Ir para o conteúdo principal
HP EliteBook 840 G7 Battery Replacement
Pedro Ramos Espinoza
Pedro Ramos Espinoza e 2 outros colaboradores
Última atualização em March 20, 2025
15 minutos
Fácil
Guia colaborativo
Introdução
Ir para o passo 1
This guide will show you how to replace the battery on a HP Elitebook 840 G7. You can remove and replace your battery by simply following these steps.
The battery powers the device so that it can operate without an external power source.
To know if you have a faulty battery signs include: Fast loss of power, Does not power up, Fails to power on without external power source.
Before using this guide be sure to look at out troubleshooting page to ensure that the battery is the problem.
O que você precisa
Ferramentas
  1. HP EliteBook 840 G7 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 Battery Replacement: passo 2, imagem 1 %32
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 Battery Replacement: passo 3, imagem 1 %32
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 Battery Replacement: passo 4, imagem 1 %32 HP EliteBook 840 G7 Battery Replacement: passo 4, imagem 2 %32 HP EliteBook 840 G7 Battery Replacement: passo 4, imagem 3 %32
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 Battery Replacement: passo 5, imagem 1 %32 HP EliteBook 840 G7 Battery Replacement: passo 5, imagem 2 %32 HP EliteBook 840 G7 Battery Replacement: passo 5, imagem 3 %32
    • Lift up the battery with you hands or tools.
Conclusão
Equipe
Gateway, Team 1-1, Pee Spring 2022 Membro de Gateway, Team 1-1, Pee Spring 2022
GCC-PEE-S22S1G1
4 Membros
Autoria de 12 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 53
Últimos 30 dias: 187
Ao todo: 3,667
