Ir para o conteúdo principal
Apple Pencil (2nd Generation) Tips Replacement
tayola
tayola e 2 outros colaboradores
Última atualização em April 24, 2025
30 segundos
Muito fácil
Pontos lista!
Guia colaborativo
Introdução
Ir para o passo 1
This guide will help you replace your Apple Pencil tip.
  1. Apple Pencil (2nd Generation) Tips Replacement, Preparation: passo 1, imagem 1 %32 Apple Pencil (2nd Generation) Tips Replacement, Preparation: passo 1, imagem 2 %32 Apple Pencil (2nd Generation) Tips Replacement, Preparation: passo 1, imagem 3 %32
    • Grab your Apple Pencil Second Generation.
    • Make sure you have replacement tips. You can buy them from Apple or from 3rd party vendors on Amazon.
  2. Apple Pencil (2nd Generation) Tips Replacement, Unscrewing and Installing the tip: passo 2, imagem 1 %32
    • To take off your Apple Pencil's current tip, squeeze it between two fingers and turn it counterclockwise to unscrew it. It should come off within seconds.
    • Once it's off, place your new Pencil tip on the metal prong and screw it clockwise until it's tight. Once it stops turning easily, you can let go.
Conclusão
tayola
Membro desde: 07/21/22
9.565 Reputação
Autoria de 44 guias
Equipe
Kid fixers Membro de Kid fixers
Community
188 Membros
Autoria de 274 guias
2Comentários do guia
Ich habe das Problem, daß der "Hals" der Kunststoffspitze im Pencil steckt. Ich bekomme ihn nicht heraus. Hat jemand eine Lösung?
Busso - Responder
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 91
Últimos 30 dias: 449
Ao todo: 21,262
