Ir para o conteúdo principal
HP Envy TouchSmart 15 Wireless Adapter Replacement
O que você precisa
  1. HP Envy TouchSmart 15 Wireless Adapter Replacement, Battery: passo 1, imagem 1 %32
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 2, imagem 1 %32
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: passo 3, imagem 1 %32 HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: passo 3, imagem 2 %32
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 4, imagem 1 %32 HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 4, imagem 2 %32 HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 4, imagem 3 %32
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: passo 5, imagem 1 %32 HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: passo 5, imagem 2 %32
    • Remove the screw with PH 0 screwdriver that is holding the wireless adapter in. This is PM 2.0x2.5 screws.
  6. HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 6, imagem 1 %32 HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 6, imagem 2 %32 HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 6, imagem 3 %32
    • Hold the wireless adapter and gently remove the white and black wires from it. The connectors will come out straight up.
    Hi
    Today I open my laptop to clean up a bit of dust. and by mistakenly I break black connector. not the thing is that the connector part from wireless card stuck inside black cable. but i can still use wifi without any problem. my question is " Is there any affect on my laptop if i leave it like this ?" and another question what is the functioning of that black cable ?
    hope I will get reply soon.please reply me on ronak.r.30588@gmail.com
    Thank you
    Ronak
    Ronnie M - Responder
Conclusão
4 outras pessoas executaram este guia.
Robert Patterson
Membro desde: 09/04/15
1.457 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 2-6, Sullivan Fall 2015 Membro de USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 Membros
Autoria de 10 guias
1Comentário do guia
Hi, I use this exact laptop but my wifi card was changed and it didn’t come with Bluetooth so i wanted to know if this
https://www.aliexpress.com/item/Dual-Ban...
can work for me and if its OK to buy it. Thanks
temidayoabayomizannu - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 24
Ao todo: 3,244
