Substituição do capacitor
1 resposta 1 pontos |
A vareta do vapor está partida |
1 resposta 0 pontos |
Um depósito ao tirar dois cafés |
Circuito elétrico da placa da fonteCentro de café totalmente automático De'Longhi ECAM23210B/SB |
Vazamento de água na unidade de infusão |
Documentos
Peças
- Delonghi Water Tank - AS13200250
- Delonghi Rubber Cleandisk (Black) - AS00001634
- Delonghi Filter 1-Dose Coffee with Rib - AS00002564
- Delonghi Glass Carafe - HZ1029
- Delonghi Water Tank - AS13200251
- Delonghi Carbon Filter - 7313285779
- Delonghi Infuser Diffuser Kit - 7313251451
- Delonghi Infusion Kit with Black Push Button - 7313251441
Ferramentas
Modelos
0132301056, 3057, 4185, BAR12, BAR12FU, BAR140, BAR18, BAR32, BAR390, BAR41, BAR42, BAR42E, BAR51, BAR52, BAR6U, BAR8IU, BAR9I, BARM100U, BARM29U, BCM8450UC Exibir 272 mais
BCM8450UC/03, BCM8450UC/04, BCM8450UC/05, BCM8450UC/09, BCO110, BCO120T, BCO130T, BCO264B, BCO320T, BCO330T, BCO430, BCO430BM, BCO432, BCO70, CAM51015B, CAM51025MB, CAM51035M, CC100IU, CM041, CM044, COM530M, COM532M, D14, D31, D4B, D612, D650, D660, D665, D895, D895C, D895UX, D986, DC312T, DC412T, DC412TTC, DC414T, DC514T, DCF210TTC, DCF212T, DCF2210TTC, DCF2212T, DCF6212TTC, DCF6214T, DCM020ST, DCM024BK, DCM025GR, DCM028, DCM029, DCM02BK, DCM02BL, DCM02GR, DCM02OR, DCM02RE, DCM02ST, DCM040, DCM041, DCM043, DCM044, DCM045, DCM047, DCM048, DCM049, DCM04RE, DCM1385OR, DCR902T, DE40P, DE50P, DE650P, DEN500P, DES020, DES020S, DES021, DES023, DES024, DES025, DES027, DES028, DES029, DFH233, DH100P, DH40P, DO1279, DO1280S, DO1289, EAM3200, EAM3300, EAM3400, EAM3400N, EAM3500, EAM3500N, EAM4000, EAM4000B, EAM4400, EAM4500, EC140B, EC140BEXC, EC155, EC220CD, EC260BK, EC270, EC330, EC460, EC5, EC5W, EC6, EC610, EC680BK, EC680BM, EC680BMC, EC680M, EC680M Dedica, EC680R, EC680R Dedica Red, EC685BK, EC685BK Dedica Deluxe, EC685M, EC685M Dedica Deluxe, EC685R, EC685R Dedica Deluxe, EC685W, EC685W Dedica Deluxe, EC700, EC701, EC702, EC710, EC730, EC860, EC885M, EC9155MB, EC9335BK, EC9335M, EC9335R, EC9335REX4, EC9355M, EC9665M, ECAM22110B, ECAM22110SB, ECAM23120SB, ECAM23120SBS11, ECAM23210B, ECAM23210SB, ECAM23260, ECAM23260SB, ECAM23270S, ECAM23450SL, ECAM23460, ECAM25462S, ECAM26455M, ECAM28465B, ECAM28465M, ECAM28465MD, ECAM29034SB, ECAM29043SB, ECAM29063SB, ECAM29084SB, ECAM35020B, ECAM35020W, ECAM35025SB, ECAM35075SI, ECAM37095TI, ECAM44660B, ECAM45055S, ECAM45760B, ECAM46860S, ECO310BK, ECO310R, ECO310W, ECP3120, ECP3220, ECP3220R, ECP3220W, ECP3420, ECP3620, ECP3630, EDG455, EDG656TEX1, EMF2BK, EMFIBK, EMK6, EMK6A, EMK6YL, EN267BAE, EN520B, EN520BEX1, EN520R, EN560S, EN680M, EN750MB, EO12001B, EO1200B, EO1238, EO1251, EO1258, EO1260, EO1270, EOP2046, ESAM04110B, ESAM04110S, ESAM2000, ESAM3300, ESAM3300EXD, ESAM3300EXHD, ESAM3300S, ESAM3500, ESAM3500N, ESAM4400, ESAM4500, ESAM5400, ESAM5500, ESAM5500B, ESAM5500M, ESAM5600, ESAM5600SL, ESAM6600, ESAM6620, ESAM6700, ESAM6900, ESAM6900M, FH1130/1BK, FH1163/1BK, FH1363/1BK, ICM17270, KF180BLACK, KF180TITAN, KF180WHITE, KF510, KF5350BK, KF5350WH, KF550, KF5650BK, KF580, KF600, KF600BLACK, KF600WHITE, KF6031BK, KF6050WH, KF7000BK, KF7070SI, KF7150BK, KF7155, KF7170BK, KF7170SI, KF7175, KF7370SI, KF9050BK, KF9070SI, KF9150BK, KF9150WH, KF9170SI, KG521M, KMM30BLACK, KMM30WHITE, KSM2, KSM4, M810, M850, M870220W, M870280W, M880220W, M880280W, MR310, MR330, MR400, MR430, PACT100P, PACT110P, PACT140HPEC, PENTA, TA1200, TA1400, VVX1470GA
