampy's personality, you can position its eyes in various ways.
    • The following images are some examples of alternative Clampy styles:
    • Prey Clampy
    • Suction-Cup-For-Feet Clampy
    • Snail Clampy
  8. How to Attach Googly Eyes to the Anti-Clamp, Feed Clampy: passo 8, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Feed Clampy: passo 8, imagem 2 %32 How to Attach Googly Eyes to the Anti-Clamp, Feed Clampy: passo 8, imagem 3 %32
    • Congratulations, you have given Clampy the gift of sight! However, it will now hunger for devices to open.
    • Give your Clampy something modest to open, like an iPhone 13 mini.
    • Make sure to remove the two P2 Pentalobe screws from the iPhone before giving it to Clampy.
  9. How to Attach Googly Eyes to the Anti-Clamp: passo 9, imagem 1 %32
    • Watch Clampy open the device like a pro.
    • If your Clampy isn't sated, follow the next step.
  10. How to Attach Googly Eyes to the Anti-Clamp: passo 10, imagem 1 %32
    • Give your Clampy something larger, like an iPhone 13 Pro.
    • Watch Clampy open this device with ease.
    • If your Clampy seems to open this device even faster...almost like its appetite is growing, follow the next step.
  11. How to Attach Googly Eyes to the Anti-Clamp: passo 11, imagem 1 %32
    • Give your Clampy something monstrous, like an iPhone 13 Pro Max.
    • Watch Clampy lose control of itself and tear open the phone with unnecessary violence.
    • If you've run out of options, follow the next step.
  12. How to Attach Googly Eyes to the Anti-Clamp, Witness Clampy: passo 12, imagem 1 %32 How to Attach Googly Eyes to the Anti-Clamp, Witness Clampy: passo 12, imagem 2 %32 How to Attach Googly Eyes to the Anti-Clamp, Witness Clampy: passo 12, imagem 3 %32
    Clampy - Anti-Clamp
    $24.95
    • Witness Clampy sit atop his pile of victims, each a testimony to his power of suction.
    • Legends tell of a clamp so powerful that even iPads shiver when they hear its name. Mothers all over the world tell their children that if they use too much adhesive on their electronics, a certain clamp will visit you in the night—and that clamp will show no mercy. These are only tales, however.
    • But, perhaps you've invoked this clamp-like being by attaching googly eyes to the Anti-Clamp. And that being's name is...
    • Clampy
Conclusão
To send Clampy back to the realm of repair gods, follow the instructions in reverse order.
40 outras pessoas executaram este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
213.574 Reputação
Autoria de 1.040 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.649 guias
5Comentários do guia
I love this♥️💙💜💛🖤💚🧡🤍🤎
This is AMAZING!!!!!!
HelloMacOS - Responder
Clampy is hungry.
HeyItzRare - Responder
I love this website so much XD
MeowMix64 - Responder
My little clamps killed several friends of apple, and I rewarded it of course!
Ben Capehart - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 38
Últimos 30 dias: 149
Ao todo: 5,688
