HP Envy TouchSmart 15 Wireless Adapter Replacement
Introdução
Ir para o passo 1You may need to replace the wireless adapter if your computer can't connect to any wireless network. Be sure that you do not break the antenna connector wires.
O que você precisa
Peças
Ferramentas
Exibir mais…
Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
Remove the screw with PH 0 screwdriver that is holding the wireless adapter in. This is PM 2.0x2.5 screws.
Hold the wireless adapter and gently remove the white and black wires from it. The connectors will come out straight up.
Hi
Today I open my laptop to clean up a bit of dust. and by mistakenly I break black connector. not the thing is that the connector part from wireless card stuck inside black cable. but i can still use wifi without any problem. my question is " Is there any affect on my laptop if i leave it like this ?" and another question what is the functioning of that black cable ?
hope I will get reply soon.please reply me on ronak.r.30588@gmail.com
Thank you
Ronak
4 outras pessoas executaram este guia.
1Comentário do guia
Hi, I use this exact laptop but my wifi card was changed and it didn’t come with Bluetooth so i wanted to know if this
”https://www.aliexpress.com/item/Dual-Ban...
can work for me and if its OK to buy it. Thanks
