Ir para o conteúdo principal
Anker 2.4G Wireless Mouse Left and Right Button Replacement
Vincent Lee
Vincent Lee e 10 outros colaboradores
Última atualização em November 27, 2022
10 - 20 minutos
Moderado
Introdução
Ir para o passo 1
Use this guide to replace the left and right mouse buttons on your Anker 2.4G Wireless Mouse.
A mouse button is an electrical switch on the mouse which allows a user to interact with a graphical user interface. They will eventually wear out through continuous use. If you notice the left or right mouse button not working properly all of the time, you may need to replace the left or right mouse button.
Please be sure to check out the troubleshooting page before using this guide. Often times, malfunctioning mouse buttons are a software issue and can be fixed without replacing the left and right mouse buttons.
Step 7 in this guide requires you to desolder the mouse buttons and solder new ones in place.
Make sure that the mouse is turned off before starting.
O que você precisa
Ferramentas
Exibir mais…
  1. Anker 2.4G Wireless Mouse Left and Right Button Replacement, Left and Right Buttons: passo 1, imagem 1 %32
    • Peel off the stickers. This will reveal the location of four screws.
  2. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 2, imagem 1 %32
    • Remove the four screws using a Phillips #0 screwdriver.
  3. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 3, imagem 1 %32 Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 3, imagem 2 %32
    • Use a spudger to pry apart the upper and lower housing of the mouse.
  4. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 4, imagem 1 %32
    • Pull the wires from the white crimping headers to disconnect them. This separates the top housing from the bottom housing.
    • Pull as far up on the wires as possible. Be careful not to rip the wires by applying too much force.
  5. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 5, imagem 1 %32
    • Remove the scroll wheel from the mother board by pulling it to the left.
    • This may take some force to remove. Make sure to pull the scroll wheel parallel to the board, not perpendicularly.
  6. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 6, imagem 1 %32
    • Pull the mother board gently away from the plastic housing.
  7. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 7, imagem 1 %32 Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 7, imagem 2 %32
    • Desolder the components and re-solder the replacements in order to repair the left and right buttons.
Conclusão
Vincent Lee
Membro desde: 01/23/14
361 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 1-39, Maness Winter 2014 Membro de Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Membros
Autoria de 16 guias
2Comentários do guia
i bought the same mouse on amazon the same day i got it stopped working and anker was out of stock so i couldn't get another one directly from them, plus i really like it i opened up the mouse using your step by step and found the issue.
jacques gates - Responder
where can these replacement button switches be purchased….thanks ric
Ric Scambler - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 4,702
