Ir para o conteúdo principal
DJI Phantom 2 Vision Plus GPS Signal Improvement Technique
Sam Goldheart
Sam Goldheart
Última atualização em February 25, 2015
Nenhuma estimativa
Moderado
Introdução
Ir para o passo 1
Follow this video guide to decrease interference from the Wifi module and increase GPS signal strength.
The guide instructions are written, and the only audio is music, and will not be suitable for the visually impaired. You can follow our case top shell guide to remove the cover, and watch the video to learn how to move the GPS cable and add shielding.
O que você precisa
Ferramentas
Exibir mais…
Vídeo de Apresentação
  1. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Case Top Shell: passo 1, imagem 1 %32 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Case Top Shell: passo 1, imagem 2 %32
    • Remove the following screws from the underside of the Phantom:
    • Twelve 2.0 mm hex bolts
    • Four Phillips #00 screws
  2. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique: passo 2, imagem 1 %32 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique: passo 2, imagem 2 %32
    • Gently lift up the top shell case.
    • Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
  3. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: passo 3, imagem 1 %32 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: passo 3, imagem 2 %32 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: passo 3, imagem 3 %32
    • The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
    • Pull the GPS connector straight up out of its socket.
    • Lift the top shell case up and remove it from the body of the Phantom.
Conclusão
4 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
472.121 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
121 Membros
Autoria de 19.812 guias
3Comentários do guia
hello do you still help with phantom drones
George Aguirre - Responder
do you still help with drones/
Isn't it better to connect the aluminium foil to the GPS GND for better isolation?
Bruno Duarte - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 4,663