Informações gerais
As cafeteiras são aparelhos projetados para preparar café de forma conveniente em casa ou em ambientes comerciais. Elas vêm em vários tipos, cada um empregando métodos diferentes para extrair sabores do café moído.
Tipos
Cafeteiras de filtro (gotejamento)
Cafeteiras pour-over (manual)
As cafeteiras pour-over são dispositivos de preparo manual que permitem aos entusiastas do café ter mais controle sobre o processo. O design básico consiste em um funil ou gotejador em forma de cone, que comporta um filtro de papel ou metal. O café moído é colocado no filtro, e a água quente é despejada sobre ele de maneira lenta e controlada.
Cafeteiras de gotejamento automático
As cafeteiras de gotejamento automático, também conhecidas como cafeteiras automáticas, são dispositivos elétricos de preparo populares projetados para conveniência e facilidade de uso. Elas automatizam o processo de preparo. Você adiciona água a um reservatório, coloca o café moído em uma cesta de filtro e liga a máquina. A água é aquecida e depois gotejada sobre o café moído. O café preparado passa por um filtro e cai em uma jarra ou bule, que fica sobre uma chapa aquecida para manter o café quente. Alguns modelos oferecem recursos como intensidade de preparo ajustável e temporizador.
Cafeteiras por imersão
Cafeteiras de preparo a frio (cold brew)
As cafeteiras de preparo a frio são dispositivos projetados para a preparação simples e eficiente de café cold brew. Elas normalmente envolvem a imersão de grãos de café moídos grosseiramente em água fria ou em temperatura ambiente por um período prolongado, geralmente de 12 a 24 horas. O resultado é um concentrado de café suave e menos ácido que pode ser diluído com água ou leite antes do consumo. Essas máquinas geralmente possuem um sistema de filtro ou malha para separar o pó, tornando o processo de preparo conveniente e sem sujeira.
Prensas francesas
A prensa francesa é um dispositivo de preparo de café simples e eficaz. Ela consiste em um recipiente cilíndrico de vidro ou aço inoxidável com um êmbolo e um filtro de malha metálica. Para fazer café, grãos moídos grosseiramente são imersos em água quente dentro da prensa. Após alguns minutos, o êmbolo é pressionado para baixo, separando o pó do café preparado. Este método permite uma xícara encorpada e saborosa, já que o pó de café permanece em contato direto com a água durante o processo de preparo.
Cafeteiras turcas
As cafeteiras turcas, conhecidas como cezve ou ibrik, são recipientes de preparo tradicionais projetados para fazer café turco. Geralmente feitas de cobre ou latão, essas panelinhas têm um cabo longo e uma base larga. O café moído finamente, a água e o açúcar (opcional) são combinados no cezve e aquecidos sobre fogo baixo. O processo de preparo único envolve levar a mistura quase à fervura várias vezes, criando um café forte e concentrado com uma espuma espessa conhecida como “kaymak”. O pó de café moído finamente assenta no fundo, oferecendo uma experiência de café rica e distinta.
