Ir para o conteúdo principal
Dirt Devil Gator Battery Replacement
Ryan Marando
Ryan Marando e 3 outros colaboradores
Última atualização em April 29, 2020
15 - 30 minutos
Moderado
Introdução
Ir para o passo 1
If your Dirt Devil Gator (Model Number: BD10100) isn’t starting or staying on for more than 15 seconds, you may need to replace the battery. Follow this guide to replace the battery to keep your Dirt Devil Gator in use!
However before using this guide, you may not need to full replace the battery, just charge it! A dead battery is a simple problem with a quick fix to get you started vacuuming again quickly!
The battery on the Dirt Devil Gator keeps the machine on and the air flow working, so it can suction dirt and debris. A dead/damaged battery will not power on the device resulting in a possible replacement needing to occur.
Step 5 requires you to remove the battery from the motor. From there, you must desolder and cut wires to replace the old battery with the new one. Follow this guide to desolder and solder connections properly!
Before beginning, make sure to power off your device completely and disconnect from any external power source.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Dirt Devil Gator Battery Replacement, Battery: passo 1, imagem 1 %32
    • Press the button on the middle of the vacuum by pushing down on it and pulling the device apart.
  2. Dirt Devil Gator Battery Replacement: passo 2, imagem 1 %32 Dirt Devil Gator Battery Replacement: passo 2, imagem 2 %32 Dirt Devil Gator Battery Replacement: passo 2, imagem 3 %32
    • Separate the vacuum by pulling on the back of the vacuum. There should not be heavy resistance when pulling.
    Note the comma splice in the second step here.
    Alex Watkins - Responder
  3. Dirt Devil Gator Battery Replacement: passo 3, imagem 1 %32 Dirt Devil Gator Battery Replacement: passo 3, imagem 2 %32 Dirt Devil Gator Battery Replacement: passo 3, imagem 3 %32
    • Unscrew each of the 13 mm screws with the micro screwdriver from the vacuum.
    • Once unscrewed, pull the case of the Dirt Devil Gator apart.
    The third bullet here is unclear to me. Can you revise for clarity?
  4. Dirt Devil Gator Battery Replacement: passo 4, imagem 1 %32 Dirt Devil Gator Battery Replacement: passo 4, imagem 2 %32 Dirt Devil Gator Battery Replacement: passo 4, imagem 3 %32
    • Pull out the grey switch and circuit board from its slot in the red case.
    • Remove all of the wires from the vacuum to where only the battery and wires are left.
    • Firmly pull out the battery and motor assembly. The circuit board and wires will remain attached.
  5. Dirt Devil Gator Battery Replacement: passo 5, imagem 1 %32 Dirt Devil Gator Battery Replacement: passo 5, imagem 2 %32
    • Cut the white and black wires with wire cutters to disconnect battery from the motor. Follow this guide to desolder!
    • Remove the tan couplings from their white sockets and replace with new batteries.
    • If the battery is torn or has battery acid around it, do not touch the battery. Safely dispose the battery. If come into contact with acid, wash hands thoroughly.
    Note that these are reassembly steps, so not necessary. Some of this information should be in the introduction, and some in the troubleshooting page. Also, you could use a reminder bullet if it’s going to influence how the device goes back together.
    Where can one purchase replacement batteries? I’ve had no luck searching online so far. Would appreciate any help. Thanks!
    Francis Albrecht - Responder
Conclusão
To reassemble your device, follow these instructions in reverse order. The battery is not likely to fail, but if it does when following these steps, you will see something immediately wrong.
Uma outra pessoa concluiu este guia.
3Comentários do guia
So, where can I purchase a battery replacement?
ed1660wmh - Responder
You neglected to mention one VITAL item, what is the part number for the replacement batteries or where does one find those? I've searched all over the internet and cannot find them anywhere. The company says they are NOT user serviceable or replaceable parts. For me, it's not a matter of being able to the job, I definitely can, but it is not possible without the parts.
Vince Pepple - Responder
Judging by the pictures, the battery seems to be comprised of standard sub-c NiCd cells.
You would probably also be able to use NiMh cells, which would grant you a little more runtime and can be bought pretty much everywhere.
RobinKemen - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 17
Últimos 30 dias: 59
Ao todo: 7,489
