Ir para o conteúdo principal
DualSense Controller v2 Battery Replacement
Sam Omiotek
Sam Omiotek e 3 outros colaboradores
Última atualização em March 8, 2025
15 - 30 minutos
Moderado
Guia em destaque
Introdução
Ir para o passo 1
Follow this guide to replace the battery on your Sony DualSense controller.
If your battery is swollen, take appropriate precautions.
Note: This guide is for current DualSense controllers with FCC IDs that end with A. Check the back of your controller to verify your model. If yours ends in a 1, it is an early model and there will be internal differences. Follow these guides for the earlier version.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. DualSense Controller v2 Battery Replacement, Unclip the right end of the middle trim: passo 1, imagem 1 %32 DualSense Controller v2 Battery Replacement, Unclip the right end of the middle trim: passo 1, imagem 2 %32
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller v2 Battery Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 1 %32 DualSense Controller v2 Battery Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 2 %32 DualSense Controller v2 Battery Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 3 %32
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller v2 Battery Replacement, Unclip the left end of the middle trim: passo 3, imagem 1 %32 DualSense Controller v2 Battery Replacement, Unclip the left end of the middle trim: passo 3, imagem 2 %32
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller v2 Battery Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 1 %32 DualSense Controller v2 Battery Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 2 %32 DualSense Controller v2 Battery Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 3 %32
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller v2 Battery Replacement, Remove the middle trim: passo 5, imagem 1 %32 DualSense Controller v2 Battery Replacement, Remove the middle trim: passo 5, imagem 2 %32 DualSense Controller v2 Battery Replacement, Remove the middle trim: passo 5, imagem 3 %32
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
  6. DualSense Controller v2 Battery Replacement, Remove the L1 button: passo 6, imagem 1 %32 DualSense Controller v2 Battery Replacement, Remove the L1 button: passo 6, imagem 2 %32 DualSense Controller v2 Battery Replacement, Remove the L1 button: passo 6, imagem 3 %32
    • Insert the flat end of your spudger into the gap above the L1 button.
    • Cover the button with your thumb to prevent it from ejecting across the room.
    • Pry the spudger upward to remove the L1 button.
  7. DualSense Controller v2 Battery Replacement, Remove the R1 button: passo 7, imagem 1 %32 DualSense Controller v2 Battery Replacement, Remove the R1 button: passo 7, imagem 2 %32 DualSense Controller v2 Battery Replacement, Remove the R1 button: passo 7, imagem 3 %32
    • Insert the flat end of your spudger into the gap above the R1 button.
    • Pry the spudger upward to remove the R1 button.
  8. DualSense Controller v2 Battery Replacement, Remove the case screws: passo 8, imagem 1 %32
    • Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
  9. DualSense Controller v2 Battery Replacement: passo 9, imagem 1 %32
    • Use a Phillips screwdriver to remove the two 6.5 mm screws behind the L1 and R1 buttons.
  10. DualSense Controller v2 Battery Replacement, Unclip the rear case: passo 10, imagem 1 %32 DualSense Controller v2 Battery Replacement, Unclip the rear case: passo 10, imagem 2 %32 DualSense Controller v2 Battery Replacement, Unclip the rear case: passo 10, imagem 3 %32
    • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
  11. DualSense Controller v2 Battery Replacement, Remove the rear case: passo 11, imagem 1 %32 DualSense Controller v2 Battery Replacement, Remove the rear case: passo 11, imagem 2 %32
    • Use your hands to carefully pull the rear case off of the controller.
    • During reassembly, make sure the red and black vibration motor wires are not pinched between the front and rear case.
    You can´t just grab both ends and expect it to open flawlessly, first you gotta travel the spudger around the seam at the outer edges of the controller, there are multiples clips in that area, there a couple really hard to get out at the outer edges of the R1 and L1 buttons, for those you need to insert the spudger bending outwards the bottom piece of the controller (a fairly amount, like 1.5mm) and while bending outwards use the same inserted spudger to lever them apart carefully, the plastic will bend quite a bit so be very careful with the motion of the spudger.
    Yet again, that was my personal experience opening it up, try first as the guide says, if you feel the upper and bottom pieces glued around the R1 and L1, then try this.
    Carlos Santana - Responder
    I had the same experience, the best way to reach these for me was to place the spunger from L1 R1 side whilst using a spunger to press outwards from the side like in Carlos's comment. Thank you Carlos I was struggling with this!
    Remco geuze -
    This did not work for me. Finally I just pulled the two parts apart at the bottom side, carefully twisting and manipulating until the parts clicked loose at the top side
    Gilian Mischker -
    This is the biggest hassle in the whole process. It seems that all controllers now come with those extra clips that other people mentioned here. I, however, didn't have the same success with their steps of running a spudger on the sides to undo the clip. Looking around, I found this Youtube video showing that you can undo the clips simply by twisting up from the bottom. Do it carefully because it pops off easily using this method - when I did, I used some force and the back just flew from my table.
    I found it easier like that and was able to continue the process.
    Rodrigo Castro - Responder
    +1 to this. None of the suggestions worked well enough for me, but this video clip got this step done for me nearly instantly. note the position of the tech's fingers and thumbs - I copied that exactly and had no issue.
    Nathan K -
  12. DualSense Controller v2 Battery Replacement, Reposition the battery: passo 12, imagem 1 %32 DualSense Controller v2 Battery Replacement, Reposition the battery: passo 12, imagem 2 %32
    • Lift the battery out of its bracket and reposition it to the right for better access to the battery connector.
    • Don't strain the battery cables.
  13. DualSense Controller v2 Battery Replacement, Disconnect the battery: passo 13, imagem 1 %32 DualSense Controller v2 Battery Replacement, Disconnect the battery: passo 13, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Don't pull on the wires to disconnect the battery.
  14. DualSense Controller v2 Battery Replacement, Remove the battery: passo 14, imagem 1 %32
    • Remove the battery.
Conclusão
4 outras pessoas executaram este guia.
Sam Omiotek
Membro desde: 02/25/19
85.752 Reputação
Autoria de 290 guias
1Comentário do guia
The guide was very helpful for most everything. I did have trouble prying off the back plate, what wasn’t clear was that clips near the L1 & R1 need to be pried ~ 1.5 mm with a spudger in the direction of the face buttons and not the back plate.
Tamasyn Hawke - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 105
Últimos 30 dias: 413
Ao todo: 12,178
