Ir para o conteúdo principal
Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement
Jeff Suovanen
Jeff Suovanen e um outro colaborador
Última atualização em January 21, 2020
Nenhuma estimativa
Moderado
Introdução
Ir para o passo 1
Follow these instructions to remove and replace the cutting blade, either to sharpen a dull blade or replace it entirely.
  1. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Spark Plug Disconnection: passo 1, imagem 1 %32 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Spark Plug Disconnection: passo 1, imagem 2 %32
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Blade: passo 2, imagem 1 %32 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Blade: passo 2, imagem 2 %32 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Blade: passo 2, imagem 3 %32
    • Lift to raise the front end of the brush cutter.
    • Place a jack stand or other secure support under the deck to prevent the brush cutter from tipping forward.
  3. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: passo 3, imagem 1 %32 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: passo 3, imagem 2 %32 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: passo 3, imagem 3 %32
    • Use a 13/16" socket to remove the bolt securing the blade.
    • If needed, wedge a wood block between the blade and the deck to prevent the blade from turning.
    • During reassembly, make sure the blade is fully seated on the spindle, and use a torque wrench to tighten the bolt to 33-38 ft lbs.
  4. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: passo 4, imagem 1 %32 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: passo 4, imagem 2 %32 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: passo 4, imagem 3 %32
    • Wear gloves or be careful when handling the blade.
    • Remove the bolt and friction washer, and remove the blade.
    • Use a new bolt and washer when replacing the blade.
    • If the large cylindrical blade adapter falls off the spindle, check to make sure the key is correctly positioned inside the adapter, and then align the key with the notch on the spindle when installing it.
  5. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: passo 5, imagem 1 %32 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: passo 5, imagem 2 %32 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: passo 5, imagem 3 %32
    • Use a 3/8" socket or wrench to remove the four 21 mm bolts securing the top cover to the deck.
  6. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: passo 6, imagem 1 %32 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: passo 6, imagem 2 %32
    • Lift and remove the top cover.
  7. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: passo 7, imagem 1 %32
    • Using a 9/16” socket or wrench, make sure the bolt at the top of the spindle is tight.
Conclusão
Jeff Suovanen
Membro desde: 08/06/13
440.041 Reputação
Autoria de 259 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.623 guias
Um comentário
how about a part number for the replacement blade that you show how to change,
ALLAN - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 35
Ao todo: 2,651
