A vareta do vapor está partida
A vareta do vapor está partida e a máquina bloqueou. Como resolver? Obrigado
Translation
The steam rod is broken and the machine has jammed. How can I solve it? Thank you
Esta é uma boa pergunta?
Translation
What is the exact model name? I don't quite understand: the steam pipe has nothing to do with the brew group.
. Qual é o nome exato do modelo? Não percebo bem: o tubo de vapor não tem nada a ver com o grupo de infusão.
Esta resposta foi útil?
Just what I thought. I was going to buy it in second hand and that was the explanation the owner gave for the blocked (non functioning) machine. I thought it was suspicious. Many many thanks, all the best!
@joaopaulo37789 A frequent issue in some models is the blocking brewing unit: https://youtu.be/qnFO8oeiidA?si=Wwk1HlpQ... (Sorry, in German)
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 79