Cafeteiras por pressão
AeroPress
A AeroPress é uma cafeteira compacta projetada para simplicidade e versatilidade. Ela consiste em uma câmara cilíndrica com um êmbolo e uma tampa de filtro. Para preparar o café, coloca-se o pó e a água quente na câmara, mistura-se, encaixa-se a tampa do filtro e pressiona-se o êmbolo para extrair o café. Seu design exclusivo permite um preparo rápido e fácil, sendo conhecida por produzir uma xícara de café suave e rica com controle sobre as variáveis de preparo. A AeroPress é popular entre entusiastas de café por sua portabilidade, preço acessível e capacidade de experimentar diferentes técnicas de preparo.
Cafeteira italiana (Moka Pot)
A Moka Pot é uma cafeteira de fogão que prepara um café forte e saboroso ao passar água fervente pressurizada pelo vapor através do café moído. Ela consiste em uma câmara inferior para a água, um funil central para o pó de café e uma câmara superior para o café pronto. À medida que a água aquece, a pressão a força através do pó de café, produzindo um café rico e concentrado conhecido como Moka. O processo é simples, rápido e popular por sua capacidade de criar um café robusto com um sabor distinto, um tanto similar ao expresso.
Máquinas de café de dose única
As máquinas de café de dose única são aparelhos compactos e convenientes projetados para preparar porções individuais de café. Elas utilizam cápsulas ou sachês de café pré-embalados, permitindo que as pessoas preparem rápida e facilmente uma única xícara de café com o mínimo de esforço e bagunça. Essas máquinas oferecem uma variedade de opções de café, atendendo a diferentes gostos, e são favorecidas por sua simplicidade e eficiência de tempo.
Máquinas de expresso
As máquinas de café expresso, comumente conhecidas como máquinas de expresso, são dispositivos especializados projetados para preparar café concentrado forçando a água quente através de grãos de café moídos finamente. Elas operam sob alta pressão, geralmente em torno de 9 bares, para extrair sabores ricos e compostos aromáticos do café. O expresso é caracterizado pelo seu sabor forte e intenso, bem como por uma camada de crema, uma espuma cremosa que se forma por cima. Essas máquinas vêm em vários tipos, incluindo manuais, semiautomáticas e automáticas, oferecendo níveis diferentes de controle sobre o processo de preparo.
Máquinas de café totalmente automáticas
As máquinas de café totalmente automáticas são aparelhos avançados que simplificam o processo de fazer café. Essas máquinas lidam com tudo, desde a moagem dos grãos até o preparo, eliminando a necessidade de intervenção manual. É possível personalizar fatores como tamanho da moagem, intensidade do café e tipo de bebida, já que essas máquinas podem produzir uma variedade de bebidas, incluindo expresso, cappuccino, latte e café comum. Com moedores integrados e sistemas de preparo automatizados, elas oferecem conveniência e consistência, entregando café fresco com o mínimo de esforço.
Cafeteiras de percolação
As cafeteiras de percolação são dispositivos tradicionais que consistem em um bule, um tubo central e uma cesta perfurada. A água no bule é aquecida e a pressão resultante a força para subir pelo tubo e cair sobre o pó de café na cesta. O café preparado flui de volta para o bule, criando um ciclo contínuo até que a intensidade desejada seja atingida. As cafeteiras de percolação eram populares no passado, mas foram amplamente substituídas pelas cafeteiras de gotejamento devido a diferenças nos métodos de preparo e preferências de sabor.
Cafeteiras de sifão
As cafeteiras de sifão, também conhecidas como cafeteiras a vácuo, empregam um método de preparo visualmente cativante e baseado na física. Consistindo em duas câmaras, a água é aquecida na câmara inferior, criando uma pressão de vapor que força a água a subir para a câmara superior, onde o pó de café é colocado. Quando o calor é desligado, o café preparado é puxado de volta para a câmara inferior devido a um efeito de vácuo. Esse processo resulta em um café único e aromático com um sabor suave e limpo, realçando os sabores dos grãos.
Informações adicionais
Um agradecimento especial a esses tradutores:
100%
Udo Baingo está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
