Ir para o conteúdo principal
Atari 5200 Entertainment System Power Button Replacement
Alan Abelson
Alan Abelson e 6 outros colaboradores
Última atualização em 3 de ago de 2019
15 - 20 minutos
Fácil
Introdução
Ir para o passo 1
If your Atari Entertainment System has a power button that needs to be repaired, this guide will take you step-by-step on how to gain access to the power button in order to repair it.
O que você precisa
Peças
Ferramentas
  1. Atari 5200 Entertainment System Power Button Replacement, Entertainment System Power Button: passo 1, imagem 1 %32
    • Gently flip the Atari Entertainment System over. You'll see 7 screws holding the system together. Use a philips head screw driver to remove all seven screws.
    • Pictured above is the Atari 5200 upside down. The orange edited circles over all 7 screws.
  2. Atari 5200 Entertainment System Power Button Replacement: passo 2, imagem 1 %32
    • Gently flip the Atari Entertainment System over to the front side. Remove the top.
  3. Atari 5200 Entertainment System Power Button Replacement: passo 3, imagem 1 %32 Atari 5200 Entertainment System Power Button Replacement: passo 3, imagem 2 %32 Atari 5200 Entertainment System Power Button Replacement: passo 3, imagem 3 %32
    • There are orange objects on the side of the system's top, pinch them.
    • If the triangles cannot be gripped, push the power button on the opposite side. This will lift the triangle to give access to easier grip.
  4. Atari 5200 Entertainment System Power Button Replacement: passo 4, imagem 1 %32 Atari 5200 Entertainment System Power Button Replacement: passo 4, imagem 2 %32 Atari 5200 Entertainment System Power Button Replacement: passo 4, imagem 3 %32
    • The Power button can now be removed/clean/replaced.
    • Be sure to keep an eye on the spring.
Conclusão
Gear Up For Future Repairs
Shop all
Alan Abelson
Membro desde: 09/26/14
233 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 13-1, Staggers Fall 2014 Membro de USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Membros
Autoria de 17 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 1,707
