Ir para o conteúdo principal
The Portege Z830-S8302 is a laptop manufactured by Toshiba and was released late 2012. This Ultrabook is thin, sleek, and lightweight making it easily portable.
5 Perguntas Visualizar todos
Turning off at odd times
Anytime I turn my laptop on, it automatically turn off after using it for a short while, and this keeps on repeating even if it is at 100 percent.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@ernestanokye could be a power issue but it sounds more like a thermal issue. It will turn off if it "feels" like it is overheating. I would suggest that at first you check the Windows (I assume your are running Windows OS what version?) You will need to use the Windows Event Viewer to review those logs. this site shows you how to access those logs. Let us know what you fiend out.
Next you want to check your RAM. If you have more than 1 memory module, try to run it with one and see if it still turns off. Then try the other one. See if that makes a difference.
Ultimately, I would open the bottom cover and clean the air ducts and the fan. Most likely I would even replace the thermal past. Again let us know what you find out,
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ernest Anokye será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 17
